I see the messages about doing a balance? I am new on here and have not installed a lot of apps but I will soon. So is it best to start the balance now or wait until I have loaded more apps. Any tips or ideas about this will be most welcome
gary
gary
you only need to balance only once a month or when you remove a lot of stuff to reclaim space
or when you resize btrfs partitions or add multiple drives using btrfs device add command
To find out whether you need to run balance, just have a close look at the output of
sudo btrfs filesystem usage /path
Overall:
Device size: 476.44GiB
Device allocated: 252.04GiB
Device unallocated: 224.40GiB
Device missing: 0.00B
Used: 224.00GiB
Free (estimated): 250.86GiB
And compare the difference between "unallocated" and "free", and "allocated" and "used". Snapshots can play a big part in this.
The higher the difference, the more it is likely that a balance operation can help.
You should not run a full balance, since it will rewrite almost everything, potentially leading to SSD degradation. A factor of 50% might be a good starting point.
EDIT: after a balance of 60% on the above, I get this:
Overall:
Device allocated: 245.04GiB
Device unallocated: 231.40GiB
Used: 223.99GiB
Free (estimated): 251.86GiB
Notice the difference.
Here is my initial information:
Overall:
Device size: 876.39GiB
Device allocated: 18.02GiB
Device unallocated: 858.36GiB
Device missing: 876.39GiB
Used: 14.49GiB
Free (estimated): 859.42GiB (min: 430.24GiB)
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 41.55MiB (used: 0.00B)
Multiple profiles: no
Data,single: Size:14.01GiB, Used:12.95GiB (92.44%)
Metadata,DUP: Size:2.00GiB, Used:786.94MiB (38.42%)
System,DUP: Size:8.00MiB, Used:16.00KiB (0.20%)
And a big thank you to both of you
gary
