niavo
18 February 2022 02:29
1
Kernel: 5.16.9-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/restore_backup_@_105424368/boot/vmlinuz-linux
root=UUID=307d340d-141b-4ab8-84f4-d9a41f921f6f quiet splash
resume=UUID=08186c96-ea26-402a-8bb2-a15a5e575416 loglevel=3
rootflags=defaults,noatime,noautodefrag,compress=zstd,subvol=restore_backup_@_105424368
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Laptop System: ASUSTeK product: X556UQK v: 1.0
Mobo: ASUSTeK model: X556UQK v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X556UQK.317 date: 04/16/2019
ID-1: BAT0 charge: 23.7 Wh (100.0%) condition: 23.7/38.0 Wh (62.4%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 201
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 900 min/max: 400/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 23209
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:134d
class-ID: 0302
Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:7 chip-ID: 04f2:b52b class-ID: 0e02 serial: <filter>
loaded: nvidia note: n/a (using device driver) display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
Sound Server-1: ALSA v: k5.16.9-arch1-1 running: yes
Sound Server-3: PipeWire v: 0.3.46 running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel bus-ID: 03:00.0 chip-ID: 168c:0036
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-8:13
chip-ID: 04ca:3018 class-ID: e001
Local Storage: total: 1.15 TiB used: 140.93 GiB (12.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2J scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZ7PD256HCGM-000H7
type: SSD serial: <filter> rev: 6H6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Imation model: Ridge
size: 7.47 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 191.41 GiB size: 191.41 GiB (100.00%)
used: 140.9 GiB (73.6%) fs: btrfs dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 451 MiB size: 450.1 MiB (99.80%)
used: 556 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 191.41 GiB size: 191.41 GiB (100.00%)
ID-4: /var/log raw-size: 191.41 GiB size: 191.41 GiB (100.00%)
ID-5: /var/tmp raw-size: 191.41 GiB size: 191.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.58 GiB used: 29.5 MiB (0.2%)
ID-2: swap-2 type: partition size: 11.46 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 48.0 C pch: 42.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3100
Processes: 294 Uptime: 8h 36m wakeups: 2 Memory: 11.58 GiB
used: 7.45 GiB (64.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1515 pacman: 1501 lib: 435 snap: 14
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.4-2):
head: impossible d'ouvrir '/var/log/pacman.log' en lecture: Aucun fichier ou dossier de ce type
System install date:
Last full system update: 2022-02-17
Failed units: logrotate.service
Ca anyone help me , after updating my system i have this message on boot "/@/boot/vmlinuz-linuz-zen not found . You need to load the kernel first. Failed to boot default and fallback entries . "
Thanks for your help .
Before getting too deep in the weeds, a quick and easy thing to check would be the boot settings in your UEFI BIOS menu (make sure it is pointing to the correct boot option).
SGS
18 February 2022 04:50
3
niavo:
You boot in a snapshot, did you restore this one after posting the garuda-inxi?
Please format your terminal output with 3 ~ in first and last line.
niavo
18 February 2022 07:45
4
Yes i boot on snapshot currenlty and i restor it to this snapshot but after rebooting system i have the same problem.
So this is the best format :
ID-1: BAT0 charge: 23.2 Wh (98.7%) condition: 23.5/38.0 Wh (61.8%)
Speed (MHz): avg: 800 min/max: 400/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 23209
Type: l1tf
class-ID: 0302
loaded: modesetting,nvidia display-ID: :0 screens: 1
direct render: Yes
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-8:11
Local Storage: total: 1.14 TiB used: 141.15 GiB (12.1%)
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2J scheme: GPT
used: 141.15 GiB (73.7%) fs: btrfs dev: /dev/sda8 maj-min: 8:8
ID-1: swap-1 type: zram size: 11.58 GiB used: 310.8 MiB (2.6%)
System Temperatures: cpu: 49.0 C pch: 43.5 C mobo: N/A
Processes: 298 Uptime: 3h 28m wakeups: 103 Memory: 11.58 GiB
used: 7.93 GiB (68.5%) Init: systemd v: 250 tool: systemctl Compilers:
inxi: 3.3.12
Garuda (2.5.4-2):
niavo
18 February 2022 07:47
5
@SGS where can i edit BOOT_IMAGE = /restore_backup_ ?
filo
18 February 2022 07:55
6
Have you already tried a sudo update-grub and reboot?
If nothing changes you could to do it manually in /boot/grub/grub.cfg but the risk is that at the next update-grub this will occur again. In that case we'll have to check the grub config files.
You could even try changing it from the grub, pushing button E at the grub line you normally use.
niavo
18 February 2022 08:28
7
@filo yes do it but after there's nothing change on boot .
filo
18 February 2022 08:37
8
You tried all the three hints and all failed?
niavo
18 February 2022 08:58
9
@filo I've tried update-grub but it can't help . But the two others i don't understand it clearly . Can you help me and check for it ?
filo
18 February 2022 09:34
10
Unfortunately I'm travelling without my Garuda laptop and cannot be 100% precise.
When you are in the grub, in the line that you normally use (probably the first one) instead of pressing enter press button E. You'll be presented with a long string which is what the grub is actually doing to boot. Try to locate that part which is unneeded: /restore_backup_@_105424368, so that you should leave only the part /boot/vmlinuz-linux-zen. Then press ctrl+X to continue booting.
or
When you're logged as above in the snapshot, do a
sudo micro /boot/grub/grub.cfg and again locate that part to remove as above. Then exit with ctrl+Q and confirm to save changes. Then sudo update-grub
Please Note: I added the -zen because by your error message it looks like you should boot into the linux-zen kernel, while your snapshot seems to be from a linux kernel.
This suggests me also another possibility, that the linux-zen is missing at all for some reasons?
So, you could also use a live USB, login, use the chroot function in the Garuda Welcome and do a
pacman -S linux-zen linux-zen-headers
niavo
18 February 2022 10:56
11
I test first suggestion so where i can edit to what you suggest . Sorry ot bother you . I Really need these helo .
filo
18 February 2022 10:59
12
It's correct.
Try directly the last suggestion (live USB -> chroot -> install kernel)
niavo
18 February 2022 11:19
13
I'm on garuda live now . So i chroot with this button ?
filo
18 February 2022 11:22
14
Yes, of course, it's the only button with that name
Please try to avoid pictures, especially when unneded...
niavo
18 February 2022 11:25
15
Do you have skype or something like that ? Now garuda say to me after executing "pacman -S linux-zen linux-zen-headers" failed to retrieve somes files .
filo
18 February 2022 11:28
16
No skype of course, I'm travelling on a train And I cannot be so much available, sorry.
Try to enter update. This should hopefully update your system and maybe freshing the mirrors might help also installing the kernel. It's difficult to understand what's going on there...
You can copy the error text from your chroot terminal and past it in your posts.
niavo
18 February 2022 11:40
17
@filo I execute update on the live usb ?
filo
18 February 2022 11:41
18
When you are into the chroot, not in a "normal" USB terminal.
In that moment you're logged as root into your installed system.
@niavo - more about chroot and what it is/does.
https://wiki.archlinux.org/title/Chroot#Using_arch-chroot
Using chroot from garuda does most of that for you.
system
Closed
20 February 2022 12:48
21
