hey, yesterday i did an update (that also included the garuda-update command), and when i started my pc today the hardened linux kernel threw the error
error: file '/@/boot/initramfs-linux-hardened.img' not found.
Press any key to continue
the latter part is funny, because whatever started instead or not started locked my keyboard… i tried to find others with the same problem, namely these three threads
after doing the steps from the first thread in that list my system now freezes after/at the “loading initramfs” command. i have no idea what to do, i’m currently running on the normal linux kernel. also neither the garuda-update nor the update-grub nor install-grub threw any errors
inxi:
Kernel: 6.5.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6104ec12-31c8-4149-b0f4-da54e147aa2b rw rootflags=subvol=@
rd.luks.uuid=a2fc9904-d25f-4977-ac91-c799b10c769a rd.udev.log_priority=3
vt.global_cursor_default=0
rd.luks.uuid=46b27a70-db7b-45e9-b0fd-5795061b5d01
resume=/dev/mapper/luks-46b27a70-db7b-45e9-b0fd-5795061b5d01 loglevel=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
serial: <superuser required> UEFI: American Megatrends LLC. v: M.J0
date: 06/30/2023
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2783 high: 3129 min/max: 400/4267 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2996 2: 2993 3: 2989
4: 2994 5: 2993 6: 2983 7: 2993 8: 2950 9: 2990 10: 3129 11: 400 12: 2997
bogomips: 86274
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 12:00.0 chip-ID: 1002:73ff
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: right model: HP V22e
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: Samsung C24F390 serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon RX 6600
(navi23 LLVM 16.0.6 DRM 3.54 6.5.3-arch1-1) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:ab28
Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1 chip-ID: 1002:1637
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
Device-4: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-2.2:4 chip-ID: 0c76:161e class-ID: 0300
API: ALSA v: k6.5.3-arch1-1 status: kernel-api tools: N/A
lanes: 1 port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 4.09 TiB used: 753.54 GiB (18.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 27.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500LX005-1CW162
tech: HDD rpm: 5400 serial: <filter> fw-rev: LVD1 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 054
ID-1: / raw-size: 914.15 GiB size: 914.15 GiB (100.00%)
used: 601.4 GiB (65.8%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-a2fc9904-d25f-4977-ac91-c799b10c769a
ID-3: /home raw-size: 914.15 GiB size: 914.15 GiB (100.00%)
ID-4: /var/log raw-size: 914.15 GiB size: 914.15 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.15 GiB size: 914.15 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
mapped: luks-46b27a70-db7b-45e9-b0fd-5795061b5d01
ID-2: swap-2 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.6 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 34.0 C
Processes: 384 Uptime: 1h 20m wakeups: 0 Memory: total: 32 GiB
available: 31.24 GiB used: 10.68 GiB (34.2%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1702
pm: pacman pkgs: 1651 libs: 432 tools: octopi,paru pm: flatpak pkgs: 51
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date: 2023-04-12
Last full system update: 2023-09-20
