T-Fen
18 January 2022 04:11
1
❯ inxi -Faz 520 Mbps ─╯
Kernel: 5.15.11-230-tkg-bmq x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0971afba-13f1-4f58-9dc9-2efda4002dba rw rootflags=subvol=@
Type: Desktop Mobo: System76 model: Thelio Major v: thelio-major-r2
serial: <superuser required> UEFI: System76 v: F4c Z5 date: 06/30/2020
Info: model: AMD Ryzen Threadripper 3960X bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x31 (49) stepping: 0 microcode: 0x8301025
Topology: cpus: 1x cores: 24 tpc: 2 threads: 48 smt: enabled cache:
L1: 1.5 MiB desc: d-24x32 KiB; i-24x32 KiB L2: 12 MiB desc: 24x512 KiB
L3: 128 MiB desc: 8x16 MiB
Speed (MHz): avg: 3641 high: 4128 min/max: 2200/4568 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4110 2: 3786
3: 3806 4: 3595 5: 3624 6: 3721 7: 3632 8: 3604 9: 3587 10: 3591 11: 3644
12: 3581 13: 3593 14: 4128 15: 3374 16: 3595 17: 3591 18: 3589 19: 3581
20: 3588 21: 3592 22: 3385 23: 3605 24: 3593 25: 3940 26: 3794 27: 3432
28: 3913 29: 3759 30: 4030 31: 3594 32: 3449 33: 3503 34: 3597 35: 3586
36: 3586 37: 3592 38: 3596 39: 3598 40: 3582 41: 3599 42: 3591 43: 3593
44: 3591 45: 3587 46: 3596 47: 3584 48: 3593 bogomips: 364481
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: eVga.com.
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 21:00.0
chip-ID: 10de:1f06 class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-1:2
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Device-3: Elgato Systems Cam Link 4K type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-2:3
chip-ID: 0fd9:0066 class-ID: 0102 serial: <filter>
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.7x13.4")
s-diag: 692mm (27.2")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 21:00.1 chip-ID: 10de:10f9
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel v: kernel
bus-ID: 23:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam type: USB
Device-4: Elgato Systems Cam Link 4K type: USB
Device-5: Audio-Technica ATR2100x-USB Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:5 chip-ID: 0909:004d
Device-6: C-Media Vanatoo T0 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-2:12 chip-ID: 0d8c:0012
Device-7: Giga-Byte USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-5:5 chip-ID: 0414:a002
Sound Server-1: ALSA v: k5.15.11-230-tkg-bmq running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: 9000 bus-ID: 43:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp67s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 44:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlo2 state: up mac: <filter>
bus-ID: 9-5:2 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 2.72 TiB used: 414.42 GiB (14.9%)
rev: 2B2QEXM7 temp: 56.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Patriot model: N/A
size: 922.5 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
used: 409.68 GiB (44.0%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
used: 560 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-1: swap-1 type: zram size: 62.75 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 10%
Processes: 828 Uptime: 9h 31m wakeups: 0 Memory: 62.75 GiB
used: 19.6 GiB (31.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 2142 pacman: 2134 lib: 577 flatpak: 0 snap: 8
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.11
Bluetooth has stopped working for me (no devices found) and I assume it may be the kernel.
dmesg | grep blue returns no results. Is there a know issue with this kernel and is the recommendation to switch to the LTS kernel. I've not switched kernels in Garuda, so not sure how 'easy' that is.
Thank you!
Bro
18 January 2022 04:58
2
Kernels are scary enough without basic knowledge.
$ sudo pacman -S linux-lts linux-lts-headers
Then reboot and select the LTS kernel to boot into at the GRUB prompt..
Given it's Garuda, you may want to make that -Syu instead of just -S
T-Fen
18 January 2022 14:45
3
Thanks. I'll do so and report back
T-Fen
18 January 2022 21:17
4
❯ inxi -Fad 173.3 Mbps ─╯
Host: treytheliomajor Kernel: 5.15.15-1-lts x86_64 bits: 64 compiler: gcc
v: 11.1.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
Speed (MHz): avg: 3621 high: 4112 min/max: 2200/4568 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3595 2: 3594
3: 3594 4: 3593 5: 3591 6: 3593 7: 3593 8: 3594 9: 3593 10: 3588 11: 3585
12: 3608 13: 3591 14: 3592 15: 3583 16: 3588 17: 3592 18: 3593 19: 3591
20: 3596 21: 3593 22: 3586 23: 4112 24: 3593 25: 3587 26: 3766 27: 3593
28: 3594 29: 3590 30: 3594 31: 3593 32: 3591 33: 3593 34: 3590 35: 4025
36: 3879 37: 3593 38: 3593 39: 3601 40: 3592 41: 3586 42: 3592 43: 3595
44: 3593 45: 3593 46: 3590 47: 3578 48: 3593 bogomips: 364130
chip-ID: 046d:085e class-ID: 0300 serial: 05817110
chip-ID: 0fd9:0066 class-ID: 0102 serial: 0004B5227A000
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2 chip-ID: 0909:004d
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-2:3 chip-ID: 0d8c:0012
Sound Server-1: ALSA v: k5.15.15-1-lts running: yes
IF: enp67s0 state: down mac: b4:2e:99:fa:27:f1
IF: wlo2 state: up mac: ac:67:5d:fe:a3:80
Local Storage: total: 2.72 TiB used: 438.9 GiB (15.8%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: S59ANJ0N407863W rev: 2B2QEXM7 temp: 55.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
serial: S59ANJ0N407861F rev: 2B2QEXM7 temp: 54.9 C scheme: GPT
serial: 070194316C276B10 rev: PMAP scheme: MBR
Message: No optical or floppy data found.
used: 410.27 GiB (44.1%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 560 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.73 GiB used: 512 KiB (0.0%)
System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 58 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 5%
Processes: 738 Uptime: 57m wakeups: 0 Memory: 62.73 GiB
used: 9.72 GiB (15.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 2149 pacman: 2141 lib: 577 flatpak: 0 snap: 8
I have installed the LTS kernel now and still having issues with bluetooth. In System Settings -> Bluetooth it shows Bluetooth is disabled but clicking the button to enable it has no effect.
However, I AM getting dmsg output now
❯ sudo dmesg | grep blue 585.1 Mbps ─╯
[ 11.980509] audit: type=1130 audit(1642536960.498:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth-autoconnect comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.026669] audit: type=1130 audit(1642536960.538:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Thanks for any troubleshooting guidance with this.
Bro
18 January 2022 22:58
5
So let’s make sure Bluetooth is not blocked for some reason. Please post the terminal output of the command…
$ rfkill list Let’s just make that plain…
rfkill list
It’s easier to understand. Also…there doesn’t happen to be a key or keyboard combination on your machine that turns Bluetooth on/off by any chance?
T-Fen
18 January 2022 23:09
6
Thank you.
❯ rfkill list 526.6 Mbps ─╯
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy2: Wireless LAN
Soft blocked: no
Hard blocked: no
No such key on the keyboard that I'm aware of...
Bro
18 January 2022 23:32
7
OK, so let's play around a bit. Let's turn Bluetooth off, then back on again. This is probably easiest.
rfkill block bluetooth
then...
rfkill unblock bluetooth
Please be sure to reboot afterwards.
EDIT: I'm getting out of my depth with Bluetooth. Fortunately, we have forum members with some amount of expertise with things that fly over the air waves. It's isn't polite to ping Moderators, but I think it might be proper to ping someone who may know some stuff, that being @tbg .
There are others but I confuse their names and forums.
tbg
18 January 2022 23:45
8
Please post:
sudo dmesg | grep -Ei 'blue|firm'
sudo bluetoothctl
systemctl status bluetooth
sudo modprobe -r btusb && sleep 10 && sudo modprobe btusb
I would also suggest testing out the linux-mainline kernel.
I'm not an expert on anything, but I do know that there is a known 5.15 bug affecting Intel bluetooth radios. The "fix" is the radio appears to come back up normally after a cold boot (not reboot--full shutdown, wait a few seconds, then boot back up). Hopefully they will have a patch soon, my laptop has the same problem!
tbg
18 January 2022 23:49
10
@BluishHumility are you dual booting Windows? or is this strictly an Intel bug.
Have you tested any of the newer or developmental firmware packages. If not, I would suggest at least testing the linux-firmware-git package.
Ew, no!
It is a multi-boot laptop, but only LInux distros. The bug looks like it is specific to Intel radios and the 5.15 kernel.
Some folks are having success patching specific modules (see this Arch thread ), but I’m not about to start recommending that to people because it doesn’t look like a solid fix at this point.
Here’s the bugzilla link, with some more details about the module replacement fix for the brave: 215167 – Bluetooth: hci0: command 0xfc05 tx timeout
It has been known for a while and they are definitely working on it, so I’m planning on just waiting for the patch at this point.
Edit:
What’s this now?
tbg
19 January 2022 00:08
12
That will give you the newer firmware updates that are coming. Often the newer firmware can be found and downloaded directly from the Intel site. Sometimes the newest developmental versions can be found from Google, (as they develop for the Android platform which is of course basically Linux).
The linux-mainline kernel has the newest kernel hardware updates, so it is also the first to receive fixes.
The OP's Bluetooth adapter is registering as "up", is yours also up, but just won't connect.
Bro
19 January 2022 00:15
13
Please don't hijack @T-Fen 's thread. I'm also interested in the solution.
Oh, and thank you very much for stepping in @tbg and @BluishHumility .
tbg
19 January 2022 00:19
14
It could be a bit of a hijack, but the kernel and firmware suggestions/solutions should apply to both issue regardless, as they are always worth testing out.
I hate Bluetooth, but I was bored so I figured why not assist for a bit @Bro .
Bro
19 January 2022 00:27
15
I can install and run a simple 10-base-T /100-base-T ethernet, and for true client-server installations I could set it up and knew every one of NetWare's 5,000 damn acronyms, but things that fly over the airwaves mystify me. Nowadays my desk sits 3 feet from my router. Ethernet all the way, baby!
Thanks.
T-Fen
19 January 2022 01:39
16
sudo dmesg | grep -Ei 'blue|firm' 585 Mbps ─╯
[ 1.890099] acpi PNP0A08:03: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[ 7.716496] iwlwifi 0000:44:00.0: Direct firmware load for iwlwifi-cc-a0-66.ucode failed with error -2
[ 7.716509] iwlwifi 0000:44:00.0: Direct firmware load for iwlwifi-cc-a0-65.ucode failed with error -2
[ 7.716520] iwlwifi 0000:44:00.0: Direct firmware load for iwlwifi-cc-a0-64.ucode failed with error -2
[ 7.718821] Bluetooth: Core ver 2.22
[ 7.718843] NET: Registered PF_BLUETOOTH protocol family
[ 7.718844] Bluetooth: HCI device and connection manager initialized
[ 7.718850] Bluetooth: HCI socket layer initialized
[ 7.718852] Bluetooth: L2CAP socket layer initialized
[ 7.718854] Bluetooth: SCO socket layer initialized
[ 7.721758] iwlwifi 0000:44:00.0: loaded firmware version 63.c04f3485.0 cc-a0-63.ucode op_mode iwlmvm
[ 9.830052] Bluetooth: hci0: Reading Intel version command failed (-110)
[ 9.830053] Bluetooth: hci0: command 0xfc05 tx timeout
[ 12.227620] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.227623] Bluetooth: BNEP filters: protocol multicast
[ 12.227627] Bluetooth: BNEP socket layer initialized
and
❯ sudo bluetoothctl 585 Mbps ─╯
Agent registered
[bluetooth]#
and
❯ systemctl status bluetooth 585 Mbps ─╯
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2022-01-18 14:54:32 MST; 3h 42min ago
Docs: man:bluetoothd(8)
Main PID: 1114 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 76926)
Memory: 2.8M
CPU: 19ms
CGroup: /system.slice/bluetooth.service
└─1114 /usr/lib/bluetooth/bluetoothd
Jan 18 14:54:32 treytheliomajor systemd[1]: Starting Bluetooth service...
Jan 18 14:54:32 treytheliomajor bluetoothd[1114]: Bluetooth daemon 5.63
Jan 18 14:54:32 treytheliomajor systemd[1]: Started Bluetooth service.
Jan 18 14:54:32 treytheliomajor bluetoothd[1114]: Starting SDP server
Jan 18 14:54:32 treytheliomajor bluetoothd[1114]: Bluetooth management interface 1.21 initialized
and
❯ sudo modprobe -r btusb && sleep 10 && sudo modprobe btusb
The last commands returns nothing in the terminal
tbg
19 January 2022 01:44
17
No, it won’t unless there is a problem reloading the bluetooth driver. That command is simply to see if it triggers a change in the bluetooth status and sometimes things start working again.
Have you tried the LTS kernel as suggested?
If that brings no improvement then try the linux-mainline kernel. You do not need to uninstall the LTS kernel if it runs OK on ypur computer. It is a good idea to keep the LTS kernel installed as a backup.
Also, be sure to install the linux-firmware-git package.
T-Fen
19 January 2022 01:50
18
Yes, I'm on the LTS kernel right now...
Linux treytheliomajor 5.15.15-1-lts #1 SMP Sun, 16 Jan 2022 09:28:22 +0000 x86_64 GNU/Linux
tbg
19 January 2022 01:53
19
You need to report in depth on everything you test. Is bluetooth exactly the same on LTS. If so, test the mainline kernel and linux-firmware-git.
T-Fen
19 January 2022 01:59
20
Hi-
Just so there is no confusion/misunderstanding, I mentioned that I had installed and was subsequently running the LTS kernel in the 4th post of this thread.
I will try the mainline kernel along with linux-firmware-git and report back
