I dual booted my laptop to Garuda Linux and it seems I cannot enable bluetooth at all, I've read few of the forums with same problem as mine but could not get proper solutions. Some said it is a kernel problem and to try linux-lts or linux-hardened but no luck in there too. Some said Windows blocks some hardwares.
The fan speed also shows 0 rpm. Help me out, I'm pretty new to this.
Other methods which I've tried are bluetoothctl which shows the following output.
sudo bluetoothctl
[sudo] password for rupangkan:
Agent registered
[bluetooth]# power on
No default controller available
[bluetooth]# scan on
[bluetooth]#
Checking bluetooth services shows the following output -
systemctl status bluetooth
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2021-08-02 00:17:27 IST; 4h 58min left
Docs: man:bluetoothd(8)
Main PID: 496 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9288)
Memory: 3.1M
CPU: 24ms
CGroup: /system.slice/bluetooth.service
└─496 /usr/lib/bluetooth/bluetoothd
Aug 02 00:17:27 garuda-lappy systemd[1]: Starting Bluetooth service...
Aug 02 00:17:27 garuda-lappy bluetoothd[496]: Bluetooth daemon 5.60
Aug 02 00:17:27 garuda-lappy systemd[1]: Started Bluetooth service.
Aug 02 00:17:27 garuda-lappy bluetoothd[496]: Starting SDP server
Aug 02 00:17:27 garuda-lappy bluetoothd[496]: Bluetooth management interface 1.20 initialized
In my Dell desktop’s BIOS is a Hardware scanning setting, with Minimal, Auto, and Thorough setting choices.
Mine defaulted to either Auto or Minimal, and a dual-boot with Windows at some point had Windows deciding not to recognize BT. Neither did Linux. I played hell finding a solution. Dell tech support wasn’t helpful, and there were others with my machine model in the same boat.
I switched the Bios setting to Thorough and presto–my BT was restored!
@Bro Thanks for the reply
Mine is ASUS TUF F15 and bluetooth works just fine on my windows.
Let me try your solution if I can find the hardware scanning on my BIOS.
Have you disabled secure boot read this from GOD Microsoft they know they are in the wrong or they would not publish this web page Disabling Secure Boot | Microsoft Docs
When that happened to me a couple three years ago, I had to have the BT hardware re-acquired when switching back to Linux. Windows was changing my BT hardware’s MAC Address was why. grrr
It has been reported that when (in dual-boot) Windows pairs the device, then it is security linked with PC HW by HW address and it cannot be paired again from another (dual-booted) OS on the PC.
Since it is easy to use it in Windows, you could un-pair your bluetooth and see how it goes in Linux.
Not only Secure Boot, but also Fast Boot has to be disabled both in Windows and BIOS (if there is an option, usually there is).
@petsam the problem i'm facing is that bluetooth is being totally disabled, and it's not getting enabled at all on Garuda Linux. Pairing with a device is out of my option as bluetooth is not being enabled
On my laptop a reboot usually gets bluetooth and even wifi back if it doesn't appear on first boot. Though while I was back on windows I did need to reseat my wifi/bluetooth adapter to get it working again. Maybe consider that?
@Khsh01
Wifi wasn't working at 1st and works sometimes but now it works completely fine.
But that isn't the case for bluetooth, it has not been enabled, not even once on Garuda
I'll try to reset the bluetooth/wifi adapters as you said
Did you try systemctl status? to make sure the drivers are initialised? Could be a systemd/driver issue. I hear who ever maintains systemd is horrible at responding to issues. Not sure if Poettering is still the maintainer.
Aug 02 09:47:31 garuda-lappy kernel: Bluetooth: Core ver 2.22
Aug 02 09:47:31 garuda-lappy kernel: Bluetooth: HCI device and connection manager initialized
Aug 02 09:47:31 garuda-lappy kernel: Bluetooth: HCI socket layer initialized
Aug 02 09:47:31 garuda-lappy kernel: Bluetooth: L2CAP socket layer initialized
Aug 02 09:47:31 garuda-lappy kernel: Bluetooth: SCO socket layer initialized
Aug 02 09:47:32 garuda-lappy systemd[1]: Started Bluetooth autoconnect service.
Aug 02 09:47:32 garuda-lappy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth-autoconnect comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 09:47:32 garuda-lappy systemd[1]: Starting Bluetooth service...
Aug 02 09:47:32 garuda-lappy bluetoothd[493]: Bluetooth daemon 5.60
Aug 02 09:47:32 garuda-lappy kernel: audit: type=1130 audit(1627877852.137:45): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 09:47:32 garuda-lappy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 09:47:32 garuda-lappy bluetoothd[493]: Starting SDP server
Aug 02 09:47:32 garuda-lappy systemd[1]: Started Bluetooth service.
Aug 02 09:47:32 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 09:47:32 garuda-lappy kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 02 09:47:32 garuda-lappy kernel: Bluetooth: BNEP filters: protocol multicast
Aug 02 09:47:32 garuda-lappy kernel: Bluetooth: BNEP socket layer initialized
Aug 02 09:47:32 garuda-lappy bluetoothd[493]: Bluetooth management interface 1.20 initialized
Aug 02 09:47:32 garuda-lappy NetworkManager[496]: <info> [1627877852.2534] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-bluetooth.so)
Aug 02 09:47:40 garuda-lappy systemd[2538]: Starting Bluetooth OBEX service...
Aug 02 09:47:40 garuda-lappy systemd[2538]: Started Bluetooth OBEX service.
Aug 02 09:47:40 garuda-lappy kded5[2780]: bluedevil: Bluetooth operational changed true
Aug 02 09:55:07 garuda-lappy systemd[2538]: Started Bluetooth.
Aug 02 09:56:34 garuda-lappy polkit-kde-authentication-agent-1[2873]: Message of action: "Authentication is required to start 'bluetooth.service'."
Aug 02 09:56:37 garuda-lappy polkitd[504]: Operator of unix-session:2 successfully authenticated as unix-user:rupangkan to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.79 [systemctl start bluetooth.service] (owned by unix-user:rupangkan)
Aug 02 09:56:49 garuda-lappy polkitd[504]: Operator of unix-session:2 successfully authenticated as unix-user:rupangkan to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.83 [systemctl enable bluetooth.service] (owned by unix-user:rupangkan)
Aug 02 10:00:35 garuda-lappy dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.88' (uid=0 pid=12777 comm="sudo bluetoothctl")
Aug 02 10:00:35 garuda-lappy sudo[12777]: rupangkan : TTY=pts/1 ; PWD=/home/rupangkan ; USER=root ; COMMAND=/usr/bin/bluetoothctl
Aug 02 10:02:31 garuda-lappy systemd[2538]: Started Bluetooth.
Aug 02 10:02:56 garuda-lappy systemd[2538]: app-bluetooth-0d2f326ed72a4483929fa5e748a86c5c.scope: Consumed 3.352s CPU time.
Aug 02 10:09:52 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/anaconda3/lib/libQt5Bluetooth.prl" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:13:34 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-xxxhdpi/perm_group_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:13:57 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-xhdpi/perm_group_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:14:22 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-xhdpi/stat_sys_data_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:14:30 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-xhdpi/ic_volume_bluetooth_in_call.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:14:30 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-xhdpi/ic_volume_bluetooth_ad2p.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:14:58 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable/ic_settings_bluetooth.xml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:14:59 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable/ic_bluetooth_share_icon.xml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:15:02 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable/ic_qs_bluetooth.xml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:15:25 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-ldpi/stat_sys_data_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:15:29 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-ldpi/ic_volume_bluetooth_in_call.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:15:29 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-ldpi/ic_volume_bluetooth_ad2p.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:15:37 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-hdpi/perm_group_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:16:03 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-hdpi/stat_sys_data_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:16:11 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-hdpi/ic_volume_bluetooth_in_call.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:16:11 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-hdpi/ic_volume_bluetooth_ad2p.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:16:33 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-mdpi/perm_group_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:16:59 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-mdpi/stat_sys_data_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:17:07 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-mdpi/ic_volume_bluetooth_in_call.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:17:07 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-mdpi/ic_volume_bluetooth_ad2p.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:17:13 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-xxhdpi/perm_group_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:17:22 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-xxhdpi/ic_perm_group_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:17:25 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:17:29 garuda-lappy baloo_file_extractor[15651]: kf.baloo: "/home/rupangkan/Android/Sdk/platforms/android-31/data/res/drawable-xxhdpi/stat_sys_data_bluetooth.png" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 02 10:17:37 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:17:37 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:33:32 garuda-lappy dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.102' (uid=0 pid=61132 comm="sudo bluetoothctl power on ")
Aug 02 10:33:32 garuda-lappy sudo[61132]: rupangkan : TTY=pts/1 ; PWD=/home/rupangkan/bluez-utils-compat ; USER=root ; COMMAND=/usr/bin/bluetoothctl power on
Aug 02 10:35:39 garuda-lappy polkit-kde-authentication-agent-1[2873]: Message of action: "Authentication is required to start 'bluetooth.service'."
Aug 02 10:35:41 garuda-lappy polkitd[504]: Operator of unix-session:2 successfully authenticated as unix-user:rupangkan to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.105 [systemctl start bluetooth.service] (owned by unix-user:rupangkan)
Aug 02 10:35:51 garuda-lappy polkitd[504]: Operator of unix-session:2 successfully authenticated as unix-user:rupangkan to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.109 [systemctl enable bluetooth.service] (owned by unix-user:rupangkan)
Aug 02 10:35:57 garuda-lappy dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.112' (uid=0 pid=62155 comm="sudo bluetoothctl power on ")
Aug 02 10:35:57 garuda-lappy sudo[62155]: rupangkan : TTY=pts/1 ; PWD=/home/rupangkan ; USER=root ; COMMAND=/usr/bin/bluetoothctl power on
Aug 02 10:36:06 garuda-lappy dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.114' (uid=0 pid=62272 comm="sudo bluetoothctl ")
Aug 02 10:36:06 garuda-lappy sudo[62272]: rupangkan : TTY=pts/1 ; PWD=/home/rupangkan ; USER=root ; COMMAND=/usr/bin/bluetoothctl
Aug 02 10:38:34 garuda-lappy systemd[2538]: Started Bluetooth.
Aug 02 10:38:49 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:38:49 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:38:49 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:38:49 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:38:50 garuda-lappy kernel: Bluetooth: hci0: urb 0000000041958dd7 failed to resubmit (2)
Aug 02 10:38:59 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:38:59 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:38:59 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:38:59 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:39:09 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:39:09 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:39:09 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:39:09 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:39:09 garuda-lappy kernel: Bluetooth: hci0: urb 00000000162779dd failed to resubmit (2)
Aug 02 10:39:20 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:39:20 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:39:20 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:39:20 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:39:20 garuda-lappy kernel: Bluetooth: hci0: urb 00000000a39aaf61 failed to resubmit (2)
Aug 02 10:39:30 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:39:30 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:39:30 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:39:30 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:39:40 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:39:40 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:39:40 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:39:40 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:39:50 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:39:50 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:39:50 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:39:50 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:39:50 garuda-lappy kernel: Bluetooth: hci0: urb 00000000bb2f21c1 failed to resubmit (2)
Aug 02 10:40:00 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:40:00 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:40:01 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:40:01 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:40:03 garuda-lappy polkit-kde-authentication-agent-1[2873]: Message of action: "Authentication is required to restart 'bluetooth.service'."
Aug 02 10:40:05 garuda-lappy polkitd[504]: Operator of unix-session:2 successfully authenticated as unix-user:rupangkan to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.128 [systemctl restart bluetooth.service] (owned by unix-user:rupangkan)
Aug 02 10:40:05 garuda-lappy bluetoothd[493]: Terminating
Aug 02 10:40:05 garuda-lappy systemd[1]: Stopping Bluetooth service...
Aug 02 10:40:05 garuda-lappy bluetoothd[493]: Stopping SDP server
Aug 02 10:40:05 garuda-lappy bluetoothd[493]: Exit
Aug 02 10:40:05 garuda-lappy dbus-daemon[495]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.62" (uid=1000 pid=3072 comm="/usr/bin/pipewire-media-session ") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=493 comm="/usr/lib/bluetooth/bluetoothd ")
Aug 02 10:40:05 garuda-lappy audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 10:40:05 garuda-lappy systemd[1]: bluetooth.service: Deactivated successfully.
Aug 02 10:40:05 garuda-lappy systemd[1]: Stopped Bluetooth service.
Aug 02 10:40:05 garuda-lappy kernel: audit: type=1131 audit(1627881005.518:280): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 10:40:05 garuda-lappy systemd[1]: Starting Bluetooth service...
Aug 02 10:40:05 garuda-lappy kded5[2780]: bluedevil: Bluetooth operational changed false
Aug 02 10:40:05 garuda-lappy bluetoothd[64073]: Bluetooth daemon 5.60
Aug 02 10:40:05 garuda-lappy audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 10:40:05 garuda-lappy systemd[1]: Started Bluetooth service.
Aug 02 10:40:05 garuda-lappy bluetoothd[64073]: Starting SDP server
Aug 02 10:40:05 garuda-lappy kernel: audit: type=1130 audit(1627881005.552:281): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 10:40:05 garuda-lappy dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.131' (uid=0 pid=64073 comm="/usr/lib/bluetooth/bluetoothd ")
Aug 02 10:40:05 garuda-lappy bluetoothd[64073]: Bluetooth management interface 1.20 initialized
Aug 02 10:40:05 garuda-lappy kded5[2780]: bluedevil: Bluetooth operational changed true
Aug 02 10:40:11 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:40:11 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:40:11 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:40:11 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:40:11 garuda-lappy kernel: Bluetooth: hci0: urb 00000000cfb694c4 failed to resubmit (2)
Aug 02 10:40:21 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:40:21 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:40:21 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:40:21 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:40:29 garuda-lappy polkitd[504]: Operator of unix-session:2 successfully authenticated as unix-user:rupangkan to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.135 [systemctl enable bluetooth.service] (owned by unix-user:rupangkan)
Aug 02 10:40:31 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:40:31 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:40:31 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:40:31 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:40:31 garuda-lappy kernel: Bluetooth: hci0: urb 00000000ea2f2c4d failed to resubmit (2)
Aug 02 10:40:41 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:40:41 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:40:42 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:40:42 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:40:52 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:40:52 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:40:52 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:40:52 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:41:02 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:41:02 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:41:02 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:41:02 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:41:12 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:41:12 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:41:12 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:41:12 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:41:12 garuda-lappy kernel: Bluetooth: hci0: urb 00000000a98f4895 failed to resubmit (2)
Aug 02 10:41:22 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:41:22 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:41:22 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:41:22 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:41:23 garuda-lappy kernel: Bluetooth: hci0: urb 0000000098d9d95e failed to resubmit (2)
Aug 02 10:41:33 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:41:33 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:41:33 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:41:33 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:41:33 garuda-lappy kernel: Bluetooth: hci0: urb 00000000e65abdeb failed to resubmit (2)
Aug 02 10:41:43 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:41:43 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:41:43 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:41:43 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:41:53 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:41:53 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:41:53 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:41:53 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:42:03 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:42:03 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:42:03 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:42:03 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:42:14 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:42:14 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:42:14 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:42:14 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:42:24 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:42:24 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:42:24 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:42:24 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:42:34 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:42:34 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:42:34 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:42:34 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:42:44 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:42:44 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:42:44 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:42:44 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:42:55 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:42:55 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:42:55 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:42:55 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:43:05 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:43:05 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:43:05 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:43:05 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:43:05 garuda-lappy kernel: Bluetooth: hci0: urb 0000000007fc3f2a failed to resubmit (2)
Aug 02 10:43:15 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:43:15 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:43:15 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:43:15 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:43:15 garuda-lappy kernel: Bluetooth: hci0: urb 0000000039908f2d failed to resubmit (2)
Aug 02 10:43:25 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:43:25 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:43:25 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:43:25 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:43:25 garuda-lappy kernel: Bluetooth: hci0: urb 0000000042a9b45f failed to resubmit (2)
Aug 02 10:43:36 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:43:36 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:43:36 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:43:36 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:43:46 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:43:46 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:43:46 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:43:46 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:43:46 garuda-lappy kernel: Bluetooth: hci0: urb 000000000dcd4e17 failed to resubmit (2)
Aug 02 10:43:56 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:43:56 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:43:56 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:43:56 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:44:06 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:44:06 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:44:06 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:44:06 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:44:16 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:44:16 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:44:17 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:44:17 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:44:27 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:44:27 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:44:27 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:44:27 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:44:37 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:44:37 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:44:37 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:44:37 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:44:47 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:44:47 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:44:47 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:44:47 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:44:57 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:44:57 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:44:58 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:44:58 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:44:58 garuda-lappy kernel: Bluetooth: hci0: urb 00000000aea9d6b1 failed to resubmit (2)
Aug 02 10:45:08 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:45:08 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:45:08 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:45:08 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:45:08 garuda-lappy kernel: Bluetooth: hci0: urb 000000004b4087b2 failed to resubmit (2)
Aug 02 10:45:18 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:45:18 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:45:18 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:45:18 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:45:28 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:45:28 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:45:28 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:45:28 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:45:28 garuda-lappy kernel: Bluetooth: hci0: urb 0000000092233493 failed to resubmit (2)
Aug 02 10:45:38 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:45:38 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:45:38 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:45:38 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:45:49 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:45:49 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:45:49 garuda-lappy systemd[2538]: Reached target Bluetooth.
Aug 02 10:45:49 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:45:59 garuda-lappy systemd[2538]: Stopped target Bluetooth.
Aug 02 10:45:59 garuda-lappy systemd[1]: Stopped target Bluetooth Support.
Aug 02 10:45:59 garuda-lappy systemd[1]: Reached target Bluetooth Support.
Aug 02 10:45:59 garuda-lappy systemd[2538]: Reached target Bluetooth.
[CONTINUES AS BODY LIMIT EXCEEDED]
@tbg I've tried two other kernels which are linux-lts and linux-hardened as well. Bluetooth does not seem to work in both of them
