Hey All–
I have searched the net and the forums here, but can’t really find anything that really helped me out with this audio issue. I know other people have had the problem, but I can’t seem to find a solution that works with my setup. I think I know what the problem is – pipewire setup and the like – but I need a second set of eyes that can offer an instruction set that may work for me.
Any suggestions are happily welcomed.
–ZF
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=64756c86-744a-4fa5-952b-1e2ddf6e70ec rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: N/A wm: kwin_x11 with: krunner
Type: Laptop System: LENOVO product: 21DA000WUS v: ThinkPad T15p Gen 3
Mobo: LENOVO model: 21DA000WUS v: SDK0T76538 WIN serial: <filter>
part-nu: LENOVO_MT_21DA_BU_Think_FM_ThinkPad T15p Gen 3
uuid: 0520eccc-31f0-11b2-a85c-a413d18f5b14 UEFI: LENOVO
v: N3EET35W (1.21 ) date: 11/08/2023
ID-1: BAT0 charge: 59.6 Wh (98.5%) condition: 60.5/68.0 Wh (88.9%)
volts: 12.8 min: 11.6 model: LGC 5B10W13960 type: Li-poly serial: <filter>
status: not charging cycles: 107
Info: model: 12th Gen Intel Core i7-12700H socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154)
stepping: 3 microcode: 0x430
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 554 high: 1214 min/max: 400/4600:4700:3500
base/boost: 2300/4700 scaling: driver: intel_pstate governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 594 2: 400 3: 697 4: 400 5: 1214
6: 400 7: 1100 8: 400 9: 696 10: 400 11: 1190 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 107520
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a2
class-ID: 0302
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 5986:9106
class-ID: 0e02
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 422x237mm (16.61x9.33")
s-diag: 484mm (19.05")
Monitor-1: eDP-1 model: BOE Display 0x08e2 built: 2019 res: 1600x900
hz: 60 dpi: 118 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 30.33 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 10 device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 24.0.1-arch1.1
device-ID: 8086:46a6 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:25a2 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
Local Storage: total: 953.87 GiB used: 280 GiB (29.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: 1108ANLA temp: 38.9 C
SMART: yes health: PASSED on: 1y 195d 7h cycles: 189
read-units: 27,525,543 [14.0 TB] written-units: 44,592,625 [22.8 TB]
used: 279.98 GiB (29.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 21.8 MiB (7.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.05 GiB used: 775.5 MiB (2.4%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 2177
Memory: total: 32 GiB available: 31.05 GiB used: 9.57 GiB (30.8%)
igpu: 64 MiB
Processes: 421 Power: uptime: 23m states: freeze,mem,disk suspend: s2idle
image: 12.38 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1996 pm: pacman pkgs: 1975 libs: 584 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 21 Compilers: gcc: 13.2.1 alt: 12
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-11-18
Last full system update: 2024-02-19 ↻
