i lost all audio and cant get it back. I've had intermitten audio issues from day 1 but usually a reboot would fix. this time when i try a test tone it gives the following error (see pic)
lspci
0000:00:00.0 Host bridge: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers (rev 01)
0000:00:02.0 VGA compatible controller: Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] (rev 01)
0000:00:04.0 Signal processing controller: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant
(rev 01)
0000:00:08.0 System peripheral: Intel Corporation GNA Scoring Accelerator module (rev 01)
0000:00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller
0000:00:14.0 USB controller: Intel Corporation Tiger Lake-LP USB 3.2 Gen 2x1 xHCI Host Controller (rev 20)
0000:00:14.2 RAM memory: Intel Corporation Tiger Lake-LP Shared SRAM (rev 20)
0000:00:15.0 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #0 (rev 20)
0000:00:15.1 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #1 (rev 20)
0000:00:16.0 Communication controller: Intel Corporation Tiger Lake-LP Management Engine Interface (rev 20)
0000:00:1c.0 PCI bridge: Intel Corporation Tiger Lake-LP PCI Express Root Port #8 (rev 20)
0000:00:1d.0 System peripheral: Intel Corporation RST VMD Managed Controller
0000:00:1f.0 ISA bridge: Intel Corporation Tiger Lake-LP LPC Controller (rev 20)
0000:00:1f.3 Multimedia audio controller: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Control
ler (rev 20)
0000:00:1f.4 SMBus: Intel Corporation Tiger Lake-LP SMBus Controller (rev 20)
0000:00:1f.5 Serial bus controller: Intel Corporation Tiger Lake-LP SPI Controller (rev 20)
0000:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adap
ter
10000:e0:1d.0 PCI bridge: Intel Corporation Tiger Lake-LP PCI Express Root Port #9 (rev 20)
10000:e1:00.0 Non-Volatile memory controller: Sandisk Corp WD Black SN770 / PC SN740 256GB / PC SN560 (DRAM-le
ss) NVMe SSD (rev 01)
```text
Kernel: 6.4.11-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=17d9134e-705b-401f-8855-87098b482bdf rw rootflags=subvol=@ quiet quiet
resume=UUID=4340d6ff-bc5f-4b71-8031-81bba7025333 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-dy2xxx v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: HP model: 87FE v: 57.20 serial: <superuser required> UEFI: AMI v: F.21 date: 03/21/2022
ID-1: BAT0 charge: 39.7 Wh (100.0%) condition: 39.7/41.0 Wh (96.7%) volts: 12.9 min: 11.4
model: HP Primary type: Li-ion serial: <filter> status: full cycles: 16
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
level: v4 note: check built: 2020 process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xAC
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 320 KiB
desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1559 high: 2993 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 1252 2: 2257 3: 587 4: 1262 5: 2473 6: 402 7: 2993 8: 1251
bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony HP TrueVision HD Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 04f2:b6f1 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0991 built: 2020 res: 1920x1080 hz: 60 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel Xe Graphics (TGL GT2) direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel,snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.4.11-zen2-1-zen status: kernel-api with: aoss type: oss-emulator
Server-1: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse status: off 2: wireplumber
status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000 bus-ID: 0000:01:00.0
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-10:5 chip-ID: 0bda:b00e class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2 lmp-v: 8 status:
discoverable: no pairing: no class-ID: 7c010c
bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1018.04 GiB used: 432.52 GiB (42.5%)
ID-1: /dev
/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK SN770 1TB
serial: <filter> fw-rev: 731100WD temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: General USB Flash Disk size: 57.62 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: SSD serial: <filter> fw-rev: 1100 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 model: General USB Flash Disk size: 28.91 GiB block-size:
ID-1: / raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 17.81 GiB (45.6%) fs: btrfs
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%) used: 147.3 MiB (14.8%) fs: vfat
ID-3: /home raw-size: 858.4 GiB size: 858.4 GiB (100.00%) used: 405.7 GiB (47.3%) fs: btrfs
ID-4: /var/log raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 17.81 GiB (45.6%) fs: btrfs
ID-5: /var/tmp raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 17.81 GiB (45.6%) fs: btrfs
ID-1: swap-1 type: zram size: 15.27 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
ID-2: swap-2 type: partition size: 33.07 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Processes: 281 Uptime: 23m wakeups: 2278 Memory: total: 16 GiB note: est. available: 15.27 GiB
used: 4.17 GiB (27.3%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: 1891 pm: pacman pkgs: 1877 libs: 564 tools: octopi,pamac,paru,trizen
pm: flatpak pkgs: 14 Client: shell wrapper v: 5.1.16-release inxi: 3.3.29
System install date: 2023-08-17
Last full system update: 2023-08-22 ↻
