i started using garuda linux on exactly one year ago and iam using it on a ( Asus TUF Gaming F15 FX566LU HN251T Laptop) it ran without any issues. LITERALLY there was no issues at all.6 months ago i shifted to vanilla arch btw and gave it a try everything ran good until i wanted to shutdown or restart the laptop. i only use kde as my DE and this kernel panic only occurs when i try to shutdown or restart my computer. So i came back to garuda and same happened and i switched to cachy os and again the same thing happened and then i tried Arco linux same thing happened and finally i lost hope and tried fedora and nobara kde. Everything worked fine no issues i had the same oackages installled on fedora and nobara which i had on arch. I scoured through every forum iam also very very noob in kernel panic troubleshooting since i think only linux elite users understand it but anyway iam writing this after a restart kernel panic. CAN SOMEONE PLEASE HELP ME RESOLVE THIS ISSUE.
(edited in garuda-inxi from a later post)
Kernel: 6.9.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=39ce2591-8067-4ad4-85fa-75e31fb85fd4 rw rootflags=subvol=@
quiet resume=UUID=9801a176-e135-4ae2-bb01-b98bc5839dc3 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LU_FX566LU
Mobo: ASUSTeK model: FX506LU v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: FX506LU.310
date: 11/26/2021
ID-1: BAT1 charge: 87.0 Wh (99.7%) condition: 87.3/90.0 Wh (96.9%)
volts: 17.4 min: 15.4 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1690 high: 4406 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 4321
5: 4406 6: 800 7: 800 8: 800 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:2 chip-ID: 13d3:56a2
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.3-arch1.1
device-ID: 8086:9bc4 memory: 7.55 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 24.1.3-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1660 Ti driver: nvidia v: 555.58.02
device-ID: 10de:2191 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
API: ALSA v: k6.9.8-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0026
Local Storage: total: 1.4 TiB used: 217.37 GiB (15.2%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: A-Data model: SX6000PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: VC0S036H temp: 32.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA1T0QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 34.9 C
ID-1: / raw-size: 459.64 GiB size: 459.64 GiB (100.00%)
used: 217.37 GiB (47.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
ID-3: /home raw-size: 459.64 GiB size: 459.64 GiB (100.00%)
ID-4: /var/log raw-size: 459.64 GiB size: 459.64 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.64 GiB size: 459.64 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:7
System Temperatures: cpu: 49.0 C pch: 54.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB available: 15.46 GiB used: 2.48 GiB (16.0%)
Processes: 284 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1445 libs: 418 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-07-09
Last full system update: 2024-07-12
i do not know if its a DE issue or,Driver issue or Hardware issue
NOTE: i beg of you guys to help me. i love this distro and it was my first distro when i started using linux and i dont want to give up on garuda or arch based distro’s even if the Kernel panics occur
Please do not post here in the forum, like in chat forums like Telegram.
As long as no one has responded to your post, you can edit your post.
Try to follow the template:
After rebooting, post the FULL output of garuda-inxi in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</> ) , or put three tildes (~) above and below the text
Use live ISO if boot not work.
I don’t think it’s a kernel panic, I use the terminal for reboot and shutdown.
Seems you didn’t search the forum, there are only three users so far with this weird behavior of KDE
filo
11 July 2024 20:32
5
You could try installing and then booting a different kernel, e.g. linux-lts:
At the next boot, you should select it in the GRUB menu under the advanced options.
“All” kernel I tried, failed.
linux, lts, zen.
That’s the fun part of a rolling release,
use old software
and it works
Fortunately, it works perfectly with Garuda’s other DE’s
Yeah but what version of KDE?
the new one 6.1 kde
Operating System: Garuda Linux
KDE Plasma Version: 6.1.2
KDE Frameworks Version: 6.3.0
Qt Version: 6.7.2
Kernel Version: 6.9.8-zen1-1-zen (64-bit)
Graphics Platform: X11
No, I am asking what version of KDE is running on Fedora (where everything works). As SGS mentioned, several other users have this issue as well and it definitely seems to be a KDE bug. Most likely your Fedora installation is using an older version of KDE, from before the bug was introduced.
I will try to reboot using the terminal as you said
Here’s the > garuda-inxi output
date: 11/26/2021
here you go
Summary
Operating System: Fedora Linux 40
KDE Plasma Version: 6.1.1
Qt Version: 6.7.2
Kernel Version: 6.9.7-200.fc40.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 8 × Intel® Core™ i5-10300H CPU @ 2.50GHz
Memory: 15.4 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: ASUS TUF Gaming F15 FX506LU_FX566LU
System Version: 1.0
kernel panic occurred even when restarting through the terminal
journalctl -b -1 -e
Jul 12 09:25:44 mak-garuda kernel: intel_rapl_common: Found RAPL domain package
Jul 12 09:25:44 mak-garuda kernel: intel_rapl_common: Found RAPL domain dram
Jul 12 09:25:44 mak-garuda kernel: ACPI: battery: new extension: ASUS Battery Extension
Jul 12 09:25:44 mak-garuda kernel: usb 1-7: Found UVC 1.00 device USB2.0 HD UVC WebCam (13d3:56a2)
Jul 12 09:25:44 mak-garuda kernel: usbcore: registered new interface driver uvcvideo
Jul 12 09:25:44 mak-garuda kernel: snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
Jul 12 09:25:44 mak-garuda kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
Jul 12 09:25:44 mak-garuda kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
Jul 12 09:25:44 mak-garuda kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Jul 12 09:25:44 mak-garuda kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
Jul 12 09:25:44 mak-garuda kernel: usbcore: registered new interface driver btusb
Jul 12 09:25:44 mak-garuda kernel: Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
Jul 12 09:25:44 mak-garuda kernel: Bluetooth: hci0: Boot Address: 0x24800
Jul 12 09:25:44 mak-garuda kernel: Bluetooth: hci0: Firmware Version: 132-3.24
Jul 12 09:25:44 mak-garuda kernel: Bluetooth: hci0: Firmware already loaded
Jul 12 09:25:44 mak-garuda kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input11
Jul 12 09:25:44 mak-garuda kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input12
Jul 12 09:25:44 mak-garuda kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input13
Jul 12 09:25:44 mak-garuda kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input14
Jul 12 09:25:44 mak-garuda kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Jul 12 09:25:44 mak-garuda kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
Jul 12 09:25:44 mak-garuda kernel: thermal thermal_zone7: failed to read out thermal zone (-61)
Jul 12 09:25:44 mak-garuda kernel: intel_tcc_cooling: Programmable TCC Offset detected
Jul 12 09:25:44 mak-garuda kernel: snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
Jul 12 09:25:44 mak-garuda kernel: snd_soc_avs 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
Jul 12 09:25:44 mak-garuda kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
Jul 12 09:25:44 mak-garuda kernel: iwlwifi 0000:00:14.3: Detected RF HR B3, rfid=0x10a100
Jul 12 09:25:44 mak-garuda kernel: iwlwifi 0000:00:14.3: base HW address: 8c:55:4a:99:37:1b
Jul 12 09:25:44 mak-garuda kernel: iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
Jul 12 09:25:44 mak-garuda kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
Jul 12 09:25:44 mak-garuda kernel: ucsi_ccg 4-0008: i2c_transfer failed -110
Jul 12 09:25:44 mak-garuda kernel: ucsi_ccg 4-0008: ucsi_ccg_init failed - -110
Jul 12 09:25:44 mak-garuda kernel: ucsi_ccg 4-0008: probe with driver ucsi_ccg failed with error -110
Jul 12 09:25:44 mak-garuda kernel: [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 2
Jul 12 09:25:44 mak-garuda kernel: ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
Jul 12 09:25:44 mak-garuda kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input15
Jul 12 09:25:44 mak-garuda kernel: ACPI: video: Video Device [PEGP] (multi-head: no rom: yes post: no)
Jul 12 09:25:44 mak-garuda kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input16
Jul 12 09:25:44 mak-garuda kernel: fbcon: i915drmfb (fb0) is primary device
Jul 12 09:25:44 mak-garuda kernel: fbcon: Deferring console take-over
Jul 12 09:25:44 mak-garuda kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Jul 12 09:25:44 mak-garuda kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Jul 12 09:25:44 mak-garuda systemd-journald[450]: Time spent on flushing to /var/log/journal/e9330d4231904a6189ecd112e42daaf1 is 14.366ms for 1463 entries
SGS
12 July 2024 06:28
14
How do you define kernel-panic?
Is that all in log?
For longer ones please use
By the way, please post terminal issues like this.
FYI
Jul 12 08:10:50 y7p systemd[1]: Stopping Set Up Additional Binary Formats...
Jul 12 08:10:50 y7p systemd[1]: systemd-sysctl.service: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Stopped Apply Kernel Variables.
Jul 12 08:10:50 y7p systemd[1]: systemd-coredump.socket: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Closed Process Core Dump Socket.
Jul 12 08:10:50 y7p systemd[1]: systemd-modules-load.service: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Stopped Load Kernel Modules.
Jul 12 08:10:50 y7p systemd[1]: Stopping Network Time Synchronization...
Jul 12 08:10:50 y7p systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Jul 12 08:10:50 y7p systemd[1]: run-credentials-systemd\x2dsysctl.service.mount: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Stopped Network Time Synchronization.
Jul 12 08:10:50 y7p systemd[1]: systemd-binfmt.service: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Stopped Set Up Additional Binary Formats.
Jul 12 08:10:50 y7p systemd[1]: systemd-backlight@backlight:amdgpu_bl0.service: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Jul 12 08:10:50 y7p systemd[1]: systemd-backlight@leds:platform::kbd_backlight.service: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Stopped Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight.
Jul 12 08:10:50 y7p systemd[1]: Removed slice Slice /system/systemd-backlight.
Jul 12 08:10:50 y7p systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Jul 12 08:10:50 y7p systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Jul 12 08:10:50 y7p systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Stopped Create System Files and Directories.
Jul 12 08:10:50 y7p systemd[1]: Stopped target Local File Systems.
Jul 12 08:10:50 y7p systemd[1]: Unmounting /boot/efi...
Jul 12 08:10:50 y7p systemd[1]: Unmounting /home...
Jul 12 08:10:50 y7p systemd[1]: Unmounting /root...
Jul 12 08:10:50 y7p systemd[1]: Unmounting /srv...
Jul 12 08:10:50 y7p systemd[1]: Unmounting Temporary Directory /tmp...
Jul 12 08:10:50 y7p systemd[1]: Unmounting /var/cache...
Jul 12 08:10:50 y7p systemd[1]: Unmounting /var/tmp...
Jul 12 08:10:50 y7p systemd[1]: Stopping Flush Journal to Persistent Storage...
Jul 12 08:10:50 y7p systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: home.mount: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Unmounted /home.
Jul 12 08:10:50 y7p systemd[1]: root.mount: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Unmounted /root.
Jul 12 08:10:50 y7p systemd[1]: srv.mount: Deactivated successfully.
Jul 12 08:10:50 y7p systemd[1]: Unmounted /srv.
Jul 12 08:10:50 y7p systemd[1]: tmp.mount: Deactivated successfully.
Maybe update to 2022/01/07
https://www.asus.com/us/supportonly/fx506lu/helpdesk_bios/
iam really sorry for posting it like this but i thought journctl and garuda-inxi were different so i posted the journalctl. also i will try your solution.
RPS
12 July 2024 14:55
16
I had a similar problem, but my kernel didn’t panic instead, the shutdown/reboot command would result in system freezing.
I am gonna take a wild guess and say it’s Proprietary NVIDIA Drivers.
If you’re okay with messing around the system, you can try the solution in my thread:
After using the system for some time with dedicated nvidia GPU, there is a very high chance that the system will freeze when I try to shut it down or log off. Sometimes it freezes as soon as I click on shutdown or log off, other times it appears to be shutting down, but it never shuts down 100%, just like in this post:
This does not happen with X11. This also does not happen if I boot into system with Nvidia GPU completely off (unload the drivers?) (using supergfxctl 4.0.5). I have used linux-…
SGS
12 July 2024 17:17
17
Seems it differs for everyone. I got black screen and mouse pointer work, I can use TTY 2 to 7 and shutdown or reboot.
But I can’t start the session from TTY with startplasma-x11 or startplasma-wayland.
Same on Notebooks without Nvidia GPU. But also on PC with GeForce RTX 3060.
Bro
12 July 2024 17:40
18
I noticed you are running under Wayland in Fedora but x11 in Garuda. What happens if you run Garuda w/Wayland & various kernels?
If you are comfortable installing and uninstalling packages via terminal I’d suggest try the nvidia-open-dkms.
SGS
12 July 2024 23:06
20
Just test it on notebooks, shutdown and reboot works fine with zen kernel.
Somebody fix it
PC (Nvidia) I can’t test at moment.
in x11 it occurs less but on wayland i experienced it a bit more
same with me if i had played any game or any gpu intensive task when i reboot or shutdown it goes into kernel panic or if i use the laptop for prolonged time and then reboot/shutdown my kernel panics
