After using the system for some time with dedicated nvidia GPU, there is a very high chance that the system will freeze when I try to shut it down or log off. Sometimes it freezes as soon as I click on shutdown or log off, other times it appears to be shutting down, but it never shuts down 100%, just like in this post:
This does not happen with X11. This also does not happen if I boot into system with Nvidia GPU completely off (unload the drivers?) (using supergfxctl 4.0.5). I have used linux-amd-znver3, linux-zen, linux-lts.
I have spent weeks trying to find a workaround/understand the cause, but I can’t.
Help.
system info:
Kernel: 6.9.4-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=a3ed4574-408f-4802-8fc7-dded1b46b1ac rw rootflags=subvol=@
resume=UUID=21ea485a-d6f1-4646-b304-bca6967a48e0 loglevel=3
mitigations=off ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713QM.331
date: 02/24/2023
ID-1: BAT0 charge: 40.6 Wh (48.0%) condition: 84.5/90.0 Wh (93.9%)
power: 25.4 W volts: 14.7 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 836 high: 1397 min/max: 400/4463 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 1397 9: 1397 10: 400 11: 1397 12: 400
13: 1397 14: 1397 15: 1396 16: 400 bogomips: 102242
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 550.90.07 alternate: nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
empty: none bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 49.0 C
alternate: fbdev,vesa dri: radeonsi gpu: nvidia,amdgpu display-ID: 0
Monitor-1: HDMI-A-1 res: 1920x1200 size: N/A modes: N/A
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
drv: radeonsi inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
renoir LLVM 17.0.6 DRM 3.57 6.9.4-AMD-znver3) device-ID: 1002:1638
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia
v: 550.90.07 device-ID: 10de:2520 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
driver: N/A alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
API: ALSA v: k6.9.4-AMD-znver3 status: kernel-api with: aoss
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 2.77 TiB used: 1.28 TiB (46.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 1.86 TiB block-size: physical: 512 B
fw-rev: 3.2.F.83 temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 46.9 C
ID-1: / raw-size: 500 GiB size: 500 GiB (100.00%) used: 307.27 GiB (61.5%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-3: /home raw-size: 500 GiB size: 500 GiB (100.00%)
used: 307.27 GiB (61.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
ID-4: /var/log raw-size: 500 GiB size: 500 GiB (100.00%)
ID-5: /var/tmp raw-size: 500 GiB size: 500 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.79 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p4 maj-min: 259:7
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 49.0 C
Memory: total: 32 GiB note: est. available: 30.79 GiB used: 4.08 GiB (13.2%)
Processes: 395 Power: uptime: 29m states: freeze,mem,disk suspend: s2idle
image: 12.27 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 2344 pm: pacman pkgs: 2330 libs: 599 tools: octopi,paru
pm: flatpak pkgs: 14 Compilers: clang: 17.0.6 gcc: 14.1.1 alt: 13
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-03-16
Last full system update: 2024-06-18
