Hello guys, wishing you a great day.
i trie to look for some solutions to my issue, but i wasn't able to fix the issue with my slow wifi which connect and disconnect sometimes. I am not sure if it is a software issue or hardware one.
Kernel: 5.19.13-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=bd4b123b-0f2e-433f-8b12-4520a90be50d rw rootflags=subvol=@
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Acer product: Aspire V3-371 v: V1.16
Mobo: Acer model: Aspire V3-371 v: V1.16 serial: <superuser required>
UEFI-[Legacy]: Insyde v: 1.16 date: 11/25/2014
ID-1: BAT0 charge: 31.6 Wh (87.1%) condition: 36.3/48.9 Wh (74.2%)
volts: 15.8 min: 15.2 model: LGC AC14B8K type: Li-ion serial: <filter>
Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 built: 2015-18 process: Intel 14nm family: 6
model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2212 high: 2265 min/max: 500/2700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2265 2: 2196 3: 2195
4: 2195 bogomips: 17567
vulnerable
Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-1.7:4
chip-ID: 04f2:b469 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting
alternate: fbdev,intel,vesa gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x212c built: 2013 res: 1366x768
dpi: 118 gamma: 1.2 size: 293x164mm (11.54x6.46") diag: 336mm (13.2")
ratio: 16:9 modes: 1366x768
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Acer
Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.19.13-arch1-1 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer
Incorporated ALI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-1.5:3 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 119.24 GiB used: 32.37 GiB (27.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingfast model: N/A size: 119.24 GiB
serial: <filter> rev: 61L3 scheme: MBR
ID-1: / raw-size: 37.55 GiB size: 37.55 GiB (100.00%) used: 32.37 GiB
(86.2%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 37.55 GiB size: 37.55 GiB (100.00%) used: 32.37 GiB
ID-3: /var/log raw-size: 37.55 GiB size: 37.55 GiB (100.00%) used: 32.37
GiB (86.2%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/tmp raw-size: 37.55 GiB size: 37.55 GiB (100.00%) used: 32.37
ID-1: swap-1 type: zram size: 7.69 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 63.0 C pch: 52.0 C mobo: N/A
Processes: 222 Uptime: 11m wakeups: 1 Memory: 7.69 GiB used: 2.76 GiB
(35.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1274
libs: 323 tools: pamac,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-10-06
Last full system update: 2022-10-06 ↻
