Now, please don’t start on me that I haven’t searched the Forum.
I try to follow this forum but linux-zen-anbox was taking forever to build.
I even checked with xanmod-anbox, which is in the chaotic AUR; but again Anbox won’t start.
I checked the wiki: ArchWiki:Archive - ArchWiki
It says the ‘linux-zen kernel includes the necessary modules’
And I tried this( while using linux-zen) →
mkdir /dev/binderfs
mount -t binder binder /dev/binderfs
but again anbox won’t launch, int worked flawlessly with manjaro though
but it didn’t solve my issuse, since anbox is in chaotic-aur, It is reasonable that it should be provided with proper support and work flawlessly at Garuda. I wonder, how the package maintainer runs it.
Are you sure you need it?
I use the zen kernel, a couple of weeks ago I tried installing ambox-git from chaotic-aur and followed exactly that guideline.
I remember that
modprobe -a binder-linux ashmem-linux
gave me an error, but I saw in another forum that it was not needed anymore (sorry I didn’t take note of that site).
At least it was starting, the basic android apps started (for example I could reach google play with my account and install apps).
I gave up because the app I was interested in (Roblox, for my kids to get rid of windows for good) did not start…
Sorry I can’t help you more than this, but at least for sure it was starting…
Try using linux-xanmod-anbox to check if its a kernel issue, this one definitly got anbox support as I was using it myself when testing Anbox a while back.
It seams like it has been removed from chaotic-aur, and I don't want to build kernels from AUR, last time I did so, it took hours. And again I would have to wait same amount of time while updates
Works for me too, but with same results as with zen kernel: generally ok but not roblox, which was my objective.
Probably because the Android image is old, 7.1.
Never mind...
Instead of these seven contributions, two would have sufficed. There are no prizes for frequent writers here. It just bloats the threads unnecessarily.
I really wonder what is not understandable about this sentence?
So that it doesn’t get any longer, I’ll close here.
