Hello,
I am using Garuda dragonized gaming edition. I use an external hdd to backup my files. I have used this device in this os previously without any problem. But today I installed latest version of this os and I am facing a problem. My usb hdd is in read-only mode and the os does not let me write in it. Whenever I plug in the device to my pc the notification says, "You are not authorized to mount this device." I am new in linux and been using garuda for last three months. In my last install the device never cause any trouble but is showing the above message now and it has stopped my work process. Please provide a proper solution so that I do not have to format the device cause it contains around 900 GB of data. I have tried few of the existing solutions in this forum but no luck. The device is /sdb. Please help.
sudo fdisk -l
Disk /dev/sda: 223.57 GiB, 240057409536 bytes, 468862128 sectors
Disk model: TS240GSSD220S
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: B72871DA-FE2D-9246-94AC-7EBC9D002653
Device Start End Sectors Size Type
/dev/sda1 4096 618495 614400 300M EFI System
/dev/sda2 618496 468857024 468238529 223.3G Linux filesystem
Disk /dev/sdb: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Transcend
Disklabel type: dos
Disk identifier: 0xf1d12b96
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 64 1953520063 1953520000 931.5G 7 HPFS/NTFS/exFAT
Disk /dev/zram0: 15.57 GiB, 16717447168 bytes, 4081408 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=22d356d9-8602-4ffa-af8f-150a79ea6337 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A
Mobo: Gigabyte model: Z370 HD3-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F13 date: 08/13/2019
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 3941 high: 3989 min/max: 800/4000 scaling:
driver: intel_pstate governor: performance cores: 1: 3943 2: 3903 3: 3976
4: 3989 5: 3894 6: 3944 bogomips: 33599
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 3 speed: 8 GT/s ports: active: HDMI-A-3
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3:3 chip-ID: 0c45:6366
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa gpu: nouveau
s-diag: 582mm (22.9")
Monitor-1: HDMI-3 mapped: HDMI-A-3 model: HP 22er serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.7x10.6") diag: 583mm (23") ratio: 15:9 or 16/10
OpenGL: renderer: NV136 v: 4.3 Mesa 21.3.7 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f1
Device-3: Microdia Webcam Vitade AF type: USB
Device-4: Kingston HyperX Cloud Stinger Core Wireless + 7.1 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:4 chip-ID: 0951:170b
Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
Local Storage: total: 1.13 TiB used: 670.21 GiB (58.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS240GSSD220S
type: SSD serial: <filter> rev: 71.1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: ST1000LM024 HN-M101MBB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> scheme: MBR
used: 31 GiB (13.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.57 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nouveau temp: 44.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 800
Processes: 265 Uptime: 3m wakeups: 0 Memory: 15.57 GiB
used: 1.61 GiB (10.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1736 lib: 511 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-15
Last full system update: 2022-03-15
