Hey all,
Here’s my inxi :
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=66082618-ab1d-4528-aec7-ddaef29e9b82 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 splash
pcie_aspm=off ibt=off
Type: Convertible System: LENOVO product: 20FRS08U00
v: ThinkPad X1 Carbon 4th serial: <superuser required> Chassis: type: 31
Mobo: LENOVO model: 20FRS08U00 v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20FR_BU_Think_FM_ThinkPad
X1 Carbon 4th uuid: <superuser required> UEFI: LENOVO v: N1FET81W (1.55 )
date: 10/11/2022
ID-1: BAT0 charge: 47.4 Wh (100.0%) condition: 47.4/47.4 Wh (100.0%)
volts: 16.5 min: 14.8 model: LGC 00HW028 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 475 high: 700 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 400 3: 400 4: 400
bogomips: 22399
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
Device-2: Lite-On HD Webcam (960×540) driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 04ca:705a
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Monitor-1: eDP-1 model: AU Optronics 0x183d built: 2014 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 14.99 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:1916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
status: active 2: wireplumber status: active 3: pw-jack type: plugin
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
Info: services: NetworkManager,wpa_supplicant
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 1.4 TiB used: 296.25 GiB (20.7%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SN01T size: 953.55 GiB
block-size: physical: 512 B logical: 512 B type: Removable tech: SSD
serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
model: MZVKV512HAJH-000L1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 7L0QBXX7 temp: 24.9 C scheme: GPT
ID-1: / raw-size: 194.8 GiB size: 194.8 GiB (100.00%)
used: 180.72 GiB (92.8%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 194.8 GiB size: 194.8 GiB (100.00%)
ID-4: /var/log raw-size: 194.8 GiB size: 194.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 194.8 GiB size: 194.8 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C pch: 33.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Memory: total: 16 GiB note: est. available: 15.35 GiB used: 2.45 GiB (16.0%)
Processes: 242 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.1 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1628 libs: 457
tools: octopi,paru,yay Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.34
System install date: 2023-07-23
Last full system update: 2024-04-27
Failed units
λ yay
[sudo] Mot de passe de jacques :
:: Synchronisation des bases de données de paquets…
garuda 67.3 KiB 12.4 KiB/s 00:05 [-------------------------------------------] 100%
core est à jour
extra est à jour
multilib est à jour
chaotic-aur 1892.9 KiB 339 KiB/s 00:06 [-------------------------------------------] 100%
:: Searching AUR for updates...
:: There are 17 providers available for java-runtime-headless:
:: Repository extra
1) jdk-openjdk 2) jdk11-openjdk 3) jdk17-openjdk 4) jdk21-openjdk 5) jre-openjdk 6) jre-openjdk-headless 7) jre11-openjdk 8) jre11-openjdk-headless 9) jre17-openjdk 10) jre17-openjdk-headless 11) jre21-openjdk 12) jre21-openjdk-headless 13) jre8-openjdk-headless
:: Repository chaotic-aur
14) java-openjdk-ea-bin 15) jdk 16) jre 17) jre8
Enter a number (default=1):
The update begins, but after more than one our, it ends with an error about debugedit.
I think i cant delet this java-runtime-headlesst
Is there a way to do it ?
Thanks in forward… ![]()
