I have installed Dolphin Emu and I want to install a fork of Dolphin called Primehack. Installing Primehack through yay gives me several errors such as these:
dolphin-emu-primehack-git: /usr/share/dolphin-emu/sys/Resources/[email protected] exists in filesystem (own
ed by dolphin-emu)
dolphin-emu-primehack-git: /usr/share/dolphin-emu/sys/Resources/Platform_Gamecube.png exists in filesystem (ow
ned by dolphin-emu)
All my research into these errors has told me to override the files but I don't want to do that. I want both versions of the emulator installed. How do I do this without breaking something?
Um, I didn't even consider that a possibility. I just assumed there would be some way to install to a different location using the package manager. Then again, I don't really understand how Arch manages packages on a technical level.
Uninstall dolphin-emu and install primehack. Uninstalling dolphin-emu should keep your configuration, games etc. so when you want to use one of them, uninstall the other one.
According to the AUR package: https://aur.archlinux.org/packages/dolphin-emu-primehack-git
dolphin-emu-primehack-git conflicts with dolphin-emu-git.
If you check the latest comment, it seems someone manged to create a patch / change the PKGBUILD to install dolphin-emu-primehack-git along with dolphin-emu (not the git version, I think).
