I previously had this issue above with my microphone where I had to install EasyEffects
sudo pacman -S easyeffects
... and reduce the microphone to 25% in order to get decent sound in the microphone:
And then recently I had an issue that resulted in me having to to wipe my computer and reinstall Garuda from scratch, and I had to do the steps in previous paragraph all over again.
Please, the owner of Xfce flavor of Garuda, can you apply the steps in the 1st paragraph as default settings so that new users of Garuda Xfce don't have to go through this mess? It seems like low-hanging fruit that could be implemented without too much effort, and yet make a great difference to users.
inxi -Faz
Kernel: 5.15.69-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4bc99fd1-6a7e-4096-8fca-ccd010a3944b rw [email protected]
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire A315-56 v: V1.15
Mobo: IL model: Sleepy_IL v: V1.15 serial: <superuser required>
UEFI: Insyde v: 1.15 date: 07/13/2020
ID-1: BAT1 charge: 40.2 Wh (100.0%) condition: 40.2/47.8 Wh (84.1%)
volts: 12.1 min: 11.2 model: LGC AP18C8K type: Li-ion serial: N/A
status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 built: 2019-21 process: Intel 10nm family: 6
model-id: 0x7E (126) stepping: 5 microcode: 0xB2
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1252 high: 1283 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1183 2: 1283 3: 1264
4: 1279 bogomips: 9523
prctl and seccomp
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 0408:a061 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: eDP-1 model: BOE Display 0x07cb built: 2018 res: 1920x1080
ratio: 16:9 modes: 1920x1080
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
Sound Server-1: ALSA v: k5.15.69-1-lts running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer
Incorporated ALI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 04ca:3015 class-ID: e001
Local Storage: total: 238.47 GiB used: 70.2 GiB (29.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ1 size: 238.47 GiB block-size: physical: 512 B
rev: E8FK12.3 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 70.2 GiB
(29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 594 KiB
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 70.2
GiB (29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 70.2
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 70.2
ID-1: swap-1 type: zram size: 7.56 GiB used: 3.98 GiB (52.7%)
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 296 Uptime: 2d 4h 54m wakeups: 28 Memory: 7.56 GiB used: 5.22
GiB (69.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1289
libs: 364 tools: paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.21
