Problem: Microphone has excessive white noise
Attempted solutions:
- I opened PulseAudio Volume Control, clicked the "Input Devices" and slid the bar to around 15%. This significantly improved the signal/noise ratio, but the problem now is that I have to also increase the volume to high levels in order to hear the recording, because the recording is silent otherwise. I don't want to damage my ears by listening to a different audio after forgetting to reduce the volume, so I need a different solution to increasing signal/noise ratio - a solution that doesn't excessively reduce overall audio volume.
- So I decided to go to this webpage (PulseAudio - ArchWiki) and have a look at "Microphone echo/noise cancellation" section. It turns out that "
<module-echo-cancel>
" is missing in the list of modules (I checked by first writingpacmd
in terminal, followed bylist-modules
). According to this ArchWiki page, it means that I need to create this module by writing in the terminal:
/etc/pulse/default.pa.d/noise-cancellation.pa
Now I'm perfectly able to enter/etc/pulse/
. But once I try to opendefault.pa
ordefault.pa.d
, I get this error message in the terminal:No such file or directory
. This error is hindering me from creating the module I need to increase signal/noise ratio for my microphone. How do I get past this obstacle? Thanks!
inxi -Faz
Kernel: 5.10.88-2-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8d05eb79-30ef-4c21-92f0-c8c7c8baee18 rw [email protected]
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire A315-56 v: V1.15
Mobo: IL model: Sleepy_IL v: V1.15 serial: <superuser required>
UEFI: Insyde v: 1.15 date: 07/13/2020
ID-1: BAT1 charge: 41.5 Wh (100.0%) condition: 41.5/47.8 Wh (86.9%)
volts: 11.9 min: 11.2 model: LGC AP18C8K type: Li-ion serial: N/A
status: Full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA6
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3302 high: 3404 min/max: 400/3400 scaling:
driver: intel_pstate governor: performance cores: 1: 3288 2: 3117 3: 3404
4: 3401 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 0408:a061 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.88-2-lts running: yes
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 4000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lite-On driver: ath10k_pci v: kernel bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 04ca:3015 class-ID: e001
address: <filter>
Local Storage: total: 238.47 GiB used: 152.04 GiB (63.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ1 size: 238.47 GiB block-size: physical: 512 B
rev: E8FK12.3 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
used: 152.04 GiB (63.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.56 GiB used: 915.2 MiB (11.8%)
System Temperatures: cpu: 64.0 C mobo: N/A
Processes: 317 Uptime: 7d 7h 39m wakeups: 81 Memory: 7.56 GiB
used: 3.76 GiB (49.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1873 lib: 441 Shell: Bash
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
