Kernel: 5.16.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: root=LABEL=linux rootflags=subvol=/@ rw add_efi_memmap quiet
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
mitigations=off sysrq_always_enabled=1
initrd=\@\boot\initramfs-linux-zen.img
Console: pty pts/0 wm: kwin_wayland DM: SDDM Distro: Garuda Linux
Type: Laptop System: MONSTER product: ABRA A7 V13.1 v: N/A serial: <filter>
Chassis: type: 10 serial: N/A
Mobo: MONSTER model: ABRA A7 V13.1 serial: N/A UEFI: INSYDE
v: 1.07.02TFB2 date: 05/11/2021
ID-1: BAT0 charge: 37.5 Wh (100.0%) condition: 37.5/40.1 Wh (93.5%)
volts: 16.4 min: 14.6 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
Info: model: 11th Gen Intel Core i5-11400H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x2C
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1268 high: 4033 min/max: 800/4500 base/boost: 2574/4500
scaling: driver: intel_pstate governor: performance volts: 0.7 V
ext-clock: 100 MHz cores: 1: 801 2: 4033 3: 1113 4: 801 5: 800 6: 1425
7: 801 8: 960 9: 1599 10: 800 11: 1294 12: 800 bogomips: 64512
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a68 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] driver: nvidia
v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0300
Device-3: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04f2:b729 class-ID: fe01 serial: <filter>
Display: server: X.Org 1.21.1.4 compositor: kwin_wayland driver:
loaded: modesetting,nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 144 dpi: 128
size: 380x220mm (15.0x8.7") diag: 439mm (17.3")
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.3.5
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Sound Server-1: ALSA v: k5.16.7-zen1-1-zen running: yes
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 129.88 GiB (27.2%)
model: MZVL2512HCJQ-00B00 size: 476.94 GiB block-size: physical: 512 B
rev: GXA7301Q temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 6d 12h cycles: 479
read-units: 9,188,537 [4.70 TB] written-units: 7,027,698 [3.59 TB]
ID-1: / raw-size: 150 GiB size: 150 GiB (100.00%) used: 129.72 GiB (86.5%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
used: 161.2 MiB (15.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 150 GiB size: 150 GiB (100.00%)
used: 129.72 GiB (86.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 150 GiB size: 150 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 150 GiB size: 150 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 15.41 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 365 Uptime: 27m wakeups: 2 Memory: 15.41 GiB
used: 3.19 GiB (20.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1627 lib: 478
inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-01-25
Last full system update: 2022-02-10
Windows dual boot: Yes
I use KDE Dragonized gaming. After a system update, the close/maximize/minimize on top bar have a different theme. This happens only if the window is maximized. I tried restoring all configs to default, didn't worked. Tried restoring a snapshot and the problem was gone. I updated the system and the problem is back.
Here is the list of packages that got updated:
[2022-02-10T19:46:00+0300] [ALPM] upgraded systemd-libs (250.3-2 -> 250.3-4)
[2022-02-10T19:46:00+0300] [ALPM] upgraded bbswitch-dkms (0.8-482 -> 0.8-483)
[2022-02-10T19:46:01+0300] [ALPM] upgraded xkeyboard-config (2.34-1 -> 2.35.1-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded xorg-server-common (21.1.3-1 -> 21.1.3-2)
[2022-02-10T19:46:01+0300] [ALPM] upgraded systemd (250.3-2 -> 250.3-4)
[2022-02-10T19:46:01+0300] [ALPM] upgraded xorg-server (21.1.3-1 -> 21.1.3-2)
[2022-02-10T19:46:01+0300] [ALPM] upgraded qt5-declarative (5.15.2+kde+r45-1 -> 5.15.2+kde+r46-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded qt5-wayland (5.15.2+kde+r48-1 -> 5.15.2+kde+r49-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded gstreamer (1.18.5-1 -> 1.20.0-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded gst-plugins-base-libs (1.18.5-1 -> 1.20.0-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded pango (1:1.50.3-1 -> 1:1.50.4-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded gst-plugins-base (1.18.5-1 -> 1.20.0-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded upower (0.99.14-1 -> 0.99.15-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded bluedevil (1:5.23.5-1 -> 1:5.24.0-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded lib32-lcms2 (2.12-1 -> 2.13.1-1)
[2022-02-10T19:46:01+0300] [ALPM] upgraded gst-libav (1.18.5-1 -> 1.20.0-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded wine-tkg-staging-fsync-git (7.1.r8.g54850aa1-326 -> 7.1.r12.gb5193cb7-326)
[2022-02-10T19:46:02+0300] [ALPM-SCRIPTLET] Remember to export WINEESYNC=1 to use Esync or WINEFSYNC=1 to use Fsync/Futex2
[2022-02-10T19:46:02+0300] [ALPM] upgraded webkit2gtk (2.34.4-1 -> 2.34.5-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded python-idna (3.3-3 -> 3.3-4)
[2022-02-10T19:46:02+0300] [ALPM] upgraded bottles (2022.1.28-6 -> 2022.1.28-8)
[2022-02-10T19:46:02+0300] [ALPM] upgraded kdecoration (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded breeze (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded candy-icons-git (r768.45719cd-1 -> r772.168538b-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded dxvk-mingw-git (1.9.4.r6.g2673d742-1 -> 1.9.4.r13.g939040b1-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded firedragon (96.0.3-2 -> 97.0-1)
[2022-02-10T19:46:02+0300] [ALPM-SCRIPTLET] To use profile-sync-daemon add firedragon to ~/.config/psd/psd.conf
[2022-02-10T19:46:02+0300] [ALPM-SCRIPTLET] If you prefer strict hardened settings execute 'cp /usr/lib/firedragon/firedragon.overrides.cfg ~/.firedragon/'
[2022-02-10T19:46:02+0300] [ALPM] upgraded freeglut (3.2.1-2 -> 3.2.2-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded libarchive (3.5.2-3 -> 3.5.3-2)
[2022-02-10T19:46:02+0300] [ALPM] upgraded libksysguard (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded ksystemstats (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded kactivitymanagerd (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded kde-cli-tools (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded milou (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:02+0300] [ALPM] upgraded layer-shell-qt (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded kscreenlocker (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded kwayland-server (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded kwin (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded plasma-integration (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded libkscreen (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded plasma-workspace (5.23.5-2 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded kdeplasma-addons (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded systemsettings (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded kmenuedit (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:03+0300] [ALPM] upgraded polkit-kde-agent (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded plasma-desktop (5.23.5-2 -> 5.24.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded garuda-dr460nized (1.5.15-1 -> 1.5.16-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded gst-plugins-bad-libs (1.18.5-5 -> 1.20.0-1)
[2022-02-10T19:46:04+0300] [ALPM] installed libltc (1.3.1-3)
[2022-02-10T19:46:04+0300] [ALPM] installed libopenmpt (0.6.1-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded gst-plugins-bad (1.18.5-5 -> 1.20.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded gst-plugins-good (1.18.5-2 -> 1.20.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded gst-plugins-ugly (1.18.5-2 -> 1.20.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded gstreamer-vaapi (1.18.5-1 -> 1.20.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded intel-ucode (20210608-1 -> 20220207-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded kde-gtk-config (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded khotkeys (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded kinfocenter (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded kscreen (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded kwallet-pam (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded kwayland-integration (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded kwin-effects-sliding-notifications (1.1.0-1 -> 1.2.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded lib32-pango (1:1.50.3-1 -> 1:1.50.4-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded mkinitcpio-busybox (1.34.1-1 -> 1.35.0-1)
[2022-02-10T19:46:04+0300] [ALPM] upgraded linux-zen (5.16.7.zen1-1 -> 5.16.8.zen1-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded linux-zen-headers (5.16.7.zen1-1 -> 5.16.8.zen1-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-browser-integration (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-disks (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-firewall (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-nm (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-pa (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-systemmonitor (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-thunderbolt (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-vault (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded plasma-wayland-session (5.23.5-2 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded powerdevil (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded protontricks-git (1.7.0.r6.g70470a9-1 -> 1.7.0.r11.g13d152e-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded resvg (0.20.0-1 -> 0.20.0-3)
[2022-02-10T19:46:06+0300] [ALPM] upgraded sddm-kcm (5.23.5-1 -> 5.24.0-1)
[2022-02-10T19:46:06+0300] [ALPM] upgraded spdlog (1.9.2-2 -> 1.9.2-3)
[2022-02-10T19:46:06+0300] [ALPM] upgraded systemd-sysvcompat (250.3-2 -> 250.3-4)
[2022-02-10T19:46:06+0300] [ALPM] upgraded xdg-desktop-portal-kde (5.23.5-1 -> 5.24.0-1)
