Workspaces not showing on latté
Hello Every one,
Am am using the latest version with KDE 5, global theme = Sweetified Plasma; window decorations = sweet-dark
i can however not see my work-spaces on the latté.
Please help
Many thanks.
Can you provide your
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: left blanked on purpose (BOP)
Type: Laptop System: Micro-Star product: CX72 7QL v: REV:1.0
serial: Chassis: type: 10 serial:
Mobo: Micro-Star model: MS-1797 v: REV:1.0 serial:
UEFI-[Legacy]: American Megatrends v: E1797IMS.508 date: 03/21/2017
ID-1: (BOP)
status: N/A
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xEA
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 650 high: 800 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 601 3: 800 4: 800
bogomips: 23199
Vulnerabilities: (BOP)
Device-1: Intel HD Graphics 620 vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:134d class-ID: 0302
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3360x1080 s-dpi: 96 s-size: 886x285mm (34.9x11.2")
s-diag: 931mm (36.6")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128
size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
Monitor-2: HDMI-1 res: 1440x900 hz: 60 dpi: 90
size: 408x255mm (16.1x10.0") diag: 481mm (18.9")
Device-1: Intel Sunrise Point-LP HD Audio vendor: Micro-Star MSI
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: (BOP) driver: (BOP)
v: kernel bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp2s0 state: up mac:
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus-ID: 03:00.0
chip-ID: 1969:10a1 class-ID: 0200
IF: enp3s0 state: down mac:
Device-1: I**(BOP)** type: USB driver: btusb v: 0.8
bus-ID: 1-5:2 chip-ID: 8087:0aa7 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 1.36 TiB used: 35.42 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: rev: A3U0
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO M.2 500GB
type: SSD serial: rev: 1B6Q scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 35.42 GiB (7.6%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.39 GiB used: 0 KiB (0.0%) priority: 100
dev: (BOP)
System Temperatures: cpu: 66.0 C pch: 48.0 C mobo: 27.8 C
Processes: 257 Uptime: 1h 0m wakeups: 3 Memory: 23.4 GiB
used: 5.57 GiB (23.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1740 pacman: 1729 lib: 382 flatpak: 0
snap: 11 Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.4-1):
System install date: 2022-01-10
Last full system update: 2022-02-02
Windows dual boot:
first of all you need to update your system
Latte configuration doesn’t come by default with a widget like Activity Pager. I think those widgets are those creating most of troubles to latte, and if I remember correctly some of them was even deprecated, probably virtual desktop bar.
I think you’d better use the keybindings like here
"like here..." "here " is not highlighted. Thanks.
