My headphone not getting detected and it is showing unplugged in configure audio devices. When I select Headphones(Unplugged) then sound coming from both speakers and headphones. Please help
System: Kernel: 5.11.6-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=6f60393a-d359-4c85-87ad-8e23807c17d6
rw rootflags=subvol=@ quiet rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop Mobo: BIOSTAR model: H61MLC v: 6.0 serial: <filter> BIOS: American Megatrends
v: 4.6.4 date: 06/09/2011
CPU: Info: Dual Core model: Intel Core i3-2100 bits: 64 type: MT MCP arch: Sandy Bridge family: 6
model-id: 2A (42) stepping: 7 microcode: 2F L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 24742
Speed: 2435 MHz min/max: 1600/3100 MHz Core speeds (MHz): 1: 2435 2: 1637 3: 1899 4: 2664
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Biostar Microtech Intl Corp driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0102
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: VGA1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1) v: 3.3 Mesa 20.3.4 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: Biostar Microtech Intl Corp driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20 class ID: 0403
Sound Server: ALSA v: k5.11.6-zen1-1-zen
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Biostar Microtech Intl Corp
driver: r8169 v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8136 class ID: 0200
Drives: Local Storage: total: 465.76 GiB used: 8.76 GiB (1.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500414CS size: 465.76 GiB block size:
physical: 512 B logical: 512 B speed: <unknown> rotation: 5900 rpm serial: <filter> rev: CA14
scheme: MBR
Partition: ID-1: / raw size: 186.28 GiB size: 186.28 GiB (100.00%) used: 8.76 GiB (4.7%) fs: btrfs
dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw size: 186.28 GiB size: 186.28 GiB (100.00%) used: 8.76 GiB (4.7%) fs: btrfs
ID-3: /var/log raw size: 186.28 GiB size: 186.28 GiB (100.00%) used: 8.76 GiB (4.7%) fs: btrfs
ID-4: /var/tmp raw size: 186.28 GiB size: 186.28 GiB (100.00%) used: 8.76 GiB (4.7%) fs: btrfs
ID-1: swap-1 type: zram size: 959.6 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 959.6 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 959.6 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 959.6 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A
Info: Processes: 213 Uptime: 12m wakeups: 135 Memory: 3.75 GiB used: 2.61 GiB (69.5%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1209 lib: 302 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.3.01
Edit your post, please!
If you include terminal outputs in your post please use the proper output format in your post. Using β~β 3 times above and β~β 3 times below the text block will provide a readable, raw look.
Read
