Hello.
when i was using opensuse with kde plasma i used desktop themes like gently which have transparent windows. (https://images.pling.com/img/00/00/49/90/47/1293160/aa68ea1bc577c068c7d25857b5b8c9601ab70fa2fbf854a2e3fecdb69464d52ce2c8.jpg )
i install those themes in garuda but there's no transparency.
whats going on? how can i enable it? i see i can change transparency on individual windows manually so i suppose the dependencies are installed.
ty.
Can you provide your inxi -Faz please?
Also your screen shoot has nothing to do with firedragon?
tbg
16 January 2022 17:14
#3
Is your compositor running?
filo
16 January 2022 19:30
#4
Have you tried to play around with the "translucency" in the desktop effects?
SGS
16 January 2022 19:37
#5
@tbg @filo @SGS
thank you for answering. I labelled the topic as firedragon by accident. I'm sorry.
Here's my inxi -Faz output. I wanted to upload a pic but I can't because I'm new. Still the problem is that all the transparencies shown in the pic I loaded are absent in my computer.
Thank you.
λ inxi -Faz
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=7827330e-2ebc-4c54-b595-5fd702fe4502 rw [email protected]
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Server System: BESSTAR TECH LIMITED product: X400 v: N/A
Mobo: BESSTAR TECH model: ATB15 serial: <superuser required>
UEFI: American Megatrends v: ATB15016 date: 09/23/2021
Info: model: AMD Ryzen 5 PRO 4650G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3141 high: 4296 min/max: 1400/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2994 2: 2921
3: 3604 4: 3239 5: 2908 6: 2974 7: 4296 8: 2956 9: 2966 10: 2994 11: 2917
12: 2932 bogomips: 88633
Device-1: AMD Renoir driver: amdgpu v: kernel bus-ID: 05:00.0
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.0x11.3") diag: 584mm (23")
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.0-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.4 direct render: Yes
v: kernel bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Conexant Systems
driver: snd_hda_intel v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
driver: r8169 v: kernel port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168
driver: r8169 v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 3-1:2 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 0 state: down
bt-service: disabled rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 238.47 GiB used: 28 GiB (11.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3256B-A01
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFK0S03
temp: 40.9 C scheme: GPT
ID-1: / raw-size: 154.8 GiB size: 154.8 GiB (100.00%)
used: 27.98 GiB (18.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 25.6 MiB (26.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 154.8 GiB size: 154.8 GiB (100.00%)
ID-4: /var/log raw-size: 154.8 GiB size: 154.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 154.8 GiB size: 154.8 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.61 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 24.0 C
Processes: 352 Uptime: 54m wakeups: 0 Memory: 13.61 GiB
used: 4.43 GiB (32.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1931 lib: 565 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
filo
17 January 2022 23:03
#7
Have you tried also to disable blur background in desktop effects?
yes. it was disabled orginally but the system stays the same whether i disable or enable it.
i tried this, so i assume it is?
[email protected] in ~ took 93ms
λ glxinfo | grep '^direct rendering:'
direct rendering: Yes
[email protected] in ~ took 89ms
λ
filo
18 January 2022 15:18
#10
You can open System Settings and search for compositor.
In general you can toggle it on and off with alt+shift+f12, but in the compositor screen you can also play with the relevant settings.
Additionally, if it crashed, it shows there an error message (e.g. "OpenGL compositing (the default) has crashed KWin in the past..."), and if so you can reset the protection / acknowledge it.
filo
18 January 2022 15:53
#11
I have another idea, but consider that I'm not using your "gently" theme, and this stuff is theme dependent.
I never played around with transparency in the past.
With the standard "sweetified plasma" theme I think I managed to get to something similar to your expectations:
Removing the "inactive blur" wallpaper plugin. As far as I know this can be done only manually removing a folder like mentioned here
unflagging/deactivating Blur in the Desktop Effects
In addition to that, it might be necessary (again depending on what you have in your system) to find a suitable GTK Application style (in Appearence / Application Style) that foresees transparency. Tis is not the case for the standard "Sweet-Dark".
thank you, @filo
I have solved it.
I went into Desktop Effects and tried modifying the transparency settings in there. Transparency wasn't even actually activated. I apologize. I remember that stuff configured itself automatically when you activated a theme... but it seems that it doesn't now?
So I activated it and modified the settings in there... still feel like the themes don't look as they should somehow... but, oh well.
Thank you.
Naman
18 January 2022 18:07
#15
I have now moved this thread to #4xx:precondition-failed as OP should have tried this prior to posting.
system
closed
20 January 2022 18:08
#17
