Hello,
I am having a very strange issue.
Whenever I turn on my second monitor and extend my desktop to it Latte-dock gets broken and needs to be killed and started again. Additionally to this some of my windows are getting broken for example the one responsible for Password prompt when I need to do something with root privileges doesn't render correctly at all.
I noticed this is happening only when I extend my desktop to a second monitor if I boot my laptop to a single display output all seems to be fine.
Additionally to this the close, minimize and maximize buttons to my windows are being rendered to my panel instead of my windows as I have configured them.
If I press Alt + F3 the menu for the configuration also is not rendered properly and it doesn't display any names just icons.
My garuda-inxi output is :
garuda-inx
parameters: BOOT_IMAGE=/@_backup_20220309001323181/boot/vmlinuz-linux-zen
root=UUID=bd24341e-38b9-4ca0-8b3e-fa78da82f50f rw
rootflags=subvol=@_backup_20220309001323181 quiet quiet splash
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: HP product: HP EliteBook 1050 G1 v: N/A
Mobo: HP model: 84E9 v: KBC Version 16.4D.00 serial: <superuser required>
UEFI: HP v: Q72 Ver. 01.17.00 date: 08/05/2021
ID-1: BAT0 charge: 72.3 Wh (98.8%) condition: 73.2/96.4 Wh (76.0%)
volts: 12.3 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 87
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1008 high: 2200 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 2200 8: 900 9: 900 10: 900 11: 900 12: 900
bogomips: 52799
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-5
empty: DP-3,DP-4,HDMI-A-4 bus-ID: 01:00.0 chip-ID: 10de:1c8d
Device-3: Chicony HP HD Camera type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 04f2:b5e7 class-ID: 0e02 serial: <filter>
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: DP-5 mapped: DP-1-0.1 note: disabled model: Dell P2419H
serial: <filter> built: 2020 res: N/A dpi: 93 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: primary model: InfoVision Optronics/Kunshan 0x061c
built: 2017 res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2
modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 3-1.2:3 chip-ID: 047f:02ee
class-ID: 0300 serial: <filter> chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
Device-3: Plantronics BT600 type: USB
driver: plantronics,snd-usb-audio,usbhid
Device-4: HP USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-1.3.5:8 chip-ID: 03f0:0269 class-ID: 0300 serial: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 4-1.3.3:4 chip-ID: 0bda:8153 class-ID: 0000
IF: enp10s0u1u3u3 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 506.05 GiB used: 368.43 GiB (72.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: AAHA4102
temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk
model: Cruzer Switch size: 29.11 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.27 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 368.43 GiB
(77.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 368.43
GiB (77.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 368.43
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 368.43
ID-1: swap-1 type: zram size: 30.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C pch: 61.0 C mobo: N/A
Processes: 351 Uptime: 2m wakeups: 1 Memory: 30.7 GiB used: 5.86 GiB
(19.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1841
libs: 507 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.8-1):
System install date: 2022-06-11
Last full system update: 2022-10-17
