Window buttons widget does not work
Window Buttons widget do not work anymore, instead displays this
file:///usr/share/plasma/plasmoids/org.kde.windowbuttons/contents/ui/main.qml:23:1: Cannot load library /usr/lib/qt6/qml/org/kde/appletdecoration/libappletdecorationplugin.so: libkdecorations3private.so.1: cannot open shared object file: No such file or directory
Kernel: 6.13.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=9ea88397-2120-46de-ae29-17ea00c118fc rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: FX505DT.316
date: 01/28/2021
ID-1: BAT0 charge: 27.3 Wh (98.2%) condition: 27.8/48.1 Wh (57.9%)
volts: 12.0 min: 11.7 model: FX50442 type: Li-ion serial: N/A
status: not charging
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1226 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1226 2: 1226 3: 1226
4: 1226 5: 1226 6: 1226 7: 1226 8: 1226 bogomips: 33535
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91
Device-2: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 55.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:56a2
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Najing CEC Panda 0x002d built: 2018 res:
max: 1920x1080 min: 640x480
drv: nvidia device: 1 drv: radeonsi gbm: drv: kms_swrast surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 19.1.7 DRM 3.60 6.13.4-zen1-1-zen)
device-ID: 1002:15d8 memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15d8
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: N/A device-ID: 10de:1f91
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.4-zen1-1-zen status: kernel-api with: aoss
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 13d3:3530
Local Storage: total: 476.94 GiB used: 34.65 GiB (7.3%)
model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
fw-rev: P1MA0V4 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 85.31 GiB size: 85.31 GiB (100.00%)
used: 34.62 GiB (40.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 32.4 MiB (12.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 85.31 GiB size: 85.31 GiB (100.00%)
ID-4: /var/log raw-size: 85.31 GiB size: 85.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 85.31 GiB size: 85.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.2 GiB used: 546.7 MiB (7.4%) priority: 100
System Temperatures: cpu: 54.1 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): cpu: 2400
Memory: total: 8 GiB note: est. available: 7.2 GiB used: 5.82 GiB (80.9%)
Processes: 293 Power: uptime: 34m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.81 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1398 libs: 413 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date:     2025-01-11
Last full system update: 2025-02-28
Take a look here:
