Window buttons applet broke with KDE 5.24
EDIT : Sorry my bad for not trying to research more about it before posting?
Could someone at least give a solution so as to keep/preserve window decorations around maximized windows? I am not going to use the Breeze window decorations, but still need to close windows that are maximized.
Current behaviour is hiding the window decorations from maximized apps.
The title.
The applet no more has custom decorations available, only shows Current and Breeze as options.
Not a fan of Breeze decorations.
╰─ inxi -Faz
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2e41d0ad-de12-458a-acbc-0d038037b38c rw rootflags=subvol=@
cryptdevice=UUID=c2083ab5-e739-4b3e-af73-4c63321909c4:luks-c2083ab5-e739-
root=/dev/mapper/luks-c2083ab5-e739-4b3e-af73-4c63321909c4 quiet
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
modprobe.blacklist=nouveau
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401II_GA401II
Mobo: ASUSTeK model: GA401II v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GA401II.219 date: 12/30/2020
ID-1: BAT0 charge: 58.5 Wh (79.1%) condition: 74.0/76.0 Wh (97.4%)
volts: 15.8 min: 15.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: Not charging
Info: model: AMD Ryzen 5 4600HS with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96)
stepping: 1 microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1464 high: 1980 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1567
3: 1400 4: 1405 5: 1441 6: 1397 7: 1397 8: 1395 9: 1397 10: 1396
11: 1397 12: 1980 bogomips: 71869
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 158
size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL:
renderer: AMD RENOIR (DRM 3.44.0 5.16.8-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 5-4:3 chip-ID: 8087:0029 class-ID: e001
address: <filter>
Local Storage: total: 953.87 GiB used: 135.58 GiB (14.2%)
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
temp: 30.9 C scheme: GPT
used: 135.58 GiB (14.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c2083ab5-e739-4b3e-af73-4c63321909c4
ID-1: swap-1 type: zram size: 15.11 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 350 Uptime: 37m wakeups: 2 Memory: 15.11 GiB
used: 3.25 GiB (21.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1398 lib: 358 Shell: Zsh
v: 5.8 running-in: konsole inxi: 3.3.12
This is known issue with many topics here in the forum and also a bug has been filed on Dec 6th on github to the Window Applet.
Sorry I don't have the links yet, but I'm sure someone will post them before I can get them back.
EDIT: Actually here you go :slight_smile: Wrong theme on Latte title buttons
Redundantly, redundant, search the forum before posting people.
How many of these threads already? I'm losing count.
