hello computer people! so yesterday i decided to try out linux (garuda) for the first time. my problem is that everytime i try to connect to wifi, the process cancels after like 1min and it just says the connection is deactivated. i would be very happy if someone could help me. i can also provide additional information if needed ![]()
Start with garuda-inxi and follow this time the template you just ignored and deleted.
Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
ok so since im not connected to wifi on my desktop, the best i can do is a picture of my screen but as i just found out i am not allowed yet to post images in this forum. so no inxi possible i guess. + i already tried finding a solution for my problem but it didnt work yet. thanks for the help though
Did you try or can you use tethering, but it works for 1 min. ![]()
Please no pictures from terminal and system settings.
Images can be read worse, are not searchable and copyable for further search.
unfortunately not (cant connect a cable) im in a bad place it seems.
Pictures consumes considerably more data volume then text. Connect the phone to the PC and copy the terminal text to it.
Y
You have no USB C or A cable?
How do you charge your smartphone battery?
i am still working on transfering the .txt on my iphone as in being able to actually send it to you
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1730 high: 3892 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 3892
3: 1550 4: 1550 5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1375 11: 1550
12: 1550 bogomips: 81438
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: gather_data_sampling status: Not affected
Type: spec_rstack_overflow mitigation: safe RET
took me a minute to find out i have a usb stick hahha this should be it right?
There are many specs missing.
It mus look like this one
ok could you tell me the exact command i need to put in? im not acting dumb btw
terminal
or use garuda-assistant
root=UUID=7ee43a5b-f160-4bd5-b32c-f44356e752c4 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3803
date: 01/22/2018
Speed (MHz): avg: 2027 high: 3892 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 2800
3: 1454 4: 1550 5: 1550 6: 1550 7: 3892 8: 3779 9: 1557 10: 1550 11: 1550
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: DP-2 empty: DP-1, DVI-D-1, HDMI-A-1, HDMI-A-2
bus-ID: 09:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 52.0 C
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Samsung C27JG5x
serial: <filter> built: 2020 res: 2560x1440 hz: 144 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (polaris10
LLVM 16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:67df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:aaf0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: Focusrite-Novation Scarlett Solo (3rd Gen.)
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-1:2 chip-ID: 1235:8211 class-ID: 0102 serial: <filter>
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Device-2: TP-Link [] driver: rtw_8822bu type: USB rev: 2.1 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 2357:0138 class-ID: 0000
IF: wlp2s0f0u2 state: down mac: <filter>
Local Storage: total: 2.07 TiB used: 4.09 GiB (0.2%)
fw-rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
model: WD10JPCX-24UE4T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: Ultra size: 28.64 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
used: 4.09 GiB (0.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 50.6 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 795
Processes: 296 Uptime: 1h 54m wakeups: 3 Memory: total: 32 GiB
available: 31.27 GiB used: 14.21 GiB (45.5%) Init: systemd v: 254
pm: pacman pkgs: 1187 libs: 351 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2024-04-06
Last full system update: 2024-04-06
Search for the wifi driver in forum.
im pretty sure i already have the right driver but i couldnt find a way to execute the setup to install it if that makes sense. so how do i actually get the driver to work?
BannedPatriot commented on 2021-07-12 20:17 (UTC)
@sethox, I’ve patched an updated driver. This package is orphaned, you can install AUR (en) - rtl8822bu-dkms instead, which includes my patch.
Seems you must wait for our Network specialists.
im crazy confused i cant load the patch bc the file types cant be copied to my usb drive so i cant load it on my desktop. also i dont know how to convert them back to their original form after making them a txt file. so yeeeaah i might be a bit too stupid for linux it appears.
Whats the responce for
journalctl -u NetworkManager | grep wifi
You could try install nmcli with ethernet on
and use it like
nmcli connection modify <Your Wifie> autoconnect no
maybe even restart your NetworkManager
systemctl restart NetworkManager
nmcli radio wifi off
nmcli radio wifi on
I mean, this are just a bunch of commands I would have tried.
- my wifi adapter seems to work a little bit because it can find all the wifis in my area it just struggles to actually connect
thanks a lot im gonna try these
In my opinion you should try this driver:
sudo pacman -S rtl88x2bu-dkms-git
Afterwards blacklist your current module:
echo "blacklist rtw88_8822bu" | sudo tee /etc/modprobe.d/rtw8822bu.conf
And reboot.
If that doesn’t work, delete /etc/modprobe.d/rtw8822bu.conf and remove the package:
sudo pacman -R rtl88x2bu-dkms-git
If rtl88x2bu-dkms-git is not found (maybe removed from Chaotic-AUR)
paru rtl88x2bu-dkms-git
Exit from the PKGBUILD preview with button q and confirm installation.
