WiFi drops out after trying to pull a webpage
Greetings,
I've recently updated my system and now WiFi won't stay connected.
Upon reboot/restarting wifi I can ping in and outside of my network but seconds after I try to access a website via browser or perform an update it completely drops out and I'm unable to ping anywhere to include within my own network via wifi. Everything is ok when using a wired connection. I've tried to re-install the driver and performed a few updates but to no avail.
I'm using a TP-Link AC1300 which isn't officially supported so I used these forums to learn how to get the driver installed - It has been great until now.
Any help would be greatly appreciated!!
Here is my networking info:
10: PCI 200.0: 0200 Ethernet controller
[Created at pci.386]
Unique ID: c3qJ.5rbhBgx50x4
Parent ID: QSNP.xpwxxKVOE11
SysFS ID: /devices/pci0000:00/0000:00:1c.4/0000:02:00.0
SysFS BusID: 0000:02:00.0
Hardware Class: network
Model: "Gigabyte Onboard Ethernet"
Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
Device: pci 0x8168 "RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
SubVendor: pci 0x1458 "Gigabyte Technology Co., Ltd"
SubDevice: pci 0xe000 "Onboard Ethernet"
Revision: 0x06
Driver: "r8169"
Driver Modules: "r8169"
Device File: enp2s0
I/O Ports: 0xd000-0xd0ff (rw)
Memory Range: 0xf0904000-0xf0904fff (ro,non-prefetchable)
Memory Range: 0xf0900000-0xf0903fff (ro,non-prefetchable)
IRQ: 16 (125593 events)
HW Address: 94:de:80:c3:6d:39
Permanent HW Address: 94:de:80:c3:6d:39
Link detected: yes
Module Alias: "pci:v000010ECd00008168sv00001458sd0000E000bc02sc00i00"
Driver Info #0:
Driver Status: r8169 is active
Driver Activation Cmd: "modprobe r8169"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #21 (PCI bridge)
25: USB 00.0: 0282 WLAN controller
[Created at usb.122]
Unique ID: XEU_.lZ_Y4IrY7j6
Parent ID: dwDZ.cR3kNpdgj73
SysFS ID: /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0
SysFS BusID: 1-1.3.3:1.0
Model: "TP-Link Archer T3U [Realtek RTL8812BU]"
Hotplug: USB
Vendor: usb 0x2357 "TP-Link"
Device: usb 0x012d "Archer T3U [Realtek RTL8812BU]"
Revision: "2.10"
Serial ID: "123456"
Driver: "rtw_8822bu"
Driver Modules: "rtw88_8822bu"
Device File: wlp0s26u1u3u3
Features: WLAN
Speed: 480 Mbps
HW Address: 42:d4:99:99:8b:1b
Permanent HW Address: c0:06:c3:5f:fb:24
Link detected: no
WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136
WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472 2.484 5.18 5.2 5.22 5.24 5.26 5.28 5.3 5.32 5.5 5.52 5.54 5.56 5.58 5.6 5.62 5.64 5.66 5.68
WLAN encryption modes: WEP40 WEP104 TKIP CCMP
WLAN authentication modes: open sharedkey wpa-psk wpa-eap
Module Alias: "usb:v2357p012Dd0210dc00dsc00dp00icFFiscFFipFFin00"
Driver Info #0:
Driver Status: rtw88_8822bu is active
Driver Activation Cmd: "modprobe rtw88_8822bu"
Driver Info #1:
Driver Status: 88x2bu is active
Driver Activation Cmd: "modprobe 88x2bu"
Attached to: #39 (Hub)
26: USB 00.0: 11500 Bluetooth Device
Unique ID: GrY4.nQKjiuCfL84
Parent ID: CiZ2.ugLqxniY9o7
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.1/3-3.1:1.0
SysFS BusID: 3-3.1:1.0
Hardware Class: bluetooth
Model: "Cambridge Silicon Radio Bluetooth Dongle (HCI mode)"
Hotplug: USB
Vendor: usb 0x0a12 "Cambridge Silicon Radio, Ltd"
Device: usb 0x0001 "Bluetooth Dongle (HCI mode)"
Revision: "88.91"
Driver: "btusb"
Driver Modules: "btusb"
Speed: 12 Mbps
Module Alias: "usb:v0A12p0001d8891dcE0dsc01dp01icE0isc01ip01in00"
Driver Info #0:
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
Attached to: #24 (Hub)
Here is my inxi:
λ garuda-inxi
Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=4e3c2a30-eb1c-4688-91a4-70a209ad6f81 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: B75M-D3H v: x.x serial: <superuser required>
BIOS: American Megatrends v: F15 date: 10/23/2013
Device-2: hidpp_battery_1 model: Logitech MX Keys Wireless Keyboard
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 built: 2012-15 process: Intel 22nm family: 6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3001 high: 3893 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3891 2: 2652 3: 1790
4: 3892 5: 2070 6: 1977 7: 3893 8: 3848 bogomips: 54273
Type: l1tf
Device-1: AMD Bonaire XT [Radeon HD 7790/8770 / R7 360 R9 260/360 OEM]
vendor: ASUSTeK driver: radeon v: kernel alternate: amdgpu arch: GCN 2
process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 2 speed: 5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1,DVI-I-1 bus-ID: 01:00.0
chip-ID: 1002:665c class-ID: 0300
alternate: fbdev,vesa gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 3640x1920 s-dpi: 96 s-size: 963x508mm (37.91x20.00")
s-diag: 1089mm (42.87")
Monitor-1: DVI-D-1 mapped: DVI-0 pos: primary,top-left model: HP V27i
serial: <filter> built: 2021 res: 1080x1920 hz: 60 dpi: 82 gamma: 1.2
size: 336x598mm (13.23x23.54") diag: 686mm (27") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-0 pos: primary,bottom-r
model: LG (GoldStar) 32GK850G serial: <filter> built: 2014 res: 2560x1440
hz: 60 dpi: 109 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 801mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
OpenGL: renderer: AMD BONAIRE (LLVM 13.0.1 DRM 2.50 5.18.6-zen1-1-zen)
v: 4.5 Mesa 22.1.2 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
Device-2: AMD Tobago HDMI Audio [Radeon R7 360 / R9 OEM]
vendor: ASUSTeK R7260X-DC2OC-2GD5 driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 1002:aac0 class-ID: 0403
Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
Device-2: TP-Link Archer T3U [Realtek RTL8812BU] type: USB
driver: rtw_8822bu bus-ID: 1-1.3.3:5 chip-ID: 2357:012d class-ID: 0000
IF: wlp0s26u1u3u3 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-3.1:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 931.51 GiB used: 161.17 GiB (17.3%)
ID-1: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
used: 161.17 GiB (17.3%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.57 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A gpu: radeon temp: 55.0 C
Processes: 284 Uptime: 19m wakeups: 4 Memory: 15.57 GiB
used: 3.2 GiB (20.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1491
lib: 364 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.19
Garuda (2.6.4-2):
System install date:     2022-03-04
Last full system update: 2022-06-25 ↻
If this started after a recent update, the first thing I would try would be some other kernels like LTS, mainline, or hardened in case a kernel bug is to blame (especially with a less-supported network card).
I don’t think it will help here, but with KDE you should reboot after updates.
@BluishHumility, Thanks! I've been meaning to teach myself how to use other kernels anyway so I'll give that a shot. It is weird that it has worked with no problems since I started using garuda and now has the issue.
@SGS, Thanks for your reply; I've reset a few times since and only updated today because I saw that you can update with 'sudo update' instead of 'sudo garuda-update' and wanted to try it out lol.
No need of sudo for update and garuda-update :wink:
If you are using a proprietary Realtek driver from the AUR or Chaotic AUR the driver sometimes requires rebuilding after a kernel update.
