Wifi stopped working after dual booting Ubuntu (Realtek RTL8852AE)
After installing Ubuntu 20.04 in another parition, these happened:
- Grub was automatically installed on Ubuntu and Garuda was not detected in grub menu (maybe bcz of btrfs)
- I booted into a live session and ran
grub-update
on Garuda bychroot
. I was able to boot into Garuda (but detected as "Arch"). Grub log was displayed instead of Garuda's boot animation. - Wifi stopped working from there on Garuda. But it is working in Ubuntu.
- I tried changing the kernel to
linux-arch
as well as reinstallingrtw89-dkms-git
(which was the driver before 5.16 kernel) from Chaotic-aur but no changes to wifi.
The wifi is working fine in following distros which I checked
- Ubuntu 20.04 with Linux 5.13 HWE (Dual Boot)
- Fedora 36 with Linux 5.17 (Live Boot)
Output of garuda-inxi
Kernel: 5.18.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=0b40ffff-2556-4233-b187-8d1002ad5f86 rw rootflags=subvol=@
loglevel=3 quiet
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: HP product: HP Pavilion Laptop 14-ec0xxx v: N/A
Mobo: HP model: 88F1 v: 82.34 serial: <superuser required> UEFI: AMI
v: F.07 date: 08/18/2021
ID-1: BAT0 charge: 39.5 Wh (99.5%) condition: 39.7/39.7 Wh (100.0%)
volts: 13.0 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: N/A cycles: 225
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1396 high: 1401 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1397 2: 1395
3: 1401 4: 1397 5: 1397 6: 1392 7: 1397 8: 1396 9: 1397 10: 1398 11: 1397
12: 1397 bogomips: 50303
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
Device-2: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 0408:5425 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x06f0 built: 2021
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.9-zen1-1-zen)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.18.9-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.54 running: yes
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8852
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-1:2 chip-ID: 0bda:8153 class-ID: 0000
IF: enp4s0f3u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-4:4 chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 173.37 GiB (36.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: HPS1
temp: 32.9 C scheme: GPT
ID-1: / raw-size: 198.47 GiB size: 198.47 GiB (100.00%)
used: 81.78 GiB (41.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 529.3 MiB size: 528.3 MiB (99.80%)
used: 6.1 MiB (1.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 198.47 GiB size: 198.47 GiB (100.00%)
ID-4: /var/log raw-size: 198.47 GiB size: 198.47 GiB (100.00%)
ID-5: /var/tmp raw-size: 198.47 GiB size: 198.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.96 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 1.95 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 345 Uptime: 9m wakeups: 184 Memory: 14.96 GiB
used: 2.91 GiB (19.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 2272
lib: 477 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: kitty
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-01-05
Last full system update: 2022-07-08
