let me check the kernel website maybe they have another newer driver for it . D… that is mad i thought it help you out.it worked on my older laptop this way.
what you get out of this in the terminal lspci -k?
they are the newest on the kernel tree for your devices they have to work normally but maybe the older driver is better like @tbg say. we have to find the loaded driver then you can try the older too load correctly.
Here it is
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
Subsystem: Lenovo Device 2238
Kernel driver in use: skl_uncore
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07)
Kernel driver in use: i915
Kernel modules: i915
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:13.0 Non-VGA unclassified device: Intel Corporation Sunrise Point-LP Integrated Sensor Hub (rev 21)
Kernel driver in use: intel_ish_ipc
Kernel modules: intel_ish_ipc
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
Kernel modules: mei_me
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
Kernel driver in use: pcieport
00:1c.2 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #3 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_soc_avs
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection I219-LM (rev 21)
Subsystem: Lenovo Device 2233
Kernel driver in use: e1000e
Kernel modules: e1000e
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader (rev 01)
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
04:00.0 Network controller: Intel Corporation Wireless 8260 (rev 3a)
Subsystem: Intel Corporation Device 0130
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
05:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM951/PM951 (rev 01)
Subsystem: Samsung Electronics Co Ltd PM963 2.5" NVMe PCIe SSD
Kernel driver in use: nvme
Kernel modules: nvme
I’m really sorry but it’s very complicated to post or reply with a connection that drops every 3 or 4 minutes.
My laptop is almost unusable…
If you have a cellular phone with a data plan use USB phone tethering to get an internet connection.
Please do so, it is pretty much the first thing to try if your wifi dies.
Please post the output of:
sudo dmesg | grep -Ei 'error|fail|firm|deauth|qos|crda|regdom|cfg80211|alpha2|wl|blue' | grep -viE 'acpi|ras|nvidia|eth'
Try disabling ipv6 in your network ? Through kde settings and router settings.
Here it is
╭─jacques@jacques in ~
╰─λ sudo dmesg | grep -Ei 'error|fail|firm|deauth|qos|crda|regdom|cfg80211|alpha2|wl|blue' | grep -viE 'acpi|ras|nvidia|eth'
[sudo] Mot de passe de jacques :
[ 0.759254] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 1.963240] usb 1-2: device descriptor read/64, error -71
[ 3.974495] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.088661] iwlwifi 0000:04:00.0: enabling device (0000 -> 0002)
[ 4.125148] iwlwifi 0000:04:00.0: Detected crf-id 0xbadcafe, cnv-id 0x3000000 wfpm id 0x80000000
[ 4.125279] iwlwifi 0000:04:00.0: PCI dev 24f3/0130, rev=0x201, rfid=0xd55555d5
[ 4.146032] iwlwifi 0000:04:00.0: loaded firmware version 36.ca7b901d.0 8000C-36.ucode op_mode iwlmvm
[ 4.209841] Bluetooth: Core ver 2.22
[ 4.209868] NET: Registered PF_BLUETOOTH protocol family
[ 4.209870] Bluetooth: HCI device and connection manager initialized
[ 4.209874] Bluetooth: HCI socket layer initialized
[ 4.209876] Bluetooth: L2CAP socket layer initialized
[ 4.209881] Bluetooth: SCO socket layer initialized
[ 4.851712] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[ 4.865754] iwlwifi 0000:04:00.0: Detected Intel(R) Dual Band Wireless AC 8260, REV=0x201
[ 4.867457] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 4.897507] Bluetooth: hci0: Firmware revision 0.0 build 14 week 44 2021
[ 4.900498] Bluetooth: hci0: Reading supported features failed (-16)
[ 4.900504] Bluetooth: hci0: Error reading debug features
[ 4.900506] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[ 4.959512] iwlwifi 0000:04:00.0: base HW address: a4:34:d9:d6:52:13, OTP minor version: 0x4
[ 5.043297] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 5.146331] iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0
[ 5.560480] psmouse serio2: trackpoint: IBM TrackPoint firmware: 0x0e, buttons: 3/3
[ 6.336479] Bluetooth: BNEP filters: protocol multicast
[ 6.336483] Bluetooth: BNEP socket layer initialized
[ 6.337544] Bluetooth: MGMT ver 1.22
[ 6.990249] iwlwifi 0000:04:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
[ 18.278721] wlp4s0: authenticate with 6a:b4:f7:86:3f:1a (local address=a4:34:d9:d6:52:13)
[ 18.279985] wlp4s0: send auth to 6a:b4:f7:86:3f:1a (try 1/3)
[ 18.301574] wlp4s0: authenticated
[ 18.302066] wlp4s0: associate with 6a:b4:f7:86:3f:1a (try 1/3)
[ 18.349022] wlp4s0: RX AssocResp from 6a:b4:f7:86:3f:1a (capab=0x1431 status=0 aid=1)
[ 18.353262] wlp4s0: associated
[ 18.979963] Bluetooth: RFCOMM TTY layer initialized
[ 18.979972] Bluetooth: RFCOMM socket layer initialized
[ 18.979976] Bluetooth: RFCOMM ver 1.11
╭─jacques@jacques in ~ as 🧙 took 4s
╰─λ
And yes i tried with the lts kernel and the problem is still the same…
Disabling IPV6 didn’t change anything…
I was quite surprised by your dmsg log being so clean. Your wifi is initializing correctly with no obvious problems according to your log.
There is a USB error that you should look into (totally unrelated to your wifi).
Open a new terminal window and run the command given below. This will create a live log output of Network Manager’s current activities. Try to connect to various websites over your wifi connection during the live session.
journalctl -u NetworkManager -f
Open a separate terminal window and try pinging various websites via both their domain name and IP address. Post a selection of 25 -50 errors generated during your Network Manager live log session. Hopefully this will help identify your issue.
Does the same issue occur in a Garuda live environment created from a current ISO image?
Here’s the response…
╰─λ journalctl -u NetworkManager -f
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.7665] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.7666] dhcp4 (wlp4s0): state changed no lease
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.7668] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.7671] device (wlp4s0): ip:dhcp6: restarting
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.7672] dhcp6 (wlp4s0): canceled DHCP transaction
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.7673] dhcp6 (wlp4s0): state changed no lease
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.7674] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.7677] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.8094] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63, acd pending
mai 26 18:38:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716741537.8097] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63
^C⏎
╭─jacques@jacques in ~ took 6m19s
[🧱] × journalctl -u NetworkManager -f
mai 26 18:50:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742256.4824] device (wlp4s0): supplicant interface state: completed -> disconnected
mai 26 18:50:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742256.4824] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
mai 26 18:50:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742256.5771] device (wlp4s0): supplicant interface state: disconnected -> scanning
mai 26 18:50:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742256.5772] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.7312] device (wlp4s0): supplicant interface state: scanning -> authenticating
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.7312] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.7414] device (wlp4s0): supplicant interface state: authenticating -> associating
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.7414] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.7651] device (wlp4s0): supplicant interface state: associating -> associated
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.7652] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.7811] device (wlp4s0): supplicant interface state: associated ->4way_handshake
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.7812] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8235] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8244] device (wlp4s0): ip:dhcp4: restarting
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8245] dhcp4 (wlp4s0): canceled DHCP transaction
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8246] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8246] dhcp4 (wlp4s0): state changed no lease
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8248] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8251] device (wlp4s0): ip:dhcp6: restarting
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8259] dhcp6 (wlp4s0): canceled DHCP transaction
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8260] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8260] dhcp6 (wlp4s0): state changed no lease
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8261] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8264] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8623] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63, acd pending
mai 26 18:50:57 jacques-20frs08u00 NetworkManager[695]: <info> [1716742257.8629] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.0044] device (wlp4s0): supplicant interface state: completed -> disconnected
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.0044] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.1044] device (wlp4s0): supplicant interface state: disconnected -> scanning
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.1045] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3010] device (wlp4s0): supplicant interface state: scanning -> authenticating
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3012] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3116] device (wlp4s0): supplicant interface state: authenticating -> associating
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3118] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3443] device (wlp4s0): supplicant interface state: associating -> associated
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3444] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3637] device (wlp4s0): supplicant interface state: associated ->4way_handshake
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3639] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3715] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3722] device (wlp4s0): ip:dhcp4: restarting
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3723] dhcp4 (wlp4s0): canceled DHCP transaction
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3724] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3724] dhcp4 (wlp4s0): state changed no lease
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3726] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3729] device (wlp4s0): ip:dhcp6: restarting
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3730] dhcp6 (wlp4s0): canceled DHCP transaction
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3731] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3731] dhcp6 (wlp4s0): state changed no lease
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3735] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.3738] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.4269] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63, acd pending
mai 26 18:52:11 jacques-20frs08u00 NetworkManager[695]: <info> [1716742331.4271] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63
mai 26 18:53:58 jacques-20frs08u00 NetworkManager[695]: <info> [1716742438.5779] device (wlp4s0): supplicant interface state: completed -> authenticating
mai 26 18:53:58 jacques-20frs08u00 NetworkManager[695]: <info> [1716742438.5779] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> authenticating
mai 26 18:53:58 jacques-20frs08u00 NetworkManager[695]: <info> [1716742438.6275] device (wlp4s0): supplicant interface state: authenticating -> disconnected
mai 26 18:53:58 jacques-20frs08u00 NetworkManager[695]: <info> [1716742438.6276] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> disconnected
mai 26 18:53:58 jacques-20frs08u00 NetworkManager[695]: <info> [1716742438.6926] device (wlp4s0): supplicant interface state: disconnected -> scanning
mai 26 18:53:58 jacques-20frs08u00 NetworkManager[695]: <info> [1716742438.6927] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.1523] device (wlp4s0): supplicant interface state: scanning -> authenticating
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.1523] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.2700] device (wlp4s0): supplicant interface state: authenticating -> associating
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.2701] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3098] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3099] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3499] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3506] device (wlp4s0): ip:dhcp4: restarting
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3507] dhcp4 (wlp4s0): canceled DHCP transaction
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3508] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3508] dhcp4 (wlp4s0): state changed no lease
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3510] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3513] device (wlp4s0): ip:dhcp6: restarting
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3514] dhcp6 (wlp4s0): canceled DHCP transaction
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3514] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3515] dhcp6 (wlp4s0): state changed no lease
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3516] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.3518] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.4120] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63, acd pending
mai 26 18:54:00 jacques-20frs08u00 NetworkManager[695]: <info> [1716742440.4128] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.6682] device (wlp4s0): supplicant interface state: completed -> authenticating
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.6684] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> authenticating
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7160] device (wlp4s0): supplicant interface state: authenticating -> associating
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7161] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7176] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7176] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7287] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7307] device (wlp4s0): ip:dhcp4: restarting
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7315] dhcp4 (wlp4s0): canceled DHCP transaction
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7316] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7316] dhcp4 (wlp4s0): state changed no lease
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7317] dhcp4 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7319] device (wlp4s0): ip:dhcp6: restarting
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7319] dhcp6 (wlp4s0): canceled DHCP transaction
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7320] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7320] dhcp6 (wlp4s0): state changed no lease
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7321] dhcp6 (wlp4s0): activation: beginning transaction (timeoutin 45 seconds)
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7322] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7819] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63, acd pending
mai 26 18:54:56 jacques-20frs08u00 NetworkManager[695]: <info> [1716742496.7821] dhcp4 (wlp4s0): state changed new lease, address=172.22.22.63
^C⏎
Here are some ping tests
╭─jacques@jacques in ~ took 8m9s
[🧱] × ping www.polyte.ch
PING polyte.ch (80.74.144.35) 56(84) octets de données.
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=1 ttl=53 temps=19.7 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=2 ttl=53 temps=20.6 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=3 ttl=53 temps=20.9 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=4 ttl=53 temps=16.8 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=5 ttl=53 temps=17.6 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=6 ttl=53 temps=18.4 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=7 ttl=53 temps=16.4 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=8 ttl=53 temps=23.0 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=9 ttl=53 temps=17.9 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=10 ttl=53 temps=18.9 ms
64 octets de mars.kreativmedia.ch (80.74.144.35) : icmp_seq=11 ttl=53 temps=18.1 ms
^C
--- statistiques ping polyte.ch ---
11 paquets transmis, 11 reçus, 0% packet loss, time 10017ms
rtt min/avg/max/mdev = 16.426/18.946/23.030/1.877 ms
╭─jacques@jacques in ~ took 10s
╰─λ ping www.facebook.com
PING star-mini.c10r.facebook.com (157.240.17.35) 56(84) octets de données.
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=1 ttl=53 temps=30.7 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=2 ttl=53 temps=22.7 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=3 ttl=53 temps=17.9 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=4 ttl=53 temps=16.1 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=5 ttl=53 temps=19.6 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=6 ttl=53 temps=19.6 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=7 ttl=53 temps=18.1 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=8 ttl=53 temps=21.8 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=9 ttl=53 temps=20.1 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=10 ttl=53 temps=21.5 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=11 ttl=53 temps=17.4 ms
64 octets de edge-star-mini-shv-01-zrh1.facebook.com (157.240.17.35) : icmp_seq=12 ttl=53 temps=18.4 ms
^C
--- statistiques ping star-mini.c10r.facebook.com ---
12 paquets transmis, 12 reçus, 0% packet loss, time 11017ms
rtt min/avg/max/mdev = 16.089/20.329/30.713/3.641 ms
╭─jacques@jacques in ~ took 11s
╰─λ ping www.fieldclimate.com/
ping: www.fieldclimate.com/: Nom ou service inconnu
╭─jacques@jacques in ~ took 3ms
[🔴] × ping www.fieldclimate.com
PING www.fieldclimate.com (80.122.185.11) 56(84) octets de données.
64 octets de 80.122.185.11 : icmp_seq=1 ttl=54 temps=55.7 ms
64 octets de 80.122.185.11 : icmp_seq=2 ttl=54 temps=53.7 ms
64 octets de 80.122.185.11 : icmp_seq=3 ttl=54 temps=49.3 ms
64 octets de 80.122.185.11 : icmp_seq=4 ttl=54 temps=48.2 ms
64 octets de 80.122.185.11 : icmp_seq=5 ttl=54 temps=49.0 ms
64 octets de 80.122.185.11 : icmp_seq=6 ttl=54 temps=47.4 ms
64 octets de 80.122.185.11 : icmp_seq=7 ttl=54 temps=52.3 ms
64 octets de 80.122.185.11 : icmp_seq=8 ttl=54 temps=49.9 ms
64 octets de 80.122.185.11 : icmp_seq=9 ttl=54 temps=49.0 ms
64 octets de 80.122.185.11 : icmp_seq=10 ttl=54 temps=54.8 ms
^C
--- statistiques ping www.fieldclimate.com ---
10 paquets transmis, 10 reçus, 0% packet loss, time 9012ms
rtt min/avg/max/mdev = 47.431/50.938/55.663/2.782 ms
╭─jacques@jacques in ~ took 9s
╰─λ
May be more relevant…
No smoking gun there, but often it helps to disable wifi power saving and also disable mac address randomization.
So sad… ![]()
How can i check those two settings ?
Very busy ATM, I’m sure you can figure it out by a quick search of the Arch Wiki.
I tried to disable the mac address like that
nano /etc/NetworkManager/NetworkManager.conf
And adding this in the file
[device]
wifi.scan-rand-mac-address=no
But with no luck again ![]()
Edit : had to go back because it’s getting worse…
Have to check how to disable wifi power saving… Bit more complicated for me…
How long have you had this issue on this installation? Always, or did it initially work fine?
Does the issue persist if you connect to another network?
Have you tried restarting your router?
This is a not so old installation.
The problem came two weeks ago, may be just after the update to KDE6.
Yep i tried several different networks, and the problem is still there.
And yep i tried restarting the router several times…
A bit lost…
Create a config file like this:
micro /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Paste this inside:
[connection]
wifi.powersave = 2
Reboot, and test again. ![]()
Are you using a VPN? If so, be sure to disable the VPN for troubleshooting purposes.
You should definitely try setting a static IP address via your router, or via Network manager, (or both). The IP address you assign needs to be an IP address on the correct subnet with the appropriate subnet mask. The Arch Wiki contains plenty of network configuration information, see:
https://wiki.archlinux.org/title/Network_configuration#Network_management
https://wiki.archlinux.org/title/Network_configuration#Static_IP_address
https://wiki.archlinux.org/title/NetworkManager
This information can also easily be found with a general internet search using terms such as:
How do I find out my Linux gateway / router IP Address?
How to find netmask and gateway in Linux?
How to configure a static IP address in Linux?
Check your router’s documentation for how to enter your router’s management console. Many routers allow setting a static IP address via MAC address association. Different router manufacturers may use different terms for this. As we do not know your exact router model, you will need to familiarize yourself with how to accomplish this. It’s usually a fairly simple procedure to assign a static IP address through most router’s configuration utilities. Setting a static IP address via MAC address association also has the added benefit of providing an extra security layer to your home network.
Give that a go, and best of luck.
Tried it too, but with no luck again ![]()
