WiFi not working (RTL8723BE)
Wifi is not working since the first installation of Garuda.
I tried to build driver rtlwifi_new repo, but that seems to be deprecated and doesn't work on new kernels versions.
And, Here I found that certain wifi drivers support are provided on kernel side, and RTL8723BE falls under that list.
I'm unable to find any proper solution for this.
Some assistance will be highly appreciated :slight_smile:
╰─λ rfkill list
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
[🔴] × inxi -Fxxxza
System:    Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=55e42994-0093-4206-876f-ddc3c21fb95d
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: HP model: 81EC v: 61.59 serial: <filter> UEFI: Insyde v: F.48 date: 12/17/2019
Battery:   ID-1: BAT1 charge: 29.4 Wh (100.0%) condition: 29.4/41.6 Wh (70.6%) volts: 16.7 min: 14.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Full
CPU:       Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake family: 6
model-id: 4E (78) stepping: 3 microcode: E2 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19200
Speed: 2703 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 2703 2: 2658 3: 2700 4: 2700
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo bus-ID: 1-5:6 chip-ID: 04f2:b50d
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: ati,intel,radeon
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.1.0 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169
v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: N/A
modules: rtl8723be port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
IF-ID-1: enp0s20f0u3 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth: Device-1: Xiaomi Mi/Redmi series (RNDIS + ADB) type: USB driver: rndis_host v: kernel
bus-ID: 1-3:7 chip-ID: 2717:ff88 class-ID: 0a00 serial: <filter>
Device-2: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:5
chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no
software: yes address: <filter>
Drives:    Local Storage: total: 1.13 TiB used: 67.28 GiB (5.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: R013
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: RSM4 scheme: MBR
Partition: ID-1: / raw-size: 84.71 GiB size: 84.71 GiB (100.00%) used: 22.18 GiB (26.2%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 55.9 MiB (58.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 84.71 GiB size: 84.71 GiB (100.00%) used: 22.18 GiB (26.2%) fs: btrfs
ID-4: /var/log raw-size: 84.71 GiB size: 84.71 GiB (100.00%) used: 22.18 GiB (26.2%) fs: btrfs
ID-5: /var/tmp raw-size: 84.71 GiB size: 84.71 GiB (100.00%) used: 22.18 GiB (26.2%) fs: btrfs
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors:   System Temperatures: cpu: 51.5 C mobo: 29.8 C gpu: radeon temp: 52.0 C
Info:      Processes: 214 Uptime: 31m wakeups: 1 Memory: 7.66 GiB used: 3.87 GiB (50.5%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1986 lib: 385
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
:slight_smile:
Does that mean your wifi was working on the live boot disk?
Have you tested other kernels yet? I would start with the LTS kernel.
Have you read the Arch Wiki entry regarding your adapter?
Are you dual booting with Windows?
Is your bios up to date?
If you have tried all the above with no luck then power down your system and remove the battery and power plug.
Plug the laptop back into AC power outlet. Do not put the laptop battery back yet. Restart the laptop and then reset your bios back to the factory default.
There has been no response from the OP in over a month. The thread is now deemed abandoned. I am locking the thread.
If the OP wishes the thread reopened please PM a mod other than myself as I am currently not accepting PM's.
