Kernel: 6.4.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c9fed118-d15b-463b-9235-1015372679a1 rw rootflags=subvol=@
resume=UUID=a8a7931a-d6f4-48db-b826-e07bb1369396 loglevel=3 ibt=off
Type: Laptop System: Dell product: Inspiron 5505 v: 1.5.4
serial: <superuser required> Chassis: type: 10 v: 1.5.4
Mobo: Dell model: 0YX59Y v: A01 serial: <superuser required> UEFI: Dell
v: 1.5.4 date: 06/10/2021
ID-1: BAT0 charge: 30.5 Wh (100.0%) condition: 30.5/39.8 Wh (76.7%)
volts: 12.5 min: 11.2 model: SWD-ATL3.560 DELL 5NDNH11 type: Li-poly
serial: <filter> status: full
Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
microcode: 0x8600104
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 3011 high: 3993 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1397 2: 3271
3: 3993 4: 1576 5: 3840 6: 3993 bogomips: 28448
Device-1: AMD Renoir vendor: Dell driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 66.0 C
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 0bda:565a
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x097d built: 2020
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.4-zen1-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Dell
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
API: ALSA v: k6.4.4-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
IF-ID-1: enp3s0f3u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
driver: rndis_host v: kernel type: USB rev: 2.1 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-1:7 chip-ID: 04e8:6864 class-ID: 0a00 serial: <filter>
Device-2: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:4 chip-ID: 0cf3:e007
Report: ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 242.19 GiB used: 57.39 GiB (23.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 256GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 11004101 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Generic model: SD MMC MS PRO
size: 3.72 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1.00
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 57.39 GiB (25.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.13 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: 40.0 C gpu: amdgpu temp: 67.0 C
Fan Speeds (RPM): cpu: 3586
Processes: 267 Uptime: 11m wakeups: 399 Memory: total: 8 GiB note: est.
available: 7.13 GiB used: 2.91 GiB (40.8%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1951 libs: 537 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-07-20
Last full system update: 2023-07-24
Hello all,
I've been having the most frustrating issue I've ever experienced when using linux since I switched over to Garuda. I really don't wanna distro hop again but it seems unique to this distribution as it never happened before and I only just made the switch.
The the issue is that every now and then, garuda seems to just 'switch off' my laptop's network card. It refuses to locate and connect to any networks and when looking through the arch wiki I tried the steps to manually reconnect at the terminal but when I did an ip link it returned the info that my wifi card was down. Attempting to set it to up resulted in a Timed Out error.
The happened once more 2 days ago but after tearing my hair out and restarting my machine 9 seperate times and trying multiple different potential fixes, the wifi just suddenly started working again with no indication as to how.
I've tried everything I tried back then and more now, it's been 16 restarts and more repeated attempts of the same methods than I care to admit and it still isn't even detecting the myriad of networks around me...
Any help in this issue would be greatly appreciated,
- Nova
