tag
29 November 2022 12:32
#1
Hello Garuda users.
please point me in the right direction here.
Installed garuda , this time ona new laptop -best install experience so far - and its looking nicer than ever -good job on Octopi!!
After 3 days its working as I need, but today after unplugging the network cable and moving to another part of the house, all the wifi connections that were already saved - and viewable in configuration tab - have disappeared.
I moved back to the ethernet connection, yet the wifi still doesnt come back ?
─[email protected] in ~ took 4ms
╰─λ garuda-inxi
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=16cd540c-8d12-402c-ac97-5bae937a0268 rw [email protected]
resume=UUID=0afd44b9-bcaa-4e95-9336-c5fa7bc4f5a9 loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: ASUSTeK product: ROG Strix G713RW_G713RW v: 1.0
Mobo: ASUSTeK model: G713RW v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713RW.314 date: 04/19/2022
ID-1: BAT0 charge: 37.6 Wh (41.0%) condition: 91.8/90.0 Wh (102.0%)
volts: 14.5 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1878 high: 3300 min/max: 1600/4934 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1372 2: 1376
3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600
12: 1600 13: 1403 14: 3300 15: 3300 16: 3300 bogomips: 105400
Device-1: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24a0 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 05:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 56.0 C
s-diag: 777mm (30.58")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a69 built: 2021
res: 2560x1440 hz: 240 dpi: 171 gamma: 1.2 size: 381x214mm (15x8.43")
diag: 437mm (17.2") ratio: 16:9 modes: max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Graphics (rembrandt
LLVM 14.0.6 DRM 3.48 6.0.10-zen2-1-zen) direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_pci_acp6x v: kernel
alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Device-2: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 14c3:7922
Local Storage: total: 953.87 GiB used: 42.88 GiB (4.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK
lanes: 4 type: SSD serial: <filter> rev: V5MA010 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 919.89 GiB size: 919.89 GiB (100.00%)
used: 42.88 GiB (4.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 919.89 GiB size: 919.89 GiB (100.00%)
ID-4: /var/log raw-size: 919.89 GiB size: 919.89 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.89 GiB size: 919.89 GiB (100.00%)
ID-1: swap-1 type: partition size: 33.68 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 30.62 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 63.5 C mobo: N/A gpu: amdgpu temp: 58.0 C
Fan Speeds (RPM): cpu: 0
Processes: 347 Uptime: 1m wakeups: 4 Memory: 30.62 GiB used: 2.15 GiB (7.0%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1414 libs: 441 tools: octopi,paru
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-25
Last full system update: 2022-11-29
I have updated and rebooted.
Please can someone run a quick eye over this and maybe point me in the right direction...is it garauda or do I have a hardware issue?
Thankyou
c00ter
29 November 2022 15:59
#2
Have you tried other kernels such as linux-lts (and headers)?
tbg
29 November 2022 19:00
#3
Do you have the most recent bios update installed?
Are you dual booting Windows?
Was your wifi working without issues prior to your most recent update?
If you recently updated and your wifi broke afterwards an update may have caused this. As your posted inxi output indicates you recently updated, you need to check on which packages were recently updated. Network related packages, and kernel or firmware updates are the most likely to cause new problems. You can view the list of updates in Garuda Assistant. Pease post the list of your most recent updates.
Unfortunately, it could be the fact that you are using an adapter that is known to have many issues when using Linux. The
mt7921e
driver is rather new and it is still having many teething issues. Unfortunately all the bugs have yet to be worked out with the mt7921e
driver.
A search of the forum will reveal many reported problems with this wifi adapter:
https://forum.garudalinux.org/search?q=mt7921e%20wifi%20asus
Your wifi properties are not being reported in your inxi output correctly. This would point to an issue with the kernel, or your bios/firmware.
Be sure to test at least three alternate kernels including the LTS & mainline.
You may also want to test the linux-frmware-git
package for any improvements.
tag
29 November 2022 19:07
#4
Hi thanks for your reply, much appreciated.
I had read the numerous posts about this problem and this was suggested and in some cases brings success, but I find this rather drastic.
I have more info to add.
this time I shut the laptop down. Then removed network cable. Then moved location. Then started laptop - wifi is now visible at boot.
I changed nothing -this is an order of input/disconnect issue and someone with intimate knowledge of garuda may be able to use this, i hope
This fits with other users posts re this issue.
tag
29 November 2022 19:19
#5
BIOS - I have just DL , not yet installed
Not dual booting.
Yes. Its been working without issue from first boot.
I had read those threads and i just felt the issue was something simple rather than being complicated.....and then I stumbled across the workaround.
I will update the BIOS and test some more....but the work around , if its proves 100% to work, will do for now.
If the issue persists I will try some of the other kernels.
Also I just noted during this issue - the Bluetooth module becomes unavailable - it has also returned with the wifi.
tbg
29 November 2022 19:31
#6
Yes I noticed the absent bluetooth as well on your inxi output. I would make a bios backup and save it to a drive. That way your customized bios settings can be restored quickly after an update, (or if you lose your wifi again). If you lose your wifi/ Bluetooth again and have problems getting it back I would recommend the following:
Reboot
Reset your bios to the factory default settings.
Restore your bios settings from the backup you made.
tag
29 November 2022 21:16
#7
Thought to run inxi again as BT and wifi are working -compare the difference
╭─[email protected] in
╰─λ garuda-inxi
ID-1: BAT0 charge: 72.0 Wh (82.0%) condition: 87.8/90.0 Wh (97.5%)
volts: 15.7 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
Speed (MHz): avg: 1680 high: 3300 min/max: 1600/4934 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3300 2: 1600
12: 1600 13: 1397 14: 1600 15: 1397 16: 1600 bogomips: 105400
class-ID: 0300 temp: 32.0 C
class-ID: 0480
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 13d3:3568 class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 41.36 GiB (4.3%)
lanes: 4 type: SSD serial: <filter> rev: V5MA010 temp: 22.9 C scheme: GPT
used: 41.36 GiB (4.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 38.4 C mobo: N/A gpu: amdgpu temp: 34.0 C
Processes: 416 Uptime: 5h 4m wakeups: 22 Memory: 30.62 GiB
used: 3.89 GiB (12.7%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1416
libs: 442 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
tbg
1 December 2022 11:17
#8
On another thread I noticed this post of yours:
I have just set-up a laptop with garuda for the first time, before only with PC, and 100% this is a bug for laptops.
If you power on with the ethernet connected it works , but if you then disconnect and move , sometimes you will not see any wifi OR Bluetooth connections - to fix I have to power down , re-connect the ethernet and reboot - and hey presto wifi and bluetooth return.
Seems like the eth0 and wifi are fighting over address space or something?
If you feel that your wifi and Ethernet are conflicting, you may want to try setting different static IP addresses for each adapter. This may help avoid conflicts.
You could also try disabling your Ethernet in your bios when you are not using it. Unfortunately not all bios have this feature.
system
Closed
15 December 2022 11:18
#9
