I have been facing this issue for a long time. Sometimes the wifi connection automatically stops and whenever I try to turn on and off the wifi from the wifi-icon the system lags for a minute. Only after the restart the wifi starts working again.
Kernel: 6.4.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=55b51a8b-341a-4d9f-ae00-5aea74479e9b rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: Dell product: Inspiron 5570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0YDF7T v: X06 serial: <filter> UEFI: Dell v: 1.14.0
date: 04/06/2023
ID-1: BAT0 charge: 33.3 Wh (85.2%) condition: 39.1/42.0 Wh (93.1%)
volts: 12.2 min: 11.4 model: Samsung SDI DELL CYMGM68 type: Li-ion
Info: model: Intel Core i7-8550U socket: U3E1 bits: 64 type: MT MCP
arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xF2
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1505 high: 2000 min/max: 400/4000 base/boost: 3300/1800
scaling: driver: intel_pstate governor: powersave volts: 1.1 V
ext-clock: 100 MHz cores: 1: 1200 2: 2000 3: 2000 4: 1042 5: 900 6: 2000
7: 2000 8: 900 bogomips: 31999
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile] vendor: Dell driver: amdgpu v: kernel arch: GCN-3
code: Volcanic Islands process: TSMC 28nm built: 2014-19 pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 1002:6900 class-ID: 0380 temp: 60.0 C
Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
chip-ID: 1bcf:28c1 class-ID: 0e02
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: LG Display 0x04a7 built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
API: ALSA v: k6.4.6-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.75 status: n/a (root, process) with:
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 0cf3:e009
address: <filter>
Local Storage: total: 1.38 TiB used: 205.42 GiB (14.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: AITC FZKM SSD 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2107XKR temp: 39.9 C
SMART: yes health: PASSED on: 222d 5h cycles: 2,844
read-units: 35,758,604 [18.3 TB] written-units: 59,547,803 [30.4 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: SDM3 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 307d 23h cycles: 8204
read: 39.73 TiB written: 28.02 TiB Old-Age: g-sense error rate: 472
Pre-Fail: reallocated sector: 99 threshold: 36 attribute: Spin_Retry_Count
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 47.25 GiB (47.3%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 596 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 251.65 GiB size: 251.65 GiB (100.00%)
used: 158.16 GiB (62.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 47.25 GiB (47.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.39 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 68.0 C mobo: 50.0 C sodimm: SODIMM C gpu: amdgpu
temp: 60.0 C
Fan Speeds (RPM): cpu: 3687
Processes: 293 Uptime: 50m wakeups: 43721 Memory: total: 16 GiB
available: 15.39 GiB used: 5.49 GiB (35.7%) igpu: 32 MiB Init: systemd
v: 253 default: graphical tool: systemctl Compilers: gcc: 13.1.1
clang: 15.0.7 Packages: pm: pacman pkgs: 1926 libs: 400 tools: octopi,paru
pm: pkg pkgs: 0 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.28
System install date: 2023-05-24
Last full system update: 2023-07-28 ↻
Windows dual boot: Yes
wifi-status
Every 1.0s: iw wlp3s0 info; ip addr show wlp3s0; ip route; echo; (journalctl -b --no-pager -q... Nops: Fri Jul 28 10:52:29 2023
Interface wlp3s0
ifindex 3
wdev 0x1
addr d4:6a:6a:b9:91:d1
type managed
wiphy 0
txpower 20.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
3: wlp3s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether d4:6a:6a:b9:91:d1 brd ff:ff:ff:ff:ff:ff
inet 192.168.101.12/24 brd 192.168.101.255 scope global dynamic noprefixroute wlp3s0
valid_lft 83503sec preferred_lft 83503sec
inet6 fe80::3868:d175:8422:7f2a/64 scope link tentative noprefixroute
valid_lft forever preferred_lft forever
Jul 28 10:51:28 Nops wpa_supplicant[736]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jul 28 10:51:28 Nops NetworkManager[649]: <info> [1690520788.2973] device (wlp3s0): supplicant interface state: completed -> in
terface_disabled
Jul 28 10:51:28 Nops NetworkManager[649]: <info> [1690520788.2973] device (p2p-dev-wlp3s0): supplicant management interface sta
te: completed -> interface_disabled
Jul 28 10:51:28 Nops avahi-daemon[628]: Withdrawing address record for 2404:7c00:43:7abd:4488:68c8:9d55:cb89 on wlp3s0.
Jul 28 10:51:28 Nops avahi-daemon[628]: Withdrawing address record for 192.168.101.12 on wlp3s0.
Jul 28 10:51:28 Nops avahi-daemon[628]: Leaving mDNS multicast group on interface wlp3s0.IPv6 with address 2404:7c00:43:7abd:448
8:68c8:9d55:cb89.
Jul 28 10:51:28 Nops avahi-daemon[628]: Leaving mDNS multicast group on interface wlp3s0.IPv4 with address 192.168.101.12.
Jul 28 10:51:28 Nops avahi-daemon[628]: Interface wlp3s0.IPv6 no longer relevant for mDNS.
Jul 28 10:51:28 Nops avahi-daemon[628]: Interface wlp3s0.IPv4 no longer relevant for mDNS.
Jul 28 10:51:27 Nops kernel: wlp3s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-5)
dmesg
[ 2856.606864] <TASK>
[ 2856.606865] ? __warn+0x81/0x1b0
[ 2856.606868] ? ieee80211_del_chanctx+0x16d/0x180 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.606920] ? report_bug+0x202/0x270
[ 2856.606923] ? handle_bug+0x3c/0x80
[ 2856.606925] ? exc_invalid_op+0x19/0xc0
[ 2856.606928] ? asm_exc_invalid_op+0x1a/0x20
[ 2856.606930] ? ieee80211_del_chanctx+0x16d/0x180 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.606984] ieee80211_free_chanctx+0x91/0xc0 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607036] __ieee80211_link_release_channel+0xea/0x120 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607089] ieee80211_link_release_channel+0x3f/0x60 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607142] ieee80211_set_disassoc+0x3c8/0x870 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607218] ieee80211_mgd_deauth+0x143/0x680 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607292] cfg80211_mlme_down+0xd0/0x1b0 [cfg80211 de2a093d22c3a330c460ca34834c1e58ca5fed2c]
[ 2856.607344] cfg80211_disconnect+0x180/0x1f0 [cfg80211 de2a093d22c3a330c460ca34834c1e58ca5fed2c]
[ 2856.607393] cfg80211_netdev_notifier_call+0x141/0x4b0 [cfg80211 de2a093d22c3a330c460ca34834c1e58ca5fed2c]
[ 2856.607428] ? vprintk_emit+0x139/0x2d0
[ 2856.607431] ? drv_remove_interface+0x114/0x120 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607470] ? _printk+0x64/0x80
[ 2856.607473] ? __warn+0xc7/0x1b0
[ 2856.607475] ? drv_remove_interface+0x114/0x120 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607513] ? report_bug+0x202/0x270
[ 2856.607515] ? ieee80211_iter_chan_contexts_atomic+0x27/0x80 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607568] ? ath10k_monitor_recalc+0x82/0x680 [ath10k_core af04db4c49d414dac4c3af2718b85aa2c926210e]
[ 2856.607586] ? exc_invalid_op+0x19/0xc0
[ 2856.607589] ? rtnl_is_locked+0x15/0x20
[ 2856.607590] ? inetdev_event+0x3d/0x690
[ 2856.607594] notifier_call_chain.constprop.0+0x51/0xc0
[ 2856.607596] __dev_close_many+0x95/0x180
[ 2856.607598] dev_close_many.constprop.0+0x8d/0x1b0
[ 2856.607601] dev_close+0x7e/0xb0
[ 2856.607603] cfg80211_shutdown_all_interfaces+0x4d/0x300 [cfg80211 de2a093d22c3a330c460ca34834c1e58ca5fed2c]
[ 2856.607638] ieee80211_restart_work+0x120/0x150 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.607675] process_one_work+0x24f/0x460
[ 2856.607679] worker_thread+0x55/0x4f0
[ 2856.607682] ? __pfx_worker_thread+0x10/0x10
[ 2856.607684] kthread+0xe5/0x120
[ 2856.607686] ? __pfx_kthread+0x10/0x10
[ 2856.607688] ret_from_fork+0x29/0x50
[ 2856.607692] </TASK>
[ 2856.607693] ---[ end trace 0000000000000000 ]---
[ 2856.607705] wlp3s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-5)
[ 2856.914664] ------------[ cut here ]------------
[ 2856.914667] WARNING: CPU: 3 PID: 262 at net/mac80211/driver-ops.c:39 drv_stop+0xf5/0x100 [mac80211]
[ 2856.914738] Modules linked in: ccm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm cmac algif_hash algif_skcipher af_alg snd_hda_codec_hdmi qrtr bnep snd_soc_avs snd_soc_hda_codec snd_soc_skl snd_ctl_led snd_soc_hdac_hda snd_hda_ext_core snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match snd_soc_acpi snd_hda_codec_realtek snd_soc_core snd_hda_codec_generic snd_compress ac97_bus joydev snd_pcm_dmaengine mousedev snd_hda_intel ath10k_pci snd_intel_dspcfg uvcvideo snd_intel_sdw_acpi intel_tcc_cooling btusb x86_pkg_temp_thermal videobuf2_vmalloc ath10k_core snd_hda_codec intel_powerclamp btrtl uvc btbcm videobuf2_memops coretemp videobuf2_v4l2 btintel snd_hda_core vfat rtsx_usb_sdmmc fat kvm_intel btmtk ath snd_hwdep hid_multitouch videodev rtsx_usb_ms dell_laptop mmc_core processor_thermal_device_pci_legacy bluetooth mac80211 kvm dell_wmi snd_pcm videobuf2_common iTCO_wdt memstick processor_thermal_device intel_pmc_bxt dell_smbios libarc4 ee1004 iTCO_vendor_support intel_rapl_msr dell_smm_hwmon ecdh_generic
[ 2856.914781] rtsx_usb cdc_acm crc16 mc irqbypass dcdbas processor_thermal_rfim r8169 rapl snd_timer processor_thermal_mbox ledtrig_audio wmi_bmof dell_wmi_descriptor intel_cstate cfg80211 intel_uncore snd i2c_i801 realtek processor_thermal_rapl psmouse intel_lpss_pci mdio_devres soundcore intel_lpss rfkill i2c_smbus libphy intel_rapl_common intel_xhci_usb_role_switch idma64 intel_soc_dts_iosf intel_pch_thermal int3403_thermal intel_hid int3400_thermal int3402_thermal acpi_thermal_rel sparse_keymap int340x_thermal_zone acpi_pad mac_hid fuse loop dm_mod zram ip_tables x_tables amdgpu i915 serio_raw atkbd crct10dif_pclmul crc32_pclmul polyval_clmulni intel_gtt libps2 polyval_generic gf128mul nvme vivaldi_fmap ghash_clmulni_intel drm_ttm_helper sha512_ssse3 drm_suballoc_helper i2c_algo_bit aesni_intel ttm gpu_sched drm_buddy crypto_simd ucsi_acpi nvme_core cryptd typec_ucsi drm_display_helper sr_mod roles cdrom nvme_common xhci_pci i2c_hid_acpi cec xhci_pci_renesas typec i2c_hid i8042 video serio wmi btrfs blake2b_generic
[ 2856.914833] libcrc32c crc32c_generic crc32c_intel xor raid6_pq vmmon(OE) vmw_vmci vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) uinput crypto_user
[ 2856.914841] CPU: 3 PID: 262 Comm: kworker/3:2 Tainted: G W OE 6.4.6-zen1-1-zen #1 ff2ee4dee9e0ab7e56a9c29d9c87555e813db5cb
[ 2856.914844] Hardware name: Dell Inc. Inspiron 5570/0YDF7T, BIOS 1.14.0 04/06/2023
[ 2856.914846] Workqueue: events_freezable ieee80211_restart_work [mac80211]
[ 2856.914883] RIP: 0010:drv_stop+0xf5/0x100 [mac80211]
[ 2856.914921] Code: 0d 00 48 85 c0 74 0c 48 8b 78 08 48 89 de e8 22 0b 06 00 65 ff 0d e3 39 f6 3d 0f 85 39 ff ff ff e8 10 53 93 f4 e9 2f ff ff ff <0f> 0b 5b c3 cc cc cc cc 0f 1f 00 90 90 90 90 90 90 90 90 90 90 90
[ 2856.914923] RSP: 0018:ffffa6bac0fdfcb8 EFLAGS: 00010246
[ 2856.914925] RAX: 0000000000000000 RBX: ffff944221cf08e0 RCX: ffff94420e486668
[ 2856.914927] RDX: 0000000000000000 RSI: 0000000000000282 RDI: ffff944221cf08e0
[ 2856.914928] RBP: ffff944221cf1b10 R08: 0000000000000040 R09: 0000000000000000
[ 2856.914929] R10: 0000000000000010 R11: 0000000000000002 R12: ffff944221cf08e0
[ 2856.914930] R13: 0000000000000000 R14: 0000000000000002 R15: 0000000000000000
[ 2856.914931] FS: 0000000000000000(0000) GS:ffff9445724c0000(0000) knlGS:0000000000000000
[ 2856.914933] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 2856.914934] CR2: 00007f25ece1c898 CR3: 0000000311a20004 CR4: 00000000003706e0
[ 2856.914935] Call Trace:
[ 2856.914937] <TASK>
[ 2856.914939] ? __warn+0x81/0x1b0
[ 2856.914944] ? drv_stop+0xf5/0x100 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.914983] ? report_bug+0x202/0x270
[ 2856.914986] ? handle_bug+0x3c/0x80
[ 2856.914989] ? exc_invalid_op+0x19/0xc0
[ 2856.914992] ? asm_exc_invalid_op+0x1a/0x20
[ 2856.914995] ? drv_stop+0xf5/0x100 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.915033] ? ieee80211_stop_device+0x3b/0x50 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.915086] ieee80211_do_stop+0x71a/0x9f0 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.915132] ieee80211_stop+0x4d/0x180 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.915177] __dev_close_many+0xd1/0x180
[ 2856.915180] dev_close_many.constprop.0+0x8d/0x1b0
[ 2856.915183] dev_close+0x7e/0xb0
[ 2856.915185] cfg80211_shutdown_all_interfaces+0x4d/0x300 [cfg80211 de2a093d22c3a330c460ca34834c1e58ca5fed2c]
[ 2856.915236] ieee80211_restart_work+0x120/0x150 [mac80211 1bfc6131375fc1eec0ed77de8ec7b0b0f986efe0]
[ 2856.915273] process_one_work+0x24f/0x460
[ 2856.915277] worker_thread+0x55/0x4f0
[ 2856.915280] ? __pfx_worker_thread+0x10/0x10
[ 2856.915283] kthread+0xe5/0x120
[ 2856.915285] ? __pfx_kthread+0x10/0x10
[ 2856.915287] ret_from_fork+0x29/0x50
[ 2856.915292] </TASK>
[ 2856.915292] ---[ end trace 0000000000000000 ]---
[ 2860.002473] ath10k_warn: 151 callbacks suppressed
[ 2860.002480] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.034200] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.066105] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.097983] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.129875] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.161693] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.193510] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.225341] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.257114] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2860.288898] ath10k_pci 0000:03:00.0: failed to wake target for read32 at 0x00036044: -110
[ 2862.643437] ath10k_pci 0000:03:00.0: failed to read firmware dump area: -16
[ 2862.643442] ath10k_pci 0000:03:00.0: Copy Engine register dump:
[ 2862.770469] ath10k_pci 0000:03:00.0: [00]: 0x00034400 4294967295 4294967295 4294967295 4294967295
[ 2862.897437] ath10k_pci 0000:03:00.0: [01]: 0x00034800 4294967295 4294967295 4294967295 4294967295
[ 2863.024369] ath10k_pci 0000:03:00.0: [02]: 0x00034c00 4294967295 4294967295 4294967295 4294967295
[ 2863.151765] ath10k_pci 0000:03:00.0: [03]: 0x00035000 4294967295 4294967295 4294967295 4294967295
[ 2863.278864] ath10k_pci 0000:03:00.0: [04]: 0x00035400 4294967295 4294967295 4294967295 4294967295
[ 2863.406429] ath10k_pci 0000:03:00.0: [05]: 0x00035800 4294967295 4294967295 4294967295 4294967295
[ 2863.533977] ath10k_pci 0000:03:00.0: [06]: 0x00035c00 4294967295 4294967295 4294967295 4294967295
[ 2863.660784] ath10k_pci 0000:03:00.0: [07]: 0x00036000 4294967295 4294967295 4294967295 4294967295
