Hello,
So, I have been facing this issue for a while and cannot resolve it. As time goes on it gets even worse, because after clicking WiFi icon internet connection comes back for maybe 5-10 mins without cut offs.
I would gladly appreciate if anyone will be able to help me, since I just couldn't find the solution on the internet and it is starting to mess me up pretty badly on online calls.
I couldn't even find this kind of problem. The ones which I found was
constant disconnect problem, which is not the case for me. It is connected but there is no internet.
For more clearance on latte top bar it shows 0.0B 0.0B or sometimes WiFi icon gets yellow.
Also, I tested my internet on a windows computer I can say that it is not my routers or my internet issue, because there everything worked smoothly. tested it on my phone and same story there.
Before this I had some issues with NetworkManager and this community helped me to resolve it.
Here is the thread: Network manager cannot find any internet connections after sleep phase.
P.S During installation I had some minor(idk internet said so) firmware issues which I solved with this:
Git Clone URL: git clone https://aur.archlinux.org/mkinitcpio-firmware.git
Source: AUR (en) - mkinitcpio-firmware
Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=391fdedd-2184-4168-9f2a-5bb2dcc485b9 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706II_FA706II
Mobo: ASUSTeK model: FA706II v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FA706II.316 date: 03/12/2021
ID-1: BAT1 charge: 40.4 Wh (100.0%) condition: 40.4/48.1 Wh (84.0%)
volts: 12.6 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
Device-1: sony_controller_battery_a4:ae:12:a7:31:ef model: N/A
serial: N/A charge: N/A status: full
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x60 (96) stepping: 1 microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1627 high: 2245 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1397 2: 1469
3: 1575 4: 1397 5: 1710 6: 1397 7: 1399 8: 2112 9: 2245 10: 2027 11: 1396
12: 1403 bogomips: 71859
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: amdgpu
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Samsung C27F390
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0x479d built: 2019
res: 1920x1080 hz: 120 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.3-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel bus-ID: 3-2:6
v: kernel chip-ID: 054c:09cc pcie: gen: 1 class-ID: 0300 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: DekTec Digital Video B.V. driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-5: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: snd-usb-audio,sony,usbhid
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-1:2 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Local Storage: total: 1.38 TiB used: 220.49 GiB (15.7%)
model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
rev: P6MA001 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001
used: 184.71 GiB (38.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.78 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): cpu: 2600
Processes: 331 Uptime: 42m wakeups: 5 Memory: 30.78 GiB
used: 5.6 GiB (18.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1895
pacman: 1882 lib: 545 flatpak: 13 Shell: fish v: 3.4.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.17
Garuda (2.6.3-2):
System install date: 2022-06-17
Last full system update: 2022-06-17
