Hello!
I installed garuda onto a microsoft surface, and it won't discover any wifi networks, and it says bluetooth is unavailable. This happens on the flash drive boot as well as the installed garuda boot. I've googled and couldn't find a working solution, and I haven't touched linux in years so I don't know how to try and fix it
my garuda-inxi:
╭─[email protected] in ~
╰─λ garuda-inxi
root=UUID=ae99ee5a-04a0-465f-98c5-3ace108256e9 rw [email protected]
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: Microsoft product: Surface Book
v: 124000000000000000000000D:0B:08F:1C:03P:38 serial: <superuser required>
Chassis: type: 9 serial: <superuser required>
Mobo: Microsoft model: Surface Book serial: <superuser required>
UEFI: Microsoft v: 92.3748.768 date: 05.04.2021
ID-1: BAT2 charge: 7.9 Wh (19.8%) condition: 39.8/51.0 Wh (78.0%)
volts: 7.1 min: 7.5 model: SMP X906980 type: Li-ion serial: <filter>
status: discharging cycles: 71
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2364 high: 2574 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2000 2: 2385 3: 2500
4: 2574 bogomips: 19999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Microsoft
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Screen-1: 0 s-res: 3000x2000 s-dpi: 96 s-size: 793x529mm (31.22x20.83")
s-diag: 953mm (37.53")
Monitor-1: eDP-1 model: Panasonic TDM13O56 serial: <filter> built: 2016
res: 3000x2000 hz: 60 dpi: 263 gamma: 1.2 size: 290x190mm (11.42x7.48")
diag: 343mm (13.5") ratio: 3:2 modes: 3000x2000
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.2.1
direct render: Yes
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0
chip-ID: 8086:1919 class-ID: 0480
Device-2: Intel CSI-2 Host driver: ipu3-cio2 alternate: ipu3_cio2
bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d70
Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
v: 1.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 11ab:2b38 class-ID: 0200
Local Storage: total: 126.74 GiB used: 6.22 GiB (4.9%)
model: MZFLV128HCGR-000MV size: 119.24 GiB block-size: physical: 512 B
rev: BXV75M0Q temp: 25.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Generic model: Flash Disk
size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 6.22 GiB
(5.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 6.22
GiB (5.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 6.22
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 6.22
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 31.5 C mobo: N/A
Processes: 192 Uptime: 2m wakeups: 1 Memory: 7.68 GiB used: 2.01 GiB
(26.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1137 libs: 301
Garuda (2.6.8-1):
System install date: 2023-01-09
Last full system update: 2023-01-09
╭─[email protected] in ~ took 2s
╰─λ
