All issues related to Garuda Linux and its assistant
as you can see my conky looks semi transparent
i have played with own_window.. things but it won't help either.
i also copy conky.conf file from other DE of garuda but final result is semi transparent .
please help to make it fully transparent
here is my conky.conf
conky.config = {
background = true,
update_interval = 1,
cpu_avg_samples = 2,
net_avg_samples = 2,
temperature_unit = 'celsius',
if_up_strictness = 'address',
double_buffer = true,
no_buffers = true,
text_buffer_size = 2048,
own_window = true,
own_window_class = 'conky-semi',
own_window_type = 'override',
own_window_type = 'desktop',
own_window_type = 'dock',
own_window_hints = 'undecorated,sticky,skip_taskbar,skip_pager,below',
--own_window_colour = '#555555',
own_window_transparent = false,
own_window_argb_visual = true,
own_window_argb_value = 0,
draw_shades = false,
draw_outline = false,
draw_borders = false,
draw_graph_borders = false,
alignment = 'top_right',
gap_x = 50,
--von oben |
gap_y = 50,
minimum_width = 350,
minimum_height = 700,
maximum_width = 400,
border_inner_margin = 0,
border_outer_margin = 20,
--xinerama_head = 0,
override_utf8_locale = true,
use_xft = true,
font = 'Google Sans:size=8',
xftalpha = 0.8,
uppercase = false,
-- Defining colors
default_color = '#FFFFFF',
-- Shades of Gray
color1 = '#DDDDDD',
color2 = '#AAAAAA',
color3 = '#FFFFFF',
-- Orange EF5A29 green 159a7f
color4 = '#808080',
-- Green Pihole
color5 = '#EF5A29',
--color0
color6='#b2c8d8',
-- color1
color7='#b2c8d8',
color8 = '#697987', -- DeepSkyBlue 00BFFF grau=323232
color9 = '#2d3b41', -- CadetBlue 5F9EA0, light grey
conky.text = [[
# focused_workspace background #16a085 to #5D7B86
# border backgr. text
# focused_workspace #F9FAF9 #16a085 #292F34
${image /usr/share/icons/garuda/garuda-white.png -p 10,0 -s 78x59 -f 5}${font sans mono:size=10}${alignr}${color6}${alignc}
${alignr}${font sans mono:size=20}${color1}${time %r}${color}
${alignr}${font sans mono:size=12}${color1}${time %a %d-%b-%Y}${color}
${color1} ${font}
${alignr}${color3}${color}
${goto 12}+-----------------------------------------------------------+
${goto 12}${color1}+----System ${color}
${goto 15}|${goto 40}|
${goto 15}|${goto 38}+-- ${color3}Os:${alignr}${color6}${execi 130000 awk -F= '/DESCRIPTION=/{print $2}' /etc/lsb-release}${color}
${goto 15}|${goto 38}+-- ${color3}Kernel:${alignr}${color6}${kernel}${color}
${goto 15}|${goto 38}+-- ${color3}User:${alignr}${color6}${execi 11003 whoami}${color}
#${goto 15}|${goto 38}+-- ${color3}Node:${alignr}${color6}${nodename}${font}${color}
#${goto 15}|${goto 38}+-- ${color3}Machine:${alignr}${color6}${machine}${color}
${goto 15}|${goto 38}+-- ${color3}Uptime:${alignr}${color6}${uptime_short}${color}
#${goto 15}|${goto 38}+-- ${color3}Entropy${alignr}${color1}${entropy_perc}% ${color6}(${entropy_avail}/${entropy_poolsize})${color}
${goto 15}|
${goto 12}${color1}+----Status${color}
${goto 15}|${goto 38}${color1}+-- Cpu ${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Usage${alignr}${color1}${cpu cpu0}% ${color6}- ${freq_g}GHz${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}LoadAvg${alignr}${color6}${loadavg}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Temp${alignr}${color1}${execi 10 sensors | grep 'Core 0' | awk {'print $3'}}${color}
${goto 15}|${goto 38}+-- ${color1}Ram${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Total${alignr}${color6}${memmax}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}In Use${alignr}${color6}${mem} ${color1}(${memperc}%)${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Free${alignr}${color6}${memfree}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Up to${alignr}${color6}${memeasyfree}${color}
#${goto 15}|${goto 40}|
#${goto 15}|${goto 38}+-- ${color1}Swap${color}
#${goto 15}|${goto 40}|${goto 60}+-- ${color3}Total${alignr}${color6}${swapmax}${color}
#${goto 15}|${goto 40}|${goto 60}+-- ${color3}Used${alignr}${color6}${swap} - ${swapperc}%${color}
#${goto 15}|${goto 40}|${goto 60}+-- ${color3}Free${alignr}${color6}${swapfree}${color}
${goto 15}|${goto 38}${color1}+-- Storage ${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Total${alignr}${color6}${fs_size /}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Used${alignr}${color6}${fs_used /} ${color1}(${fs_used_perc}%)
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Free${alignr}${color6}${fs_free /}${color}
#${goto 15}|${goto 38}${color1}+-- Diskio ${color}
#${goto 15}|${goto 40}|${goto 60}+-- ${color3}Read${alignr}${color6}${diskio_read}${color}
#${goto 15}|${goto 40}|${goto 60}+-- ${color3}Write${alignr}${color6}${diskio_write}${color}
${goto 12}${color1}+----Processes ${color}
${goto 15}|${goto 38}+-- ${color3}Total${alignr}${color6}${processes}${color}
${goto 15}|${goto 38}+-- ${color3}Running${alignr}${color6}${running_processes}${color}
${goto 15}|${goto 38}+-- ${color1}Cpu${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top name 1}${alignr}${color6}${top cpu 1}${top mem 1}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top name 2}${alignr}${color6}${top cpu 2}${top mem 2}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top name 3}${alignr}${color6}${top cpu 3}${top mem 3}${color}
${goto 15}|
${goto 15}|${goto 38}+-- ${color1}Mem${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top_mem name 1}${alignr}${color6}${top_mem cpu 1}${top_mem mem 1}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top_mem name 2}${alignr}${color6}${top_mem cpu 2}${top_mem mem 2}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top_mem name 3}${alignr}${color6}${top_mem cpu 3}${top_mem mem 3}${color}
#${goto 15}|
I think you should change this to true
i have tried but it won't help
Have you looked in conky help and/or man(ual)? It should all be there.
Without any conky specific knowledge, I find these two settings possibly relevant.
i don't know but in Garuda multimedia edition have same conky.conf file but in my dragonized edition it look some thing blur background
Check the force blur script
#own_window_type = 'desktop',
IDK, 3 times own_window_type = ,
possible?
Thanks @RUanauR
i unchecked blur in Desktop effect setting and now it works
hi @SGS i have played every combination with own_window.... but not do any help
but as @RUanauR says i tried and it work
Then give @RUanauR the solve
. He provided the solution, not you.
Sorry @RUanauR only my intention is when people search they see my step in clear way.
I am really sorry
No problem.
