Hello and sorry to bother with this, I have left to install only 3 programs, one is Virtualbox. What is the best way to install Virtualbox? garuda-virtualbox does not install it.
Is there an easy way to install Virtualbox?, I tried with garuda-virtualbox, it ask me to choose from one of two host kernel options and no matter what I choose it gives me dependencies conflicts. If I have to do it via command line I appreciate the exact command, thanks.
Regards
Hello, the error was in pamac, now I tried with pacman via command line and no error on that point, I copy the output from the terminal, but this time I get:
"Unable to install module vboxhost/6.1.14_OSE for kernel 5.4.64-1-lts: Missing kernel modules tree."
After running garuda-virtualbox I lost all the system information that appeared at the right hand of the screen.
$ LANG=C sudo pacman -Syu garuda-virtualbox
[sudo] password for jose:
core is up to date
extra is up to date
community is up to date
multilib is up to date
error: failed retrieving file 'chaotic-aur.db' from lonewolf-builder.duckdns.org : Resolving timed out after 10000 milliseconds
chaotic-aur 1248,0 KiB 129 KiB/s 00:10 [-------------------------------------------] 100%
resolving dependencies...
:: There are 2 providers available for VIRTUALBOX-HOST-MODULES:
:: Repository community
1) virtualbox-host-dkms 2) virtualbox-host-modules-arch
Enter a number (default=1): 1
Packages (7) virtualbox-6.1.14-1 virtualbox-ext-oracle-6.1.14-1 virtualbox-ext-vnc-6.1.14-1 virtualbox-guest-iso-6.1.14-1
virtualbox-host-dkms-6.1.14-1 virtualbox-sdk-6.1.14-1 garuda-virtualbox-20200912-1
Total Installed Size: 249,73 MiB
:: Proceed with installation? [Y/n] Y
(7/7) checking keys in keyring [-------------------------------------------] 100%
(7/7) checking package integrity [-------------------------------------------] 100%
(7/7) loading package files [-------------------------------------------] 100%
(7/7) checking for file conflicts [-------------------------------------------] 100%
(7/7) checking available disk space [-------------------------------------------] 100%
(1/7) installing virtualbox-host-dkms [-------------------------------------------] 100%
Optional dependencies for virtualbox-host-dkms
linux-headers: build modules against Arch kernel [installed]
linux-lts-headers: build modules against LTS kernel [installed]
linux-zen-headers: build modules against ZEN kernel [installed]
(2/7) installing virtualbox [-------------------------------------------] 100%
vde2: Virtual Distributed Ethernet support [installed]
virtualbox-guest-iso: Guest Additions CD image [pending]
virtualbox-ext-vnc: VNC server support [pending]
virtualbox-sdk: Developer kit [pending]
(3/7) installing virtualbox-ext-vnc [-------------------------------------------] 100%
0%...10%...20%...30%...40%...50%...60%...70%...80%...90%...100%
Optional dependencies for virtualbox-ext-vnc
tigervnc: vnc client [installed]
(4/7) installing virtualbox-guest-iso [-------------------------------------------] 100%
===> virtualbox-guest-iso post install message:
===> Redistribution of VBoxGuestAdditions.iso from the binary packages
===> on www.virtualbox.org with Arch Linux has been granted by
===> InnoTek Systemberatung GmbH.
===> By using this package you accept
===> the VirtualBox Personal Use and Evaluation License (PUEL)
===> which can be found here: http://virtualbox.org/wiki/VirtualBox_PUEL
===> If you do not accept this license, you must remove the package immediately.
(5/7) installing virtualbox-sdk [-------------------------------------------] 100%
(6/7) installing virtualbox-ext-oracle [-------------------------------------------] 100%
Optional dependencies for virtualbox-ext-oracle
rdesktop: client to connect vm via RDP
(7/7) installing garuda-virtualbox [-------------------------------------------] 100%
Optional dependencies for garuda-virtualbox
tigervnc [installed]
( 1/12) Creating system user accounts...
( 2/12) Reloading system manager configuration...
( 3/12) Reloading device manager configuration...
( 4/12) Arming ConditionNeedsUpdate...
( 5/12) Install DKMS modules
==> dkms install --no-depmod -m vboxhost -v 6.1.14_OSE -k 5.8.8-zen1-1-zen
==> dkms install --no-depmod -m vboxhost -v 6.1.14_OSE -k 5.8.8-arch1-1
==> depmod 5.8.8-zen1-1-zen
==> depmod 5.8.8-arch1-1
==> Unable to install module vboxhost/6.1.14_OSE for kernel 5.4.64-1-lts: Missing kernel modules tree.
( 6/12) Cleaning pacman cache...
==> no candidate packages found for pruning
( 7/12) Foreign/AUR package notification
lib32-libva1 1.8.3-3
lib32-libva1-intel-driver 1.8.3-1
libva1 1.8.3-3
libva1-intel-driver 1.8.3-2
( 8/12) Updating icon theme caches...
( 9/12) Orphaned package notification
autoconf 2.69-7
automake 1.16.2-3
bison 3.6.4-1
flex 2.6.4-3
linux 5.8.8.arch1-1
pkgconf 1.7.3-1
(10/12) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
/etc/default/grub-btrfs/config.pacnew
Please check and merge
(11/12) Updating the desktop file MIME type cache...
(12/12) Updating the MIME type database...
Hello I rebooted and Virtualbox and the system information worked. Now I am battling with KDE to copy files from my backup in a secondary disk, to the Garuda SSD, permissions in Dolphin are a problem. Thanks.
Thanks, is working now, for some reason Dophin showed guest, but root terminal showed jose I rebooted and it worked, now I have VirtualBox with my originals VDIs. Thanks for your help and sorry for the inconveniences.
Regards
