I found out you can change the grub wallpaper for garuda by replacing /usr/share/grub/themes/garuda/background.png, though I'm not sure if that's the most appropriate way for this distro. I also found you can change some values in /usr/share/grub/themes/garuda/theme.txt.
But the question is, how can I make the font bigger? I have a high resolution screen and the font is TINY.
Should I change the font size? If so, how?
Should I specify a resolution? I tried that with the grub config (/etc/default/grub) and regenerating, but it had no effect with 4 different screen resolutions. Someone mentioned trying in /boot/grub/grub.cfg but it clearly says not to edit the file. What's the appropriate way for this distro?
Kernel: 6.2.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=dcc00dc0-be25-44ae-afb0-b21c38dd277c rw rootflags=subvol=@
loglevel=3 rd.live.overlay.overlayfs=1 ibt=off
Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
Type: Laptop System: Dell product: XPS 17 9720 v: N/A
Mobo: Dell model: 0KNF8J v: A00 serial: <superuser required> UEFI: Dell
v: 1.15.0 date: 02/07/2023
ID-1: BAT0 charge: 87.4 Wh (100.0%) condition: 87.4/95.1 Wh (91.9%)
volts: 13.1 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly serial: <filter>
status: full
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
microcode: 0x429
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2499 high: 3177 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 2700 3: 2700
4: 2700 5: 2700 6: 2700 7: 2700 8: 2700 9: 2508 10: 702 11: 2700 12: 2700
13: 2700 14: 2700 15: 3177 16: 2700 17: 2700 18: 2700 19: 2700 20: 2700
bogomips: 107520
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-5, DP-6, DP-7, DP-8, DP-9, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-03)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 01:00.0 chip-ID: 10de:2520
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 0c45:6732 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Sharp 0x1517 built: 2021 res: 3840x2400 dpi: 266
gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17") ratio: 16:10
modes: 3840x2400
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
API: ALSA v: k6.2.12-zen1-1-zen status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 2.75 TiB used: 11.78 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: PM9A1 NVMe 1024GB
lanes: 4 type: SSD serial: <filter> rev: 36309229 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
rev: 4B2QEXM7 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 11.78 GiB (0.6%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:9
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:8
used: 11.78 GiB (0.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:9
ID-1: swap-1 type: zram size: 62.49 GiB used: 0 KiB (0.0%) priority: 100
Use of uninitialized value $unit in concatenation (.) or string at /usr/bin/inxi line 24660.
Use of uninitialized value $value in concatenation (.) or string at /usr/bin/inxi line 24660.
Src: /sys System Temperatures: cpu: 56.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 418 Uptime: 20m wakeups: 13165 Memory: 62.49 GiB
used: 4.65 GiB (7.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: 1305 pm: pacman pkgs: 1298
libs: 376 tools: pamac,paru pm: flatpak pkgs: 7 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.26
System install date: 2023-04-23
Last full system update: 2023-04-24 ↻
