Weird behavior when I move mouse beyond right screen edge
Whenever my mouse goes beyond the right edge of my right monitor, everything on screen starts scrolling to the left, until I've got an entire extra black screen on my right monitor that cannot be interacted with, everything that was on my right monitor is now on my left monitor, and everything that was on my left monitor is hidden from view.
I hate this behavior and want to disable it.
Google is no help because I cannot for the life of me figure out what any sane person would call it, or why it would ever be useful to anyone.
EDIT: added garuda inxi because I'm not interested in being complained at.
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c30eb9ca-4832-49f3-81c1-4b0e792d90a1 rw rootflags=subvol=@
resume=UUID=91b55c39-2dff-41a3-bf73-eadf9564488f loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI: American Megatrends v: H.60
date: 06/11/2020
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4199 high: 4200 min/max: N/A cores: 1: 4200 2: 4200
3: 4200 4: 4200 5: 4200 6: 4200 7: 4199 8: 4200 9: 4200 10: 4200 11: 4200
12: 4200 bogomips: 100801
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 28:00.0 chip-ID: 10de:1c82 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
Screen-1: 0 s-res: 5760x1080 s-dpi: 94 s-size: 1557x292mm (61.30x11.50")
s-diag: 1584mm (62.37")
Monitor-1: DP-1 pos: right res: 1920x1080 hz: 60 dpi: 93
size: 525x297mm (20.67x11.69") diag: 603mm (23.75") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX 1050
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: snd_emu10k1 v: kernel bus-ID: 25:00.0 chip-ID: 1102:0008
class-ID: 0401
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
bus-ID: 28:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 0951:16a4 class-ID: 0300
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 7.5 TiB used: 14.81 GiB (0.2%)
fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: ACF0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA200
tech: HDD rpm: 7200 serial: <filter> fw-rev: ABX0 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 QVO 1TB
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 14.81 GiB (0.8%)
used: 14.81 GiB (0.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 48 C
Processes: 311 Uptime: 40m wakeups: 0 Memory: total: 32 GiB
available: 31.29 GiB used: 3.58 GiB (11.4%) Init: systemd v: 254
pm: pacman pkgs: 1907 libs: 527 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-28
Last full system update: 2023-08-28
I’ve never been a multi-monitor user, so probably cannot help much here.
From your inxi I just noticed that
screen 5760 does not match with 1920+1920 (it should have been 3840).
I hope this is fixable from the KDE System Settings for monitor.
The described behaviour also reminded me of the “Combine screens into virtual display” feature described here:
https://wiki.archlinux.org/title/Multihead#Combine_screens_into_virtual_display
If really needed, you may want to try that auto setting.
If not use
sudo nvidia-settings
