so when i was trying to build gamescope i got this message
wlserver: [wayland] error: XDG_RUNTIME_DIR not set in the environment
im not sure where to find XDG or what i need to edit the file
I also can't login into KDE Wayland even thou i have all of these package install
i'm using 5.18.3-262-tkg-bmq
i'm use Nvidia i have these install
is this because nvidia still dose not work wayland ?
opencl-nvidia
nvidia-utils
nvidia-settings
nvdia-dkms
libxnvctrl
libcdpai
lib32-opencl-nvidia
gwe
xf86-video-nouveau
wayland install
kwayland-integration
kwayland-server
layer-shell-qt
liva
libdecor
plasma-wayland-session
qt5-wayland
wayland
wayland-utils
xorg-xwayland
SGS
June 15, 2022, 4:50pm
2
Yes, and please post terminal output (+ garuda-inxi) like this.
opencl-nvidia
nvidia-utils
nvidia-settings
nvdia-dkms
libxnvctrl
libcdpai
lib32-opencl-nvidia
gwe
xf86-video-nouveau
wayland install
kwayland-server
layer-shell-qt
liva
libdecor
qt5-wayland
wayland
wayland-utils
xorg-xwayland
filo
June 15, 2022, 4:54pm
3
Also, always check comments in the AUR (none in this case, I think) and especially issues upstream.
This user cannot run it after driver update, maybe also building is affected.
opened 09:18AM - 14 Jun 22 UTC
I upgraded to the latest Nvidia drivers yesterday (515.48.07), on my Optimus lap… top, running Manjaro.
Gamescope won't run for me:
~ > gamescope -r 30 -- vkcube
No CAP_SYS_NICE, falling back to regular-priority compute and threads.
Performance will be affected.
vulkan: selecting physical device 'NVIDIA GeForce GTX 1050': queue family 2
vulkan: physical device supports DRM format modifiers
vulkan: vkGetPhysicalDeviceFormatProperties2 returned zero modifiers for DRM format 0x3231564E (VkResult: 0)
vulkan: supported DRM formats for sampling usage:
vulkan: 0x34325241
vulkan: 0x34325258
wlserver: [backend/headless/backend.c:82] Creating headless backend
wlserver: Running compositor on wayland display 'gamescope-0'
wlserver: [backend/headless/backend.c:18] Starting headless backend
wlserver: [xwayland/server.c:92] Starting Xwayland on :1
No provider of eglGetCurrentContext found. Requires one of:
EGL 14
(EE)
(EE) Backtrace:
(EE) 0: Xwayland (0x564c644ca000+0x1658c3) [0x564c6462f8c3]
(EE) 1: Xwayland (0x564c644ca000+0x1659c4) [0x564c6462f9c4]
(EE) 2: /usr/lib/libc.so.6 (0x7fa40ea4a000+0x3e8e0) [0x7fa40ea888e0]
(EE) 3: /usr/lib/libc.so.6 (0x7fa40ea4a000+0x8e36c) [0x7fa40ead836c]
(EE) 4: /usr/lib/libc.so.6 (raise+0x18) [0x7fa40ea88838]
(EE) 5: /usr/lib/libc.so.6 (abort+0xcf) [0x7fa40ea72535]
(EE) 6: /usr/lib/libepoxy.so.0 (0x7fa40ee64000+0xbfc8e) [0x7fa40ef23c8e]
(EE) 7: /usr/lib/libepoxy.so.0 (0x7fa40ee64000+0xbfcd0) [0x7fa40ef23cd0]
(EE) 8: /usr/lib/libepoxy.so.0 (0x7fa40ee64000+0xc105f) [0x7fa40ef2505f]
(EE) 9: /usr/lib/libepoxy.so.0 (0x7fa40ee64000+0xc3fdb) [0x7fa40ef27fdb]
(EE) 10: /usr/lib/libepoxy.so.0 (0x7fa40ee64000+0x5f277) [0x7fa40eec3277]
(EE) 11: /usr/lib/libepoxy.so.0 (0x7fa40ee64000+0x68387) [0x7fa40eecc387]
(EE) 12: /usr/lib/libepoxy.so.0 (0x7fa40ee64000+0x8b9ff) [0x7fa40eeef9ff]
(EE) 13: /usr/lib/libepoxy.so.0 (0x7fa40ee64000+0xc3b57) [0x7fa40ef27b57]
(EE) 14: Xwayland (0x564c644ca000+0x47439) [0x564c64511439]
(EE) 15: Xwayland (0x564c644ca000+0x44091) [0x564c6450e091]
(EE) 16: Xwayland (0x564c644ca000+0x3eac1) [0x564c64508ac1]
(EE) 17: Xwayland (0x564c644ca000+0x2f1ce) [0x564c644f91ce]
(EE) 18: /usr/lib/libc.so.6 (0x7fa40ea4a000+0x29290) [0x7fa40ea73290]
(EE) 19: /usr/lib/libc.so.6 (__libc_start_main+0x8a) [0x7fa40ea7334a]
(EE) 20: Xwayland (0x564c644ca000+0x31a75) [0x564c644fba75]
(EE)
(EE)
Fatal server error:
(EE) Caught signal 6 (Aborted). Server aborting
(EE)
wlserver: [xwayland/server.c:247] Xwayland startup failed, not setting up xwm
As far as I can tell XWayland seems to work OK otherwise, I can run Steam games via Proton for example.
Anyway it's brand new. Maybe not even a bug. Just wanted to suggest an approach...
SGS:
Kernel: 5.18.3-262-tkg-bmq arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=9a48c1a2-a8e4-4593-8aa9-8fe4dd3dbc74 rw rootflags=subvol=@
resume=UUID=ffd2d4d3-f83c-4607-b6bc-2cab7baad1e1 loglevel=3
Console: pty pts/1 wm: kwin_x11 DM: 1: LightDM v: 1.30.0 note: stopped
2: SDDM note: stopped Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: GA-78LMT-USB3 6.0 v: SEx serial: N/A
BIOS: Award v: F2 date: 11/25/2014
Info: model: AMD FX-8350 socket: 754 (M2) note: check bits: 64 type: MT MCP
arch: Piledriver built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 2 stepping: 0 microcode: 0x6000852
Topology: cpus: 1x cores: 8 smt: enabled cache: L1: 384 KiB
desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 4000 min/max: 1400/4000 boost: enabled
base/boost: 4000/3000 scaling: driver: acpi-cpufreq governor: performance
volts: 1.5 V ext-clock: 200 MHz cores: 1: 4000 2: 4000 3: 4000 4: 4000
5: 4000 6: 4000 7: 4000 8: 4000 bogomips: 64069
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: PNY driver: nvidia
v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2
speed: 5 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f82 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 3600x1080 s-dpi: 90 s-size: 1016x312mm (40.00x12.28")
s-diag: 1063mm (41.84")
Monitor-1: DVI-D-0 pos: bottom-l res: 1680x1050 hz: 60 dpi: 90
size: 473x296mm (18.62x11.65") diag: 558mm (21.97") modes: N/A
Monitor-2: HDMI-0 pos: primary,top-right res: 1920x1080 hz: 60 dpi: 106
size: 458x258mm (18.03x10.16") diag: 526mm (20.7") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 8-1.3:4 chip-ID: 2d30:1000 bus-ID: 00:14.2 class-ID: 0300
chip-ID: 1002:4383 class-ID: 0403
Device-2: NVIDIA vendor: PNY driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-3: C-Media Addasound SR Series type: USB
Sound Server-1: ALSA v: k5.18.3-262-tkg-bmq running: yes
lanes: 1 port: ce00 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 803.94 GiB used: 360.74 GiB (44.9%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 223.57 GiB block-size:
physical: 512 B logical: 512 B sata: 3.2 speed: 3.0 Gb/s type: SSD
serial: <filter> rev: BB.3 scheme: MBR
SMART: yes state: disabled
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500LT012-9WS142
family: Laptop HDD size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: SDM1 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Ultra
size: 114.61 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 210.74 GiB size: 210.74 GiB (100.00%)
used: 100.87 GiB (47.9%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 210.74 GiB size: 210.74 GiB (100.00%)
maj-min: 8:1
ID-3: /var/log raw-size: 210.74 GiB size: 210.74 GiB (100.00%)
maj-min: 8:1
ID-4: /var/tmp raw-size: 210.74 GiB size: 210.74 GiB (100.00%)
maj-min: 8:1
ID-1: swap-1 type: zram size: 11.67 GiB used: 30 MiB (0.3%) priority: 100
ID-2: swap-2 type: partition size: 12.83 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 30.9 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 50%
Processes: 287 Uptime: 4h 6m wakeups: 0 Memory: 11.67 GiB
used: 5.17 GiB (44.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1832
lib: 513 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.18
Garuda (2.6.3-2):
System install date: 2022-06-14
Last full system update: 2022-06-15
Is partially upgraded: Yes
Failed units: anbox-container-manager.service bluetooth-autoconnect.service systemd-networkd-wait-online.service
good to know nvidia still have not fix wayland in there cards
filo
June 15, 2022, 8:11pm
5
I noticed you are in a partial upgrade status.
Maybe you’d better
garuda-update
Furthermore, how’s that
Two DM’s are out of standard…
For sddm, give a look at this thread:
Hi,
So for all that want to run an "all wayland kde", with sddm using wayland instead of xorg, do this:
install package sddm-wayland-git from chaotic-aur
in for example /etc/sddm.conf.d/dr460nized.conf, add:
[General]
DisplayServer=wayland
GreeterEnvironment=QT_WAYLAND_SHELL_INTEGRATION=layer-shell
and
[Wayland]
CompositorCommand=kwin_wayland --no-lockscreen --inputmethod maliit-keyboard --width 2560 --height 1440
adjust width and height to your monitor.
but beware, maybe, here be drago…
Just consider that now sddm-wayland-git
is called sddm-git
