My apologies, here’s the output.
Kernel: 6.7.8-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 13.2.1 clocksource: tsc avail: acpi_pm
root=UUID=c140b002-e28d-4083-a150-ae19562001fd rw
rootflags=subvol=@ quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=a515cfb2-63f6-4abb-9bde-b9daf61c375e
loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A
info: frameworks v: 6.0.0 wm: kwin_wayland with: krunner
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A
Mobo: ASUSTeK model: ROG STRIX Z690-E GAMING WIFI
v: Rev 1.xx serial: <superuser required> part-nu: SKU
uuid: <superuser required>
UEFI-[Legacy]: American Megatrends v: 0503
date: 09/09/2021
ID-1: hidpp_battery_0 charge: 100% condition: N/A
volts: 4.2 min: N/A model: Logitech G703 LIGHTSPEED
Wireless Gaming Mouse w/ HERO type: N/A serial: <filter>
status: full
Info: model: 12th Gen Intel Core i7-12700K bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF)
family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x32
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4
threads: 20 smt: enabled cache: L1: 1024 KiB desc: d-4x32
KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB L2: 12 MiB
desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 1547 high: 2790
min/max: 800/4900:5000:3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 1200 3: 2508
4: 2542 5: 2790 6: 800 7: 801 8: 1200 9: 2514 10: 1200
11: 2536 12: 2579 13: 1200 14: 1236 15: 1300 16: 1200
17: 1200 18: 1200 19: 947 20: 1200 bogomips: 144383
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1
sse4_2 ssse3 vmx
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti]
vendor: eVga.com. driver: nvidia v: 550.54.14
alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2208 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11.3.4.1:15
Display: wayland server: X.org v: 1.21.1.11
with: Xwayland v: 23.2.4 compositor: kwin_wayland driver:
X: loaded: modesetting,nouveau,nvidia
alternate: fbdev,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: Unknown-1 res: 640x480 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0
drv: nvidia device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia wayland: drv: zink x11:
drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa
v: 24.0.2-arch1.1 glx-v: 1.4 direct-render: yes
renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 30.42 GiB
unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 14 device: 0
type: discrete-gpu name: NVIDIA GeForce RTX 3080 Ti
driver: nvidia v: 550.54.14 device-ID: 10de:2208
surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 24.0.2-arch1.1 (LLVM 16.0.6)
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
Device-2: NVIDIA GA102 High Definition Audio
vendor: eVga.com. driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aef class-ID: 0403
Device-3: Logitech HD Pro Webcam C920
Device-4: SteelSeries ApS Arctis Pro Wireless
driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-11.3.4.3.3:18 chip-ID: 1038:1294
Device-5: ASUSTek USB Audio
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-4:2 chip-ID: 0b05:1996 class-ID: 0300
API: ALSA v: k6.7.8-zen1-1-zen status: kernel-api
with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.0.3 status: active with:
1: pipewire-pulse status: active 2: wireplumber
status: active 3: pipewire-alsa type: plugin 4: pw-jack
type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak]
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2725
Device-2: Intel Ethernet I225-V vendor: ASUSTeK
driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
IF-ID-1: virbr0 state: up speed: 10000 Mbps
duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10000 Mbps
duplex: full mac: <filter>
Info: services: NetworkManager, smbd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-14:9 chip-ID: 8087:0032 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up
address: <filter> bt-v: 5.3 lmp-v: 12 status:
Hardware-1: Intel Volume Management Device NVMe RAID
Controller driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0
chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.82 TiB used: 521.4 GiB (28.0%)
SMART Message: Unable to run smartctl. Root privileges
required.
model: SSD 980 PRO 2TB size: 1.82 TiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 39.9 C
scheme: MBR
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%)
used: 521.4 GiB (28.5%) fs: btrfs dev: /dev/nvme0n1p1
maj-min: 259:1
ID-2: /home raw-size: 1.79 TiB size: 1.79 TiB (100.00%)
maj-min: 259:1
ID-3: /var/log raw-size: 1.79 TiB
size: 1.79 TiB (100.00%) used: 521.4 GiB (28.5%) fs: btrfs
ID-4: /var/tmp raw-size: 1.79 TiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: partition size: 34.27 GiB
used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: swap-2 type: zram size: 31.15 GiB
used: 3 MiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20
System Temperatures: cpu: 28.0 C mobo: N/A
Memory: total: 32 GiB available: 31.16 GiB
used: 9.3 GiB (29.8%)
Processes: 444 Power: uptime: 6h 5m
states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.4 GiB
services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical
Packages: pm: pacman pkgs: 1862 libs: 512
tools: octopi,paru Compilers: gcc: 13.2.1
Shell: garuda-inxi default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date: 2023-04-24
Last full system update: 2024-03-06
I also luckily had GWE (GreenWithEnvy) opened this time from creating my forum account and getting the driver info and I saw this error message this time.
NV-CONTROL X extension not found
It was not possible to find the NVIDIA NV-CONTROL X extension on the current Display device.
Please make sure that the NVIDIA proprietary display drivers are installed and they support your current GPU
So I’ll spend some time looking into that error more in the morning. I just wanted to get this posted since I forgot it from the template.
Edit: Looks like the above error might be a GWE only thing.
Edit 2: I found and ran this command in another post about Wayland and nVidia yesterday, but it didn’t do anything:
sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ nvidia-drm.modeset=1 "/g' -i /etc/default/grub && sudo update-grub
But I manually went into the grub file and added the nvidia-drm.modeset and reboot and now I’m able to actually boot into Wayland at proper resolutions and with the KDE shell/widgets loading.
Thanks for the awesome experience so far with Garuda, and sorry for the post with my hiccup about getting Wayland running.
Fonts are a bit blurry in some areas, but I can live with that until I figure that out.
