garuda-inxi System: Kernel: 6.11.0-1-cachyos-bore arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos-bore root=UUID=87fbd51c-f09a-4550-b283-c3fe8bc490be rw rootflags=subvol=@ quiet resume=UUID=ba48962c-2402-4c28-83e0-7ad50e53d838 loglevel=3 ibt=off Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux Machine: Type: Laptop System: Acer product: Nitro AN515-54 v: V1.33 serial: <superuser required> Mobo: CFL model: Octavia_CFS v: V1.33 serial: <superuser required> part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.33 date: 11/17/2020 Battery: ID-1: BAT1 charge: 43.0 Wh (100.0%) condition: 43.0/57.5 Wh (74.8%) volts: 16.7 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter> status: full CPU: Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8 Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2 smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB Speed (MHz): avg: 2037 min/max: 800/4100 scaling: driver: intel_pstate governor: powersave cores: 1: 2037 2: 2037 3: 2037 4: 2037 5: 2037 6: 2037 7: 2037 8: 2037 bogomips: 38400 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx Vulnerabilities: <filter> Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300 Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Acer Incorporated ALI driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300 Device-3: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter> Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2 compositor: kwin_wayland driver: X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris gpu: i915 display-ID: 0 Monitor-1: eDP-1 model: LG Display 0x065a built: 2019 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080 API: Vulkan v: 1.3.295 layers: 4 device: 0 type: integrated-gpu name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 24.2.3-arch1.1 device-ID: 8086:3e9b surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA GeForce GTX 1650 driver: nvidia v: 560.35.03 device-ID: 10de:1f91 surfaces: xcb,xlib,wayland device: 2 type: cpu name: llvmpipe (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000 surfaces: xcb,xlib,wayland API: EGL Message: EGL data requires eglinfo. Check --recommends. Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403 Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403 API: ALSA v: k6.11.0-1-cachyos-bore status: kernel-api tools: N/A Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl Network: Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200 IF: enp7s0 state: down mac: <filter> Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280 IF: wlp8s0 state: up mac: <filter> Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant Bluetooth: Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0029 class-ID: e001 Report: btmgmt ID: hci0 rfk-id: 8 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c Drives: Local Storage: total: 1.14 TiB used: 728.03 GiB (62.2%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200 MTFDHBA256TCK size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: P1MA003 temp: 42.9 C scheme: GPT ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: ACM1 scheme: GPT Partition: ID-1: / raw-size: 221.17 GiB size: 221.17 GiB (100.00%) used: 171.9 GiB (77.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 ID-3: /home raw-size: 221.17 GiB size: 221.17 GiB (100.00%) used: 171.9 GiB (77.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 ID-4: /var/log raw-size: 221.17 GiB size: 221.17 GiB (100.00%) used: 171.9 GiB (77.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 ID-5: /var/tmp raw-size: 221.17 GiB size: 221.17 GiB (100.00%) used: 171.9 GiB (77.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 Swap: Kernel: swappiness: 133 (default 60) cache-pressure: 100 (default) zswap: no ID-1: swap-1 type: zram size: 15.46 GiB used: 67.2 MiB (0.4%) priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0 ID-2: swap-2 type: partition size: 17.01 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 Sensors: System Temperatures: cpu: 72.0 C pch: 68.0 C mobo: N/A Fan Speeds (rpm): N/A Info: Memory: total: 16 GiB available: 15.46 GiB used: 5.95 GiB (38.5%) Processes: 293 Power: uptime: 1d 8h 16m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 5 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical tool: systemctl Packages: pm: pacman pkgs: 1264 libs: 367 tools: octopi,pamac,paru,yay Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36 Garuda (2.6.26-1): System install date: 2024-09-19 Last full system update: 2024-09-25 ↻ Is partially upgraded: No Relevant software: snapper NetworkManager dracut nvidia-dkms Windows dual boot: No/Undetected Failed units:
fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.769: Function: ghb_init_combo_box
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.771: returning null (PictureDeinterlaceFilter)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.772: returning null (PictureDenoiseFilter)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.772: returning null (PictureSharpenFilter)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.787: Function: ghb_widget_to_setting
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.787: Function: ghb_get_setting_key
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.787: ud 0x5bf8d976e5f0
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.787: builder 0x5bf8d981ee00
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.787: Function: bind_audio_tree_model
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.787: Done
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.787: Function: bind_subtitle_tree_model
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.788: Function: ghb_presets_bind_tree_model
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.788: Done
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.791: returning null (DiskFreeLimit)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.823: returning null (PresetDescription)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.823: returning null (Default)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.823: returning null (FolderOpen)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.824: returning null (FolderOpen)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.824: returning null (PresetDescription)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.824: returning null (Default)
(fr.handbrake.ghb:341764): ghb-DEBUG: 19:29:52.855: Function: ghb_cache_volnames
Gdk-INFO: 19:29:53.012: Vulkan: Loader Message: linux_read_sorted_physical_devices:
Gdk-INFO: 19:29:53.012: Vulkan: Loader Message: Original order:
Gdk-INFO: 19:29:53.013: Vulkan: Loader Message: [0] llvmpipe (LLVM 18.1.8, 256 bits)
Gdk-INFO: 19:29:53.013: Vulkan: Loader Message: [1] Intel(R) UHD Graphics 630 (CFL GT2)
Gdk-INFO: 19:29:53.013: Vulkan: Loader Message: [2] NVIDIA GeForce GTX 1650
Gdk-INFO: 19:29:53.013: Vulkan: Loader Message: Sorted order:
Gdk-INFO: 19:29:53.013: Vulkan: Loader Message: [0] NVIDIA GeForce GTX 1650
Gdk-INFO: 19:29:53.013: Vulkan: Loader Message: [2] llvmpipe (LLVM 18.1.8, 256 bits)
Gdk-INFO: 19:29:53.013: Vulkan: Loader Message: linux_read_sorted_physical_devices:
Gdk-INFO: 19:29:53.013: Vulkan: Loader Message: Original order:
(fr.handbrake.ghb:341764): Gdk-DEBUG: 19:29:53.013: Vulkan: Loader Message: Copying old device 0 into new device 0
(fr.handbrake.ghb:341764): Gdk-DEBUG: 19:29:53.013: Vulkan: Loader Message: Copying old device 1 into new device 1
(fr.handbrake.ghb:341764): Gdk-DEBUG: 19:29:53.013: Vulkan: Loader Message: Copying old device 2 into new device 2
Gdk-INFO: 19:29:53.015: Vulkan: Loader Message: linux_read_sorted_physical_devices:
Gdk-INFO: 19:29:53.015: Vulkan: Loader Message: Original order:
Gdk-INFO: 19:29:53.015: Vulkan: Loader Message: [0] llvmpipe (LLVM 18.1.8, 256 bits)
Gdk-INFO: 19:29:53.016: Vulkan: Loader Message: [1] Intel(R) UHD Graphics 630 (CFL GT2)
Gdk-INFO: 19:29:53.016: Vulkan: Loader Message: [2] NVIDIA GeForce GTX 1650
Gdk-INFO: 19:29:53.016: Vulkan: Loader Message: Sorted order:
Gdk-INFO: 19:29:53.016: Vulkan: Loader Message: [0] NVIDIA GeForce GTX 1650
Gdk-INFO: 19:29:53.016: Vulkan: Loader Message: [2] llvmpipe (LLVM 18.1.8, 256 bits)
(fr.handbrake.ghb:341764): Gdk-DEBUG: 19:29:53.016: Vulkan: Loader Message: Copying old device 0 into new device 0
(fr.handbrake.ghb:341764): Gdk-DEBUG: 19:29:53.016: Vulkan: Loader Message: Copying old device 1 into new device 1
(fr.handbrake.ghb:341764): Gdk-DEBUG: 19:29:53.016: Vulkan: Loader Message: Copying old device 2 into new device 2
Gdk-INFO: 19:29:53.016: Vulkan: Loader Message: linux_read_sorted_physical_devices:
Gdk-INFO: 19:29:53.016: Vulkan: Loader Message: Original order:
Gdk-INFO: 19:29:53.016: Vulkan: Loader Message: [0] llvmpipe (LLVM 18.1.8, 256 bits)
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: Removing driver /usr/lib/libvulkan_radeon.so due to not having any physical devices
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: Removing driver /usr/lib/libvulkan_intel_hasvk.so due to not having any physical devices
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: Failed to find vkGetDeviceProcAddr in layer "libVkLayer_MESA_device_select.so"
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: vkCreateDevice layer callstack setup to:
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: <Application>
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: ||
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: <Loader>
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: <Device>
Gdk-INFO: 19:29:53.018: Vulkan: Loader Message: Using "Intel(R) UHD Graphics 630 (CFL GT2)" with driver: "/usr/lib/libvulkan_intel.so"
(fr.handbrake.ghb:341764): Gdk-DEBUG: 19:29:53.032: wp_linux_drm_syncobj_manager_v1#54: error 0: surface already exists
ghb fails to launch under wayland on terminal with debugging option enabled
ghb -x gives output pasted above , I have ven remade the package , it thought it was chaotic-aur fault , but it seems like issue in wayland
