Lately when running sudo pacman -Syu I get the following message:
: Starting full system upgrade...
warning: garuda-settings-manager-git: local (1.0.0.r1.g15c4106-3) is newer than chaotic-aur (1.0.0.r1.g15c4106-1)
warning: garuda-settings-manager-kcm-git: local (1.0.0.r1.g15c4106-3) is newer than chaotic-aur (1.0.0.r1.g15c4106-1)
How is it possible to have a newer package compared to the repo? Does this requires intervention?
inxi -Faz
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=543c6354-5d39-4703-bb64-407600dc772d rw rootflags=subvol=@
resume=UUID=65b1555e-e8e7-41cb-84a2-63265cdbd7db loglevel=3
Mobo: ASUSTeK model: TUF GAMING B550M-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: Discharging
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3602 high: 3654 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3611 2: 3601
3: 3593 4: 3595 5: 3593 6: 3595 7: 3654 8: 3602 9: 3596 10: 3591 11: 3599
12: 3598 bogomips: 88795
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 07:00.0 chip-ID: 10de:1d01
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5")
s-diag: 693mm (27.3")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Device-1: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 10de:0fb8
driver: snd_hda_intel v: kernel bus-ID: 09:00.4 chip-ID: 1022:1487
Device-3: Yamaha Steinberg UR22 type: USB driver: snd-usb-audio
bus-ID: 3-1:2 chip-ID: 0499:1509 class-ID: ff00
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
bus-ID: 1-5:2 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 1.14 TiB used: 855.87 GiB (73.5%)
model: WDS250G3X0C-00SJG0 size: 232.89 GiB block-size: physical: 512 B
rev: 111110WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1053 scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 32.02 GiB (32.0%)
ID-3: /home raw-size: 128.59 GiB size: 128.59 GiB (100.00%)
used: 82.21 GiB (63.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 32.02 GiB (32.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.6 GiB used: 308.2 MiB (1.9%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 41 C
Processes: 363 Uptime: 12h 18m wakeups: 24 Memory: 15.6 GiB
used: 3.48 GiB (22.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1665 lib: 350 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: yakuake inxi: 3.3.11
