During garuda-update i get the following warnings:
warning: fxload: local (2008_10_13-6) is newer than chaotic-aur (1.0.27-1)
warning: reshade-shaders-git: local (r879.a2314cb-1) is newer than chaotic-aur (r86.3e43f85-1)
the reshade-shaders-git warning i’ve been getting for many months but the fxload one just popped up today and i was wondering: a) why does this happen? and b) what should i do about it?
searching the packages with pacman -Ss returns to following info:
chaotic-aur/reshade-shaders-git r86.3e43f85-1 [installed: r879.a2314cb-1]
chaotic-aur/fxload 1.0.27-1 [installed: 2008_10_13-6]
below there is more detailed info about the packages obtained with pacman -Qi and the garuda-inxi at the end
Version : r879.a2314cb-1
Description : A collection of post-processing shaders written in the ReShade FX shader language, to be used by vkBasalt
Architecture : any
URL : https://github.com/crosire/reshade-shaders
Licenses : custom
Groups : None
Provides : None
Depends On : None
Optional Deps : None
Required By : None
Optional For : vkbasalt
Conflicts With : None
Replaces : None
Installed Size : 9.18 MiB
Packager : UFSCar HPC Builder <hpc.ufscar@chaotic.cx>
Build Date : Sat 30 Apr 2022 11:17:23 AM -04
Install Date : Sun 17 Jul 2022 05:02:21 AM -04
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
Version : 2008_10_13-6
Description : fxload firmware loader. Used with udev or devfs/hotplug.
Architecture : x86_64
URL : http://linux-hotplug.sourceforge.net/
Licenses : GPL
Groups : None
Provides : None
Depends On : glibc
Required By : None
Optional For : None
Replaces : None
Installed Size : 26.01 KiB
Build Date : Sat 05 Nov 2022 04:07:50 AM -03
Install Date : Mon 07 Aug 2023 09:11:24 PM -04
Install Script : No
Kernel: 6.11.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1ff06791-3783-4094-b0dd-898c4b519967 rw rootflags=subvol=@
resume=UUID=f1f58c16-f4e6-4587-b7db-88c32ef6457f loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.1 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Laptop System: Micro-Star product: Katana GF66 11SC v: REV:1.0
Mobo: Micro-Star model: MS-1582 v: REV:1.0 serial: <superuser required>
part-nu: 1582.3 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E1582IMS.30A date: 07/22/2021
ID-1: BAT1 charge: 35.4 Wh (96.5%) condition: 36.7/52.0 Wh (70.5%)
volts: 12.2 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
microcode: 0x52
smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB
desc: 6x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: performance cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 64512
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:9a68 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 560.35.03
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0302
Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:3 chip-ID: 5986:211b
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
gpu: i915,nvidia d-rect: 3286x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left res: 1366x768 size: N/A modes: N/A
Monitor-2: eDP-1 pos: right res: 1920x1080 size: N/A modes: N/A
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
device-ID: 8086:9a68 memory: 3.64 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics (TGL GT1) driver: mesa intel v: 24.2.5-arch1.1
device-ID: 8086:9a68 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1650 driver: nvidia
v: 560.35.03 device-ID: 10de:1f9d surfaces: xcb,xlib,wayland device: 2
v: 24.2.5-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0401
API: ALSA v: k6.11.4-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 323.08 GiB (67.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFK52.8 temp: 32.9 C
used: 322.86 GiB (69.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.46 GiB used: 2.38 GiB (31.8%)
ID-2: swap-2 type: partition size: 8.8 GiB used: 221.7 MiB (2.5%)
System Temperatures: cpu: 38.0 C mobo: N/A
Memory: total: 8 GiB note: est. available: 7.46 GiB used: 3.8 GiB (50.9%)
Processes: 335 Power: uptime: 1d 2h 55m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 2.94 GiB services: org_kde_powerdevil,
Packages: 2535 pm: pacman pkgs: 2496 libs: 604 tools: paru pm: flatpak
pkgs: 39 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
System install date: 2022-08-03
Last full system update: 2024-10-21 ↻
