Something terrible has occurred with my system.
error: could not parse package description file ‘haskell-hie-compat-0.3.0.0-1/desc’ from db ‘extra’
error: could not read db ‘extra’ (Truncated input file (needed 512 bytes, only 0 available))
repeated forever… I think.
╰─λ garuda-update
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur 2.6 MiB 2.30 MiB/s 00:01 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
--> Applying keyring updates before starting full system update..
warning: archlinux-keyring-20231222-1 is up to date -- skipping
error: could not parse package description file 'haskell-hie-compat-0.3.0.0-1/desc' from db 'extra'
error: could not read db 'extra' (Truncated input file (needed 512 bytes, only 0 available))
warning: chaotic-keyring-20230616-1 is up to date -- skipping
warning: garuda-hotfixes-1.1.2-1 is up to date -- skipping
there is nothing to do
^C⏎
[🔴] × garuda-inxi
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw rootflags=subvol=@
drm.edid_firmware=DisplayPort-0:/edid/Samsung-EDID-RGB.bin ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
UEFI: American Megatrends LLC. v: F28 date: 12/14/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 2960 high: 5332 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 5300 2: 5316 3: 800
4: 800 5: 5332 6: 800 7: 5300 8: 800 9: 5300 10: 5300 11: 800 12: 5300
13: 5300 14: 800 15: 5296 16: 5329 17: 800 18: 800 19: 800 20: 800
21: 4203 22: 800 23: 800 24: 4182 bogomips: 164044
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73a5
Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.1:7
chip-ID: 1532:0e03 class-ID: 0102
Device-3: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:9 chip-ID: 534d:2109
Device-4: Elgato Systems GmbH Game Capture HD60 X
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.1:4
chip-ID: 0fd9:0082 class-ID: 0300 serial: <filter>
Device-5: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.2:8
chip-ID: 07ca:0110 class-ID: 0102 serial: <filter>
s-diag: 1165mm (45.88")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Samsung serial: <filter>
built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 16.0.6 DRM 3.56 6.7.0-zen3-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.274 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-4: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-5: MacroSilicon USB Video
Device-6: Elgato Systems GmbH Game Capture HD60 X
Device-7: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 port: N/A bus-ID: 08:00.0 chip-ID: 1d6a:14c0 class-ID: 0200
temp: 44.0 C
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:20 chip-ID: 8087:0033
Local Storage: total: 9.56 TiB used: 1.69 TiB (17.7%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 55.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:5 vendor: Western Digital
fw-rev: 731100WD temp: 53.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Corsair model: Performance Pro
tech: SSD serial: <filter> fw-rev: 1.0 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: X110 2.5 7MM 256GB
tech: SSD serial: <filter> fw-rev: 412 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.4 TiB (77.2%)
used: 1.3 MiB (0.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 1.4 TiB (77.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.61 GiB used: 740.8 MiB (1.2%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1096
Processes: 568 Uptime: 13m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.62 GiB used: 7.74 GiB (12.4%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2192 libs: 593 tools: octopi,paru,yay pm: rpm
pkgs: 0 Shell: fish v: 3.7.0 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-05-03
Last full system update: 2024-01-18
