The wall of errors that I first posted about in the below thread is back and will not go away this time no matter what I try. Any suggestions would be greatly appreciated.
╭─locutus@Unimatrix in ~
╰─λ garuda-inxi
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b3d95ca1-50dc-4f6f-9e2e-1eb204336f28 rw rootflags=subvol=@
v: 5.115.0 wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
UEFI: American Megatrends v: 3404 date: 10/07/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M325
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3486 high: 3620 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3605 4: 3593 5: 3400 6: 3592 7: 3400 8: 3400 9: 3400 10: 3400 11: 3595
12: 3592 13: 3620 14: 3400 15: 3591 16: 3400 bogomips: 108586
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 0b:00.0 chip-ID: 10de:2504 class-ID: 0300
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.38x11.14")
s-diag: 727mm (28.63")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: AOC Q2963
serial: <filter> built: 2016 res: 2560x1080 hz: 60 dpi: 97 gamma: 1.2
size: 673x284mm (26.5x11.18") diag: 730mm (28.8") modes: max: 2560x1080
min: 640x480
inactive: wayland,device-1
memory: 11.72 GiB
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 545.29.06
device-ID: 10de:2504 surfaces: xcb,xlib
Device-1: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: snd_emu10k1 v: kernel bus-ID: 08:00.0 chip-ID: 1102:0008
class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
bus-ID: 0b:00.1 chip-ID: 10de:228e class-ID: 0403
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 13d3:3563
Local Storage: total: 26.89 TiB used: 16.16 TiB (60.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR002 temp: 29.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 28.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
fw-rev: 1801 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: Expansion HDD
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0003 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000AS0002-1NA17Z
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5980
serial: <filter> scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: GPT
ID-1: / raw-size: 232.8 GiB size: 232.8 GiB (100.00%) used: 39.2 GiB (16.8%)
used: 2 MiB (0.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
used: 39.2 GiB (16.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.95 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.2 C mobo: N/A gpu: nvidia temp: 40 C
Memory: total: 48 GiB available: 46.95 GiB used: 12.36 GiB (26.3%)
Processes: 534 Power: uptime: 42m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.74 GiB services: org_kde_powerdevil,upowerd
Packages: 2176 pm: pacman pkgs: 2161 libs: 586
tools: pacseek,paru,pikaur,yay pm: flatpak pkgs: 15 pm: snap pkgs: 0
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-12
Last full system update: 2024-02-15 ↻
