Hii
I am using kde dragonized and here I encountered rather a strange issue.Whenever I put my laptop to sleep, it does not wake up. Meaning to say when I press a key, It does not respond. I tried a few things
- Updating and rebooting
- Using snapper and tried to restore to a previous snapshot, It worked but after I updated in that snapshot, I observed the same problem. When I tried different snapshots, It had the same problem.
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=55ad2dc2-c093-4bbf-a6b9-f8f27f5449b0 rw [email protected]
Type: Laptop System: LENOVO product: 81MT v: Lenovo V145-15AST
serial: <superuser required> Chassis: type: 10 v: Lenovo V145-15AST
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 8ZCN27WW(V2.06) date: 01/12/2021
ID-1: BAT1 charge: 24.5 Wh (98.0%) condition: 25.0/30.0 Wh (83.2%)
volts: 8.5 min: 7.5 model: 0x53 0x4D 0x50 0x00 0x31 0x PABAS0241231
type: Li-ion serial: <filter> status: N/A cycles: 508
Info: model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
arch: Excavator family: 0x15 (21) model-id: 0x70 (112) stepping: 0
microcode: 0x6006705
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 2344 high: 2373 min/max: 1300/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2373 2: 2316
bogomips: 10380
STIBP: disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Syntek EasyCamera type: USB driver: uvcvideo bus-ID: 1-1.3:4
chip-ID: 174f:241a class-ID: 0e02
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 2000
bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
bus-ID: 1-1.2:3 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 931.51 GiB used: 24.17 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0E scheme: MBR
used: 24.17 GiB (2.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 3.72 GiB used: 206.8 MiB (5.4%)
System Temperatures: cpu: 71.2 C mobo: N/A gpu: amdgpu temp: 71.0 C
Processes: 227 Uptime: 16m wakeups: 1 Memory: 3.72 GiB
used: 2.59 GiB (69.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1475 lib: 401 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
Any help?
