VLC volume on tracks & videos resets after repeating erroneously. (seems to be a possible exploit; wifi 6 is turned off in bios & no internet or power.. connected when this happens) Audio also cuts out at certain points in the track as if the track has been manipulated yet it seems to be have been.
Much appreciated.
Kernel: 6.1.6-hardened2-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: pti=on page_alloc.shuffle=1
BOOT_IMAGE=/@/boot/vmlinuz-linux-hardened
root=UUID=05bceb4d-b058-461f-b1fc-5c0e56056f6b rw [email protected]
quiet
cryptdevice=UUID=fb551a59-b1f6-4fb4-a902-0a18c46bbd4c:luks-fb551a59-b1f6-4fb4-a902-0a18c46bbd4c
root=/dev/mapper/luks-fb551a59-b1f6-4fb4-a902-0a18c46bbd4c quiet splash
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X412DAP_F412DA
Mobo: ASUSTeK model: X412DAP v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X412DAP.300 date: 12/25/2019
ID-1: BAT0 charge: 18.6 Wh (61.6%) condition: 30.2/37.1 Wh (81.4%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 62
Info: model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2600 boost: enabled scaling:
driver: acpi-cpufreq governor: powersave cores: 1: 1400 2: 1400 3: 1400
4: 1400 bogomips: 20769
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 54.0 C
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07f6 built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon Vega 3 Graphics
(raven2 LLVM 15.0.7 DRM 3.49 6.1.6-hardened2-1-hardened)
direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Sound API: ALSA v: k6.1.6-hardened2-1-hardened running: yes
Message: No PCI device data found.
Device-1: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1.4:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp3s0f3u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 15.61 GiB (6.5%)
model: MZVLQ256HAJD-00000 size: 238.47 GiB block-size: physical: 512 B
rev: FXV7000Q temp: 18.9 C scheme: GPT
ID-1: / raw-size: 45.9 GiB size: 45.9 GiB (100.00%) used: 15.35 GiB (33.5%)
mapped: luks-fb551a59-b1f6-4fb4-a902-0a18c46bbd4c
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 259.4 MiB (52.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 45.9 GiB size: 45.9 GiB (100.00%)
used: 15.35 GiB (33.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 45.9 GiB size: 45.9 GiB (100.00%)
ID-5: /var/tmp raw-size: 45.9 GiB size: 45.9 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.75 GiB used: 572.2 MiB (9.7%)
System Temperatures: cpu: 54.9 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): cpu: 0
Processes: 228 Uptime: 1h 2m wakeups: 50878 Memory: 5.75 GiB
used: 2.25 GiB (39.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1255
libs: 329 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2023-01-04
Last full system update: 2023-01-21 ↻
Failed units: dev-nvme0n1p2.swap
I do it fore you, maybe you can't edit this one.
Audio also cuts out at certain points in the track as if the track has been manipulated yet it seems to be have *NOT been.
SGS
21 January 2023 19:05
#3
And please, format your first post. Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
In short
With 3 ~ in first and last line
Terminal text
then others can easily expand or copy the text.
terminal text
then others can easily expand or copy the text the view. Move the mouse pointer over it in the upper right corner.
Zenbook system output
Kernel: 6.1.7-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 12.2.1 parameters: pti=on page_alloc.shuffle=1
root=UUID=55c56afe-ed85-4263-be74-dacd068ee188 rw [email protected]
quiet
cryptdevice=UUID=341d1267-be1c-4197-9640-7c4201f29cac:luks-341d1267-be1c-4197-9640-7c4201f29cac
root=/dev/mapper/luks-341d1267-be1c-4197-9640-7c4201f29cac quiet splash
Type: Laptop System: ASUSTeK product: ZenBook UX425UG_Q408UG v: 1.0
Mobo: ASUSTeK model: UX425UG v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: UX425UG.301 date: 12/05/2021
ID-1: BATT charge: 46.5 Wh (91.9%) condition: 50.6/63.1 Wh (80.1%)
volts: 12.0 min: 12.0 model: ASUSTeK UX425 type: Li-ion serial: <filter>
status: discharging cycles: 124
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1458 high: 2100 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2100 2: 1400
3: 1400 4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400
12: 1400 bogomips: 50322
Device-1: NVIDIA TU117M [GeForce MX450] vendor: ASUSTeK driver: nvidia
v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 02:00.0
chip-ID: 10de:1f9c class-ID: 0302
Device-2: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 40.0 C
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0035 built: 2021
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.7-hardened1-1-hardened) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.1.7-hardened1-1-hardened running: yes
IF: enp4s0f3u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 960.43 GiB used: 16.25 GiB (1.7%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SD32G
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 42.32 GiB size: 42.32 GiB (100.00%)
used: 16.22 GiB (38.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-341d1267-be1c-4197-9640-7c4201f29cac
used: 26 MiB (27.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 42.32 GiB size: 42.32 GiB (100.00%)
ID-4: /var/log raw-size: 42.32 GiB size: 42.32 GiB (100.00%)
ID-5: /var/tmp raw-size: 42.32 GiB size: 42.32 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.17 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.1 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 298 Uptime: 7m wakeups: 97 Memory: 7.17 GiB
used: 2.12 GiB (29.5%) Init: systemd v: 252 default: graphical
pkgs: 1320 libs: 349 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-12-31
