Hello.
I just installed Garuda and I must say I really do love it. I am however experiencing some visual issues... I would attach a screenshot/image of what it looks like, but I cant as I'm new. So I uploaded it to imgur ![]()
Screenshot of settings (expected result): https://i.imgur.com/d2IGYWb.png
Photo of setup (actual result): https://i.imgur.com/XPvCrAu.jpeg
The cursor does move as normal on the left monitor, but selecting seems to be inverted and half of the center monitor shows on it. As for the monitor on the right, it seems shaky/blurry. Also on the dark background it looks as if text is burned into the screen (its not).
garuda-inxi output: Garuda-inxi output - Pastebin.com
╰─λ garuda-inxi
Kernel: 5.16.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=9c17b418-33df-4d0d-b680-e1e5ad3ec051 rw rootflags=subvol=@
Type: Desktop System: ECT product: N/A v: 2.0 serial: <superuser required>
Mobo: MSI model: CSM-B85M-E45 (MS-7817) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: 10.4
date: 02/20/2014
Info: model: Intel Core i5-4570 bits: 64 type: MCP arch: Haswell family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
desc: 1x6 MiB
Speed (MHz): avg: 3592 high: 3600 min/max: 800/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3598 2: 3571 3: 3600
4: 3600 bogomips: 25600
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Micro-Star MSI driver: i915 v: kernel ports: active: HDMI-A-2,VGA-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 3 speed: 8 GT/s ports: active: DP-1 empty: DVI-D-1,DVI-I-1,HDMI-A-3
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-9:4 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
gpu: i915,nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 4920x2126 s-dpi: 96 s-size: 1298x561mm (51.1x22.1")
s-diag: 1414mm (55.7")
Monitor-1: DP-1-1 mapped: DP-1 pos: middle-l model: Acer CB242Y
serial: <filter> built: 2019 res: 1080x1920 dpi: 93 gamma: 1.2
size: 296x527mm (11.7x20.7") diag: 604mm (23.8") ratio: 16:9 modes:
Monitor-2: HDMI2 mapped: HDMI-A-2 pos: bottom-r
model: LG (GoldStar) IPS FULLHD built: 2014 res: 1920x1080 hz: 60 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.6") diag: 551mm (21.7") ratio: 16:9
Monitor-3: VGA1 mapped: VGA-1 pos: primary,top-center
model: Samsung S24F350 serial: <filter> built: 2017 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 520x290mm (20.5x11.4") diag: 598mm (23.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.3.7 compat-v: 3.0 direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fbb
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.16.15-zen1-1-zen running: yes
Local Storage: total: 409.88 GiB used: 21.28 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD322HJ
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1118 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Innovation IT model: N/A
type: SSD serial: <filter> rev: 2A0 scheme: GPT
ID-1: / raw-size: 108.79 GiB size: 108.79 GiB (100.00%)
used: 20.85 GiB (19.2%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
used: 441.5 MiB (0.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 108.79 GiB size: 108.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 108.79 GiB size: 108.79 GiB (100.00%)
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18
ID-2: swap-2 type: zram size: 7.57 GiB used: 2.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 36.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 576
Processes: 258 Uptime: 27m wakeups: 0 Memory: 7.57 GiB
used: 4.38 GiB (57.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1801 lib: 540 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-18
Last full system update: 2022-03-18
