Fra96
August 17, 2022, 8:28am
1
Hello Garuda users.
I installed the new version of the video card driver hoping that this would fix the problem with the video card but the performance keep on being low. I tested on minecraft and the game doesn't overcome 20 FPS, the video card is recognized because the game says that the card used is RTX 2060. I saw in the System monitor that the GPU frequency is 75 MHz most of the time even if the GPU usage is 100%.
This is my garuda-inxi:
Kernel: 5.15.60-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=a715693c-beb0-4b88-870f-4885fc8edc10 rw rootflags=subvol=@
quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=2
loglevel=3 ibt=off
Type: Laptop System: PC Specialist product: Recoil v: Standard
Mobo: Tong Fang model: GK5CP0Z v: Standard serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: N.1.51 date: 04/04/2019
ID-1: BAT0 charge: 29.1 Wh (75.0%) condition: 38.8/46.7 Wh (82.9%)
volts: 12.5 min: 11.4 model: standard type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 4010 high: 4069 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3998 2: 3984 3: 4006
4: 4017 5: 4069 6: 4033 7: 3992 8: 3988 9: 4016 10: 4047 11: 3993
12: 3982 bogomips: 52799
vulnerable
prctl and seccomp
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Tongfang Hongkong driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Tongfang Hongkong driver: nvidia v: 515.65.01
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-07) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none empty: DP-2,DP-3,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:1f11
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:3
chip-ID: 04f2:b65a class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Monitor-1: eDP-1 mapped: eDP-1-1 model: BOE Display 0x07af built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Tongfang Hongkong
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-lts running: yes
vendor: Tongfang Hongkong driver: r8168 v: 8.050.03-NAPI modules: r8169
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
Device-2: Intel Wireless-AC 9260 vendor: Rivet Networks driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 232.89 GiB used: 96.29 GiB (41.3%)
model: WDS250G2X0C-00L350 size: 232.89 GiB block-size: physical: 512 B
rev: 101140WD temp: 51.9 C scheme: GPT
ID-1: / raw-size: 75 GiB size: 75 GiB (100.00%) used: 23.25 GiB (31.0%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 157.87 GiB size: 157.87 GiB (100.00%) used: 73.04
GiB (46.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /var/log raw-size: 75 GiB size: 75 GiB (100.00%) used: 23.25 GiB
(31.0%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/tmp raw-size: 75 GiB size: 75 GiB (100.00%) used: 23.25 GiB
ID-1: swap-1 type: zram size: 15.48 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: 63.0 C pch: 59.0 C mobo: N/A gpu: nvidia
temp: 63 C
Processes: 331 Uptime: 19m wakeups: 1 Memory: 15.48 GiB used: 2.43 GiB
(15.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1651 lib: 396
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-04-03
Last full system update: 2022-08-17
Thank you to whom wants to help.
On Garuda Assistant enable all performance options, also on enable performance mode in the battery icon on system tray. Your CPU is in powersave mode,
Fra96
August 17, 2022, 10:18am
3
Thank you, solved
There should be some problem with change between powersave and performance because each other component was in performance mode so I had to switch manually the CPU with the command
cpupower frequency-set --governor performance
I think I'll make an automatic script, if needed I can share it.
Fra96
August 17, 2022, 6:21pm
4
Ok, I have rebooted and the problem is the same as before, but now the CPU is in performance mode and the other devices too. The video card is fixed to 75 MHz clock for the majority of the time.
It worked only one time
New garuda-inxi:
loglevel=3 ibt=off
ID-1: BAT0 charge: 36.8 Wh (94.8%) condition: 38.8/46.7 Wh (82.9%)
volts: 11.7 min: 11.4 model: standard type: Li-ion serial: <filter>
status: charging
Speed (MHz): avg: 3946 high: 3998 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 3916 2: 3985 3: 3902
4: 3901 5: 3998 6: 3962 7: 3973 8: 3986 9: 3952 10: 3806 11: 3997
12: 3975 bogomips: 52799
vulnerable
prctl and seccomp
Local Storage: total: 232.89 GiB used: 88.12 GiB (37.8%)
rev: 101140WD temp: 45.9 C scheme: GPT
ID-1: / raw-size: 75 GiB size: 75 GiB (100.00%) used: 14.94 GiB (19.9%)
ID-2: /home raw-size: 157.87 GiB size: 157.87 GiB (100.00%) used: 73.18
GiB (46.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /var/log raw-size: 75 GiB size: 75 GiB (100.00%) used: 14.94 GiB
(19.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/tmp raw-size: 75 GiB size: 75 GiB (100.00%) used: 14.94 GiB
ID-1: swap-1 type: zram size: 15.48 GiB used: 1.2 MiB (0.0%)
System Temperatures: cpu: 78.0 C pch: 51.0 C mobo: N/A gpu: nvidia
temp: 65 C
Processes: 326 Uptime: 6h 26m wakeups: 1 Memory: 15.48 GiB used: 2.54 GiB
(16.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1652 lib: 396
Garuda (2.6.6-1):
You have an Optimus laptop.
Are you running Minecraft on the iGPU or the dGPU?
Verify by running nvidia-smi
in a terminal.
TNE
August 17, 2022, 7:34pm
6
prime-run minecraft-launcher
Fra96
August 18, 2022, 8:18am
7
The game says Nvidia RTX 2060, usually the integrated one performs better.
nvidia-smi
output:
Wed Aug 17 20:46:12 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 58C P3 26W / N/A | 943MiB / 6144MiB | 87% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 7701 G /usr/lib/Xorg 212MiB |
| 0 N/A N/A 9104 G /usr/bin/kwin_x11 78MiB |
| 0 N/A N/A 11032 G /usr/bin/plasmashell 53MiB |
| 0 N/A N/A 11154 G /usr/bin/latte-dock 22MiB |
| 0 N/A N/A 44241 G /usr/bin/firefox-esr 173MiB |
| 0 N/A N/A 2435575 G ...uncher/minecraft-launcher 8MiB |
| 0 N/A N/A 2437795 G ...va-runtime-gamma/bin/java 385MiB |
Fra96
August 18, 2022, 8:20am
8
Doesn't work because I already use the nvidia video card (prime has nvidia video card as default).
sudo nvidia-smi -lgc 1000,1000
This command should pin GPU frequency to 1000 MHz.
Fra96
August 18, 2022, 4:19pm
10
This is quite strange because when I stay on the desktop without game open it stay on 1 GHz while when I start the game or the game is opened the frequency is stable on 75 MHz.
I used this command to unlock the frequency and it works in the same way so change the frequency on idle, but is quite fixed to 75 MHz when the game is opened.
sudo nvidia-smi -lgc unlimited,unlimited
Could you have enabled a low performance or battery conservation mode in Minecraft?
TNE
August 18, 2022, 4:41pm
12
Ah right, I should've checked that in the inxi first, I see it now, sorry.
Fra96
August 18, 2022, 4:45pm
13
I thinked that and I tried to do a benchmark to be sure, the benchamark locks on one of the phases, but I could see an inconstant framerate, the partial results are
meanFPS: 20.7
Time: 124.5s
Frames: 2572
MinFPS: 3.9
MaxFPS: 103.7
Scene: 12/18
The framerate went like a wave. Also frequencies have same behaviour.
I used Unigine valley benchmark
So we know it is not Minecraft specific. Disable KDE compositor (AFAIK Shift+Alt+F12 does it, check settings if it fails) quit Latte Dock by right clicking on a dock and choosing "quit latte" then run benchmark again. Use MangoHUD while benching so you can monitor temperatures.
EDIT: Temps are a bit high. What were you doing when running inxi?
temp: 65 C
Fra96
August 18, 2022, 5:49pm
15
This time the benchmark ended so I have the results. They are slightly better, but the behaviour is as similar as before.
The temperature was never above 75°C.
I was starting and stopping minecraft so I think it is normal.
Results:
|FPS:|**22.1**|
|Score:|**924**|
|Min FPS:|**4.9**|
|Max FPS:|**122.7**|
## System
|Platform:|Linux 5.15.60-1-lts x86_64|
|CPU model:|Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz (2207MHz) x12|
|GPU model:|NVIDIA GeForce RTX 2060 PCI Express 515.65.01 (6144MB) x1|
## Settings
|Render:|OpenGL|
|Mode:|1920x1080 fullscreen|
|Preset|Custom|
|Quality|High|
Powered by [UNIGINE Engine](http://unigine.com/products/unigine/)
[Unigine Corp.](http://unigine.com/) © 2005-2013
That level of performance doesn't make any sense.
Is your PSU able to provide enough power for the GPU? Is it connected correctly with all relevant molex connectors? Is it in the correct PCIe slot?
Fra96
August 18, 2022, 6:11pm
17
The computer is a notebook, so the slot is correct because I used Kubuntu in the past and it worked well. For the PSU I can try to change it.
Have you cleaned out its vents and fans recently?
Fra96
August 18, 2022, 6:14pm
20
Yes, more or less two month ago, and the temperature is not too high (the benchmark reached 75°C, but most of the time was 70°C or less)
That could just be the system performing thermal throttling, which would also explain
Have you made any other changes to your system other configuration since installing?
