I think you might need to repaste your cpu and gpu
The CPU I think is ok, I done a mini benchmark and the full load temperature is under 72°C with no effort from fans. The PC is not so old.
Another think that for me excludes hardware issues may be the fact that for one time it worked. ( on minecraft stable 180 FPS, now 10/15 FPS ).
I don't know if it could be helpful, but I gave a look to the dmesg and I have some errors:
[ 0.258025] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [SAC1] at bit offset/length 64/64 exceeds size of target Buffer (64 bits) (20210730/dsopcode-198)
[ 0.344617] ACPI: 10 ACPI AML tables successfully acquired and loaded
[ 0.347318] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20210730/nsinit-411)
[ 0.347325] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20210730/nsinit-419)
[ 0.359389] ACPI: Dynamic OEM Table Load:
[ 0.359397] ACPI: SSDT 0xFFFF90B740222600 0000F4 (v02 PmRef Cpu0Psd 00003000 INTL 20160527)
[ 0.360838] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20210730/nsinit-411)
[ 0.360843] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20210730/nsinit-419)
[ 0.361581] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.363578] ACPI: Dynamic OEM Table Load:
[ 0.363586] ACPI: SSDT 0xFFFF90B741A08800 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.365070] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20210730/nsinit-411)
[ 0.365075] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20210730/nsinit-419)
[ 0.366033] ACPI: Dynamic OEM Table Load:
[ 0.366040] ACPI: SSDT 0xFFFF90B741A1E800 0004FD (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.367741] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20210730/nsinit-411)
[ 0.367745] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20210730/nsinit-419)
[ 0.369305] ACPI: Dynamic OEM Table Load:
[ 0.369313] ACPI: SSDT 0xFFFF90B741A1E000 0005FC (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.371043] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20210730/nsinit-411)
[ 0.371047] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20210730/nsinit-419)
[ 0.372304] ACPI: Dynamic OEM Table Load:
[ 0.372314] ACPI: SSDT 0xFFFF90B74012F000 000AB0 (v02 PmRef ApPsd 00003000 INTL 20160527)
[ 0.375218] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20210730/nsinit-411)
[ 0.375222] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20210730/nsinit-419)
[ 0.376125] ACPI: Dynamic OEM Table Load:
[ 0.376131] ACPI: SSDT 0xFFFF90B741A0E800 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.377654] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20210730/nsinit-411)
[ 0.377657] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20210730/nsinit-419)
[ 2.942030] usbhid 1-6:1.0: couldn't find an input interrupt endpoint
[ 2.960187] r8168 Copyright (C) 2022 Realtek NIC software team <[email protected]>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 4.734441] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 4.734455] ucsi_ccg 0-0008: i2c_transfer failed -110
[ 4.734463] ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
[ 6.792639] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
[ 58.737381] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=11803 end=11804) time 180 us, min 1063, max 1079, scanline start 1057, end 1086
[ 137.119738] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=23090 end=23091) time 154 us, min 1063, max 1079, scanline start 1056, end 1081
[ 432.225613] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=65585 end=65586) time 146 us, min 1063, max 1079, scanline start 1061, end 1085
[ 506.649724] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=76302 end=76303) time 344 us, min 1063, max 1079, scanline start 1041, end 1093
Some of these are nvidia errors.
