Hello folks! I’m now trying to figure out another thing as part of my migration from windows =p how to authenticate to a website and how to sign a PDF using a smart card digital certificate.
I’ve found out about lots of stuff already, like the Arch Wiki article on Smart Cards, and using Okular to sign PDFs…
I got around to install the recommended packages with
sudo pacman -S ccid opensc pcsc-tools
sudo systemctl enable pcscd.service
sudo systemctl start pcscd.service
When I run pcsc_scan
it properly shows me my reader and details on my card’s certificate:
$ pcsc_scan
PC/SC device scanner
V 1.6.2 (c) 2001-2022, Ludovic Rousseau <ludovic.rousseau@free.fr>
Using reader plug'n play mechanism
Scanning present readers...
0: Gemalto PC Twin Reader 00 00
Possibly identified card (using /usr/share/pcsc/smartcard_list.txt):
3B 7D 96 00 00 80 31 80 65 B0 83 11 11 E5 83 00 90 00
3B 7D .. 00 00 80 31 80 65 B0 .. .. .. .. 83 .. 90 00
IDClassic 3XX / Classic TPC (IXS, IS, IS V2, IS CC, IM, IM CC, IM CC V3) / MultiApp ID Cards
Gemalto TOP DL v2 StdR
eCPF (Cadastro de Pessoas Físicas) from Imprensa Oficial do Brasil
Identidade digital (e-CPF) from Caixa
The Arch Wiki article mentions that
The Chrome, Firefox, Thunderbird and SeaMonkey are automatically processed with pkcs11-register(1) at each login . (Discuss in Talk:Smartcards)
So I shutdown my browser, executed it… and still nothing. Sadly, the “Talk:Smartcards” is completely empty.
I thought maybe it was enough that pcsc_scan
could see my reader and certificate, but I still get no success on trying to login either on FireDragon or Vivaldi, and the certificate also won’t show up on Okular (when I go Tools > Digitally Sign, all I get is an error message about there being no signing certificates available and a link to a manual about adding digital signatures which must be outdated, since there’s nothing about the subject there)
$ garuda-inxi
Kernel: 6.2.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=468e3250-834f-4678-85b1-f50f268e557d rw rootflags=subvol=@
resume=UUID=92d5bc58-440e-4eab-9f01-4fa35d34e02b loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: G5 5590 v: N/A
Mobo: Dell model: 0F3T2G v: A00 serial: <superuser required> UEFI: Dell
v: 1.22.0 date: 11/10/2022
ID-1: BAT0 charge: 48.6 Wh (100.0%) condition: 48.6/60.0 Wh (81.0%)
volts: 16.6 min: 15.2 model: SMP DELL JJPFK87 type: Li-poly serial: <filter>
status: full
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1849 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 800 3: 800
4: 2600 5: 2600 6: 2600 7: 799 8: 2600 9: 800 10: 2600 11: 2600 12: 800
bogomips: 62399
ports: active: none off: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:671f class-ID: 0e02
Screen-1: 0 s-res: 2560x2160 s-dpi: 96 s-size: 675x570mm (26.57x22.44")
s-diag: 883mm (34.78")
Monitor-1: DP-1-0 pos: primary,top res: 2560x1080 hz: 60 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
Monitor-2: HDMI-1-0 pos: bottom res: 2560x1080 hz: 60 dpi: 96
size: 677x290mm (26.65x11.42") diag: 736mm (29") modes: N/A
Monitor-3: eDP-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
bus-ID: 1-4.1:5 v: kernel chip-ID: 1b3f:2008
class-ID: 0300 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Generalplus USB Audio Device type: USB
Device-4: Realtek USB Audio type: USB driver: snd-usb-audio
bus-ID: 1-4.5:9 chip-ID: 0bda:4014 class-ID: 0102 serial: <filter>
API: ALSA v: k6.2.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.67 status: active with: 1: pipewire-pulse
Device-1: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
IF: enp60s0 state: down mac: <filter>
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 3d:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 48.0 C
IF: wlp61s0 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 6-1.2:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:8
chip-ID: 0cf3:e007 class-ID: e001
Local Storage: total: 1.14 TiB used: 538.63 GiB (46.0%)
model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
rev: 20240012 temp: 51.9 C scheme: GPT
model: WD10SPZX-75Z10T3 size: 931.51 GiB block-size: physical: 4096 B
rev: 4514 scheme: GPT
ID-1: / raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
used: 63.78 GiB (28.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 624 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
ID-4: /var/log raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.43 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 69.0 C pch: 69.0 C mobo: 65.0 C
Fan Speeds (RPM): cpu: 2418 fan-1: 2353
Processes: 323 Uptime: 1h 12m wakeups: 3 Memory: 15.43 GiB
used: 6.72 GiB (43.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1920
libs: 531 tools: gnome-software,octopi,pamac,paru,yay pm: appimage pkgs: 0
Shell: Zsh v: 5.9 running-in: kitty inxi: 3.3.26
System install date: 2023-04-01
Last full system update: 2023-04-06
